> what is it part, of my 3sgte
post Apr 21, 2006 - 12:29 PM
3rdgen3SGTE
Joined Nov 21, '05
From Quebec
This is part I can't identifie
what it is?
I know it's have map sensor,ignitor and ecu (dont have pic for that)
if Someone know some other part can I have need for swap in 5sfe car
Tank you
This post has been edited by 3rdgen3SGTE: Apr 21, 2006 - 2:10 PM
Celica GTS turbo 1994
3sgte genIII Ct20b
Replies (1 - 6)
post Apr 21, 2006 - 12:30 PM
Fuel injector relay or fuel pump relay cant tell which. Whats the number on the back?
I'm not quite sure what your asking in your other question(s).
This post has been edited by Supersprynt: Apr 21, 2006 - 12:31 PM
post Apr 21, 2006 - 12:36 PM
3rdgen3SGTE
Joined Nov 21, '05
From Quebec
I want know if I need other part for my swap
QUOTE(Supersprynt @ Apr 21, 2006 - 12:30 PM) [snapback]424511[/snapback]
I have two same thinks part so one with 2 wires and the other 5 wires I think is that fuel and injecteur resistor
This post has been edited by 3rdgen3SGTE: Apr 21, 2006 - 12:38 PM
3sgte genIII Ct20b
post Apr 21, 2006 - 2:26 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
the 5 wires is the fuel injector resistor pack, you NEED this, ive read on mr2oc and celicatech i think some people remove them, but DO NOT do it, its unsafe, im not sure why they do it but they are flirting with disaster.
the other one is fuel pump resistor pack which you do not need.
post Apr 21, 2006 - 2:57 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
Last part is an idle control valve. Operates when you have the aircon running for example.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Apr 21, 2006 - 6:11 PM
phattyduck
Joined Dec 5, '05
From LA, CA
The two silver boxes: 2-wire is the fuel pump resistor, the 5-wire is for the injector resistors.
The third picture is your ignition coil (I think - the picture is unclear)
The fourth picture is the air bypass for the air conditioning. It can be removed (and the assciated ports on the manifold and intercooler plugged) if you are removing your A/C.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Apr 21, 2006 - 8:47 PM
3rdgen3SGTE
Joined Nov 21, '05
From Quebec
Tanks lots
It's my 3rd 3sgte engine that I buy and now need other one only for injector resistor pack if my 4th gen Map sensor fit on the 3rd gen engine.
Or maybe some place for buy injector resistor pack I don't need so lot of spare part
3sgte genIII Ct20b
Lo-Fi Version Time is now: February 23rd, 2025 - 4:19 AM
