> power stearing, need help
post Apr 29, 2006 - 1:25 PM
esd_1985
Joined Mar 29, '06
From Lincoln
It feels like my power steering is going out its hard ta turn not all the time but it feels like it catches but its fine when im moving
Replies (1 - 6)
post Apr 29, 2006 - 1:30 PM
Chanh55
Joined Jun 29, '03
Check the fluid level, then check the lines and make sure there are no leaks.
post Apr 29, 2006 - 1:40 PM
Rayme
Joined Feb 18, '06
From NB, Canada
a binding U-joint can can that erratic "grabby" feeling too, try to lube it up.
-Rémy
02 SiR, 08 250R
post Apr 29, 2006 - 4:00 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
Also ensure that the belt is correctly tensioned.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Apr 29, 2006 - 9:57 PM
QUOTE(Rayme @ Apr 29, 2006 - 1:40 PM) [snapback]427898[/snapback]
perhpas you mean balljoint or CV joint? front wheel drive cars dont have U joints.
it sounds like air in the lines due to low fluid level. to purge air, fill the resivor, leave the cap off, turn the wheel lock to lock several times, then check the fluid level again and add as needed. do this until it feels normal again.
This post has been edited by Bitter: Apr 29, 2006 - 9:59 PM
post Apr 30, 2006 - 8:02 AM
Rayme
Joined Feb 18, '06
From NB, Canada
QUOTE(Bitter @ Apr 29, 2006 - 11:57 PM) [snapback]428028[/snapback]
The joint you see where the steering column comes out of the firewall, I'ts called a u joint, what do you mean? smile.gif
-Rémy
02 SiR, 08 250R
post Apr 30, 2006 - 10:51 AM
ah ok. ive always called that the rag joint or some other name, infact newer cars use CV style joints there.
Lo-Fi Version Time is now: January 10th, 2025 - 3:02 PM
