Enthusiast Joined Jun 4, '03 From chitown Currently Offline Reputation: 0 (0%) ![]() |
I need help on flushing and replacing my transmission fluid and filter. I was told that there are two bolts to loosen, one is drain bolt and one is refill(???) bolt. I was wondering if anyone can tell me if thats right or basically a how-to on this, or even any website that has this info. any opinions, help or advice is greatly appreciated!!! thanks in advance
![]() Enthusiast Joined Nov 4, '02 From montrose colorado Currently Offline Reputation: 0 (0%) ![]() |
auto or manual
95 celica st auto
Enthusiast ![]() ![]() Joined Mar 31, '03 From BC Currently Offline Reputation: 0 (0%) ![]() |
I know this is more expensive, but it might be easier to just have the dealer do it, the dealer I go for auto trans fluid replacement is cheaper than say jiffy lube, etc.
Enthusiast ![]() Joined Apr 24, '03 From NYC Currently Offline Reputation: 0 (0%) ![]() |
That's for manual tranny only.....and if anyone is gonna change the manual tranny fluid, make sure you can undo the filler bolt before you drain it, or you'll be screwed with the oil out of the tranny and can't fill it back up. For auto tranny, there's a drain bolt on the pan, at the bottom of the tranny. To get to the filter, you'll need to take the pan off as well. To refill it, you'd pour the oil down the dip stick tube. You could also stick a tube down the dip stick tube and suck the oil out too. But either way, you wouldn't get all the oil out. To do a really good flush n refill, a shop would use a machine to do that. Take a look at the current issue of Popular Mechanics; there's a good how-to article on changing auto tranny fluid that I read it at someone's house. Probably the June issue. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Hecho en la Republica Dominicana/Living in NJ Currently Offline Reputation: 0 (0%) ![]() |
ok and auto transmission is a real bitch to change the fluid in....you need a machine to drian all the fluid out of an auto trans..so i would tell you just take it shop and let them do it...
![]() Enthusiast ![]() Joined Apr 9, '03 From Long Island, New York Currently Offline Reputation: 0 (0%) ![]() |
yea take it to toyota... its worth it not to screw anything up
good call Macavely |
yeah bring to us it takes about an hour and all the fluid get removed. its well worth the cost and adds life to ur trans.
thankx for all your response, shop it is then...
Lo-Fi Version | Time is now: February 23rd, 2025 - 1:58 PM |
