![]() Enthusiast ![]() Joined Apr 16, '06 Currently Offline Reputation: 0 (0%) ![]() |
Alright, so on each of my doors the cloth that goes over the fatty padding is starting to come off, no more stickyness to hold it there.
Should I rip off the cloth and clean off the padding that was underneath and just have it like that? *Update* Alright, so I ripped the cloth pieces off the doors and used Goo Gone and a tough pad a bunch of times to get rid of the ****ty glue and whatnot which was still there after the cloth came off. Problem is it's alittle faded and whatnot and theres tiny tiny tiny areas of the **** yet that won't go away. So I'm thinking I should just paint it. But I'm not sure what kind of paint to use for one, and secondly how to go about painting it without getting it on the rest of the door and whatnot.. This post has been edited by Pulse_of_Enigma: May 1, 2006 - 1:32 PM -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 25, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) ![]() |
I'll go with 1.
It's easier and still retain the factory look. The other option I would consider is getting it retrim in leather. -------------------- ![]() 98 ST204 ZR - Black Beauty - Roaming the streets of Sydney 73 TA22 LT - Tiffany Blue - Mint Classic Weekend Cruiser 75 TA22 LT - Snow White - Mint Classic Weekend Cruiser 77 RA28 LT - Flubber Green - Mint Classic Weekend Cruiser 94 MX-5 NA8 Clubman - Red Racer - Looking for corners WIP Project: 69 RT40 Corona, 2nd WIP Project: 66 RT40 1600s Corona 86 Corona RT142 - Daily Driver 6GC 4 Life Baby!!! |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '04 Currently Offline Reputation: 5 (100%) ![]() |
I had the exact same problem as you! I ended up ripping off the cloth (it was faded anyways) and it looks much much cleaner now! But I will tell you, it wasn't fun cleaning off that glue. Me and a friend used some goo-gone, and a steel wool pad. I like it a lot better this way!
Alright, thanks for the input. I sort of want to go with option 2.
Wait, the steel wool pad didn't scratch it up? And what about the coloration after it all came off?
QUOTE(gt_driFFter @ Apr 29, 2006 - 9:46 PM) [snapback]428025[/snapback] I had the exact same problem as you! I ended up ripping off the cloth (it was faded anyways) and it looks much much cleaner now! But I will tell you, it wasn't fun cleaning off that glue. Me and a friend used some goo-gone, and a steel wool pad. I like it a lot better this way! -------------------- |
Other opinions and suggestions/ideas are more than welcomed too, lol.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) ![]() |
Mine's doing the same thing, I think I'm going to peel it off and dye it black then glue it back on
anyone know of good fabric glue for this kinda thing? -------------------- 1999 Celica GT
*Update*
Alright, so I ripped the cloth pieces off the doors and used Goo Gone and a tough pad a bunch of times to get rid of the ****ty glue and whatnot which was still there after the cloth came off. Problem is it's alittle faded and whatnot and theres tiny tiny tiny areas of the **** yet that won't go away. So I'm thinking I should just paint it. But I'm not sure what kind of paint to use for one, and secondly how to go about painting it without getting it on the rest of the door and whatnot.. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) ![]() |
Mine had the same problem a few years back, so I just took some spray adhesive, and glued it together/made it look like stock again (even tucking the sides of the fabric into the crack around it)…. Waaalaaa,
![]() ...btw, is there not a way to take that small panel out and re-fabric "properly"? ~snap -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
![]() Enthusiast ![]() ![]() Joined Jan 22, '04 From WA, Australia Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(snapshotgt @ May 2, 2006 - 4:23 AM) [snapback]428666[/snapback] ...btw, is there not a way to take that small panel out and re-fabric "properly"? ~snap That's what I'd always planned to do, but I've been told, the bit around the door handle, which is all tucked in, doesnt come off? So apparently you can't the fabric out there, without cutting it. I'm not sure on this though, it's just what I've heard. |
QUOTE(snapshotgt @ May 1, 2006 - 3:23 PM) [snapback]428666[/snapback] Mine had the same problem a few years back, so I just took some spray adhesive, and glued it together/made it look like stock again (even tucking the sides of the fabric into the crack around it)…. Waaalaaa, ![]() ...btw, is there not a way to take that small panel out and re-fabric "properly"? ~snap That is a very very good question. QUOTE(ShadowFX @ May 1, 2006 - 4:58 PM) [snapback]428707[/snapback] That's what I'd always planned to do, but I've been told, the bit around the door handle, which is all tucked in, doesnt come off? So apparently you can't the fabric out there, without cutting it. I'm not sure on this though, it's just what I've heard. Well, to answer, all my cloth came off and out perfectly, nothing ripped and I didn't have to cut anything. -------------------- |
Did you just pull it off? Or take the door apart? or..?
the cloth simply comes right out.
QUOTE(ShadowFX @ May 2, 2006 - 6:43 AM) [snapback]429005[/snapback] Did you just pull it off? Or take the door apart? or..? Pretty much what prsure said.. I didn't take anything apart, just pulled right out. Maybe the worse the glue is underneath the easier to pull off. -------------------- |
Hmm, yeah.. I wonder if you take the door apart, if you can pop that thick pad out that the cloth was overtop... It would be alot easier to clean and possibly re-paint.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) ![]() |
Well i just went out and pulled mine off cuz it was coming off. I do like how I looks, I just need to clean it up..
So did you all use SOS pads? Or what? ![]() This post has been edited by Jaws4God: May 12, 2006 - 5:21 PM -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
QUOTE(Jaws4God @ May 12, 2006 - 5:07 PM) [snapback]433351[/snapback] Well i just went out and pulled mine off cuz it was coming off. I do like how I looks, I just need to clean it up.. So did you all use SOS pads? Or what? ![]() I used Goo Gone, some water and a towel and a really stiff black scrubbie type thing. -------------------- |
Lo-Fi Version | Time is now: February 21st, 2025 - 8:56 AM |
