A/C causing problems..., Engine overheats |
Jun 22, 2006 - 7:00 PM |
Enthusiast Joined Jun 7, '06 From Desert Hot Springs Currently Offline Reputation: 0 (0%) |
Alright, I've already replaced the radiator. But my celica still overheats when I turn on the A/C. Does anyone have any idea what the problem may be?
Jun 22, 2006 - 7:22 PM |
condensor fan is working?
Jun 22, 2006 - 9:30 PM |
where would that be?
Jun 22, 2006 - 9:38 PM |
the fan infront of the radiator.
Jun 23, 2006 - 1:07 AM |
yes both of them are working perfectly.
Jun 23, 2006 - 6:28 PM |
Enthusiast Joined Apr 2, '06 From Socal Currently Offline Reputation: 0 (0%) |
did you check your waterpump?
Jun 24, 2006 - 1:32 AM |
it's a fairly new one. i'll check it out though.
Jun 24, 2006 - 8:23 AM |
Enthusiast Joined Jun 14, '06 From bainbridge ga Currently Offline Reputation: 2 (100%) |
have you washed the bugs out of the condenser 7 out of 10 issues with ac / overheating is related to insuffecient airflow get a goooooood degreaser and spray the condenser down and wash it out also have you checked the coolant if theres and crusty looking goop in the radiator you'll need to do a system flush which i recomend doing any way if you haven't done it it keeps things nice n clean and a nice n clean engine is one that will go for 3000 million miles lol seriously though wash your condenser out i seen tooooo many cases where guys will buy high flow bada*s radiators to try n fix a overheating issue when all it was well was dragon flys n bumble bees over the years blocking off airflow through the radiator
This post has been edited by expedition2166: Jun 24, 2006 - 8:25 AM |
Jun 25, 2006 - 2:27 AM |
Enthusiast Joined Jun 25, '06 From Bremerton, Washington Currently Offline Reputation: 1 (100%) |
i dont know if this is right but the same thing happen to my integra it had a blown head gasket i don't know if that has to do anything to your problems
This post has been edited by rayneezy23: Jun 25, 2006 - 2:27 AM |
Jun 25, 2006 - 9:48 PM |
Enthusiast Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
i know your a bright person so im going to spare the "check your fluids" speach. maybe you could check to make sure the thermostat is opening up, that could be your problem, cuz youd still be getting cold air, but putting way too much strain on the engine without pumping the coolant through your head.
-------------------- The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Jun 28, 2006 - 6:05 PM |
Well, I've cleaned out the condenser... I don't think that was it . Next I'm going to check the thermostat. But I think it's the head gasket.
Jul 4, 2006 - 4:08 AM |
alright... the thermostat IS working properly... the water pump is working just fine... the condenser is clean... the radiator is new...
What else could it be? |
Lo-Fi Version | Time is now: December 1st, 2024 - 7:36 AM |
