7afte TMIC?, Is it possible? |
May 10, 2006 - 11:40 PM |
Enthusiast Joined Apr 6, '06 From Willington, CT Currently Offline Reputation: 0 (0%) |
is a top mount intercooler even capable of being used on a 7afte... i have a 7afe and plan on beginning to buy all necessary items for turbo instalation and was wondering if it would even work for this engine and where i can get one if it could.
(i dont plan on running alot of boost.. at all. 10 psi tops so max hp that i can reach isnt really an issue) -------------------- Mini Supra... in need of mini boost.
May 10, 2006 - 11:46 PM |
the top mount is a good intercooler.... but you cant mount it on top like the 3sgte has. you can use it, but have to figure out a way to mount it up front or off the the side.
May 10, 2006 - 11:53 PM |
QUOTE(lagos @ May 10, 2006 - 11:46 PM) [snapback]432718[/snapback] the top mount is a good intercooler.... but you cant mount it on top like the 3sgte has. you can use it, but have to figure out a way to mount it up front or off the the side. I figured... it looks like there isnt much above the engien room for teh 7afe... it was just a thought. thanx. -------------------- Mini Supra... in need of mini boost.
Jun 9, 2006 - 9:56 AM |
Enthusiast Joined Dec 19, '05 Currently Offline Reputation: 0 (0%) |
my 7afte is TMIC. it uses the bracket from the 4efte. but you cant really put a big intercooler if its top mount. also you always need to remove the intercooler when changing sparkplugs.
Jun 9, 2006 - 10:33 AM |
Enthusiast Joined May 17, '03 From Florence, KY Currently Offline Reputation: 0 (0%) |
QUOTE(akiyama @ Jun 9, 2006 - 10:56 AM) [snapback]442921[/snapback] my 7afte is TMIC. it uses the bracket from the 4efte. but you cant really put a big intercooler if its top mount. also you always need to remove the intercooler when changing sparkplugs. Pictures please. |
Jun 9, 2006 - 11:15 AM |
with a TMIC, if your not directing cold, outside air over it somehow, it is pretty much usless.
i cant see why youd even bother with one, unless its a W2A top mount, with the heat exchanger mounted up front, like the 185RC, or the 205 -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Jun 9, 2006 - 11:30 AM |
Enthusiast Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
What I would do is relocate the battery and then use a W2A intercooler on the right side of the motor. For space reasons I would find a smaller EBay unit like a spearco or turbonetics design, then youre good to go.
Then all you would need is a resivoir for the coolant/water mixture, a pump to keep it flowing, and perhaps a heat exchanger to cool off the fluid to keep intercooler temps down. That would make for a nice setup with very little lag and good cooling properties. EDIT- Manny beat me to the punch....doh. This post has been edited by Silver94CelicaOwner: Jun 9, 2006 - 11:31 AM -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Lo-Fi Version | Time is now: January 10th, 2025 - 10:17 PM |
