> ever seen this before?, Apex'i Front Strut Bar
post Jun 22, 2006 - 9:01 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i saw it online, it resembles closely to that of a Cusco strut bar
anyway, i was in absolute awe when i saw it.. thinking "whoa, never seen this before on a 6th gen"
it's not in the Parts Database, so i'm guessing it is now discontinued? or maybe atleast it's very rare.
here are some pics: (u can never get sick of pics..)
well, i just got it in earlier today, and because i haven't worked for 2 weeks straight due to an injury on my right leg, i had nothing else to do and i just HAD to install it!
you know how it is when you get a part you've been waiting to get... hehe biggrin.gif
here it is installed:
IPB ImageIPB ImageIPB Image
unfortunately, the power steering reservoir is sort of in the way and now it's tilting slightly to the inside when the bar is in place.. i'm guessing it's located elsewhere on a gt-four. but let's just hope that the bar does it's job and doesn't push the reservoir any further during a hard turn or else i'll have a big problem.
also, since the bar is meant for an st205, it kinda bridges upward.. which makes the stock hood hard to close. but that's okay.... for now wink.gif
IPB ImageIPB Image
Replies (1 - 17)
post Jun 22, 2006 - 9:19 PM
its hinged at either end which means the bar will twist and flex with the car and NOT keep the body rigid.
you can make your own bar with a little work and a few tools that will actually stiffen things and costs alot less. im making one soon for my prizm, i'll make a little thread when i'm done.
the stock bar is 3 point which is ALOT better than any 2 point bar. the shorter the bar spans the less it'll flex and the thinner and lighter the material can be.
This post has been edited by Bitter: Jun 22, 2006 - 9:20 PM
post Jun 22, 2006 - 11:00 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i just got back from a quick test drive..
the car feels a lot more solid during turns than the stock bar did. with the stock bar, the car felt like the front chassis was still flexing during a hard turn which slows the car down but with this, it felt more rigid and solid which made turning quicker and more responsive.
and yes, the bar is hinged but it isn't hinged loosely. cuz then, what is the point in adding a strut bar? i believe they're hinged for easier installation and can be adjusted to spread to really tighten the gap between the struts..
a fully closed 3-point strut bar like TRD, JSpeed and C-ONE truly is better than any 2-point. however, the stock strut bar only has 2 members going diagonally from the firewall. with that said, the stock strut bar allows for better bracing during linear hard braking but the 2-point bar allows for better bracing while actually doing the turn.
but that's just my opinion..
post Jun 23, 2006 - 2:46 PM
jdg371
Joined Jun 14, '05
is there a possibel way to combine the stock sway bar and a straight bar making a full 3pt?
post Jun 23, 2006 - 2:54 PM
QUOTE(jdg371 @ Jun 23, 2006 - 2:46 PM) [snapback]448145[/snapback]
its really easy, get a peice of pipe bent and welded to the stock bar.
post Jun 23, 2006 - 6:18 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
QUOTE(azian_advanced @ Jun 22, 2006 - 9:01 PM) [snapback]447853[/snapback]
I find this quite worrying. Should you really be modding cars if you think that the brake fluid resevoir is where the power steering fluid goes? wink.gif
PAS Fluid Reservoir
Brake Fluid Reservoir
Besides, forcing the brake reservoir over to one side means that it won't seat properly and that means a huge risk of leaks and even air getting into the system. That brace is obviously not meant to fiit your car. Simply bending (critical) parts out of the way is not the ideal solution to making things fit.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Jun 23, 2006 - 7:20 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
OMG! ^ the above post kills me lol
check your halogen fluid lately??? lol
easy mistake....others have made worse confusions (mostly me lol)
This post has been edited by devilsden97: Jun 23, 2006 - 7:21 PM
Kawi Love
post Jun 23, 2006 - 11:30 PM
azian_advanced
Joined Apr 18, '05
From Calgary
woops... my bad. i didn't even read what it said on the plastic before making the assumption that it was the power steering reservoir.
thanks for clearing that up.. all i know is it's some kinda reservoir..
and Gary you're right, critical parts shouldn't be risked in order to make things fit..
so i think i'll put a couple washers beneath the strut bar to lift it a little? anybody want to make a suggestion to this?
it's just touching it but not bent over completely.. it's fine as it is now but if it flexes inwards by more than an inch, then maybe i'll have some problems.. but i truly doubt that'll happen.
post Jun 23, 2006 - 11:40 PM
WH95TE
Joined Jun 16, '06
From Plantation, FL
My car doesnt even have one of those bars kindasad.gif Should I get one?
post Jun 23, 2006 - 11:45 PM
devilsden97
Joined Jun 13, '05
QUOTE(WH95TE @ Jun 24, 2006 - 12:40 AM) [snapback]448297[/snapback]
dude its because u have an ST lol
Gt's came with a factory strut bar (as shown in the second picture under the A'pexi one)
St's did not. You can find gt ones for cheap.
Kawi Love
post Jun 23, 2006 - 11:47 PM
WH95TE
Joined Jun 16, '06
From Plantation, FL
QUOTE(devilsden97 @ Jun 23, 2006 - 11:45 PM) [snapback]448301[/snapback]
I know smile.gif That's why im asking if I should get one lol. Like is it even worth it?
post Jun 23, 2006 - 11:48 PM
snapshotgt
Joined Oct 12, '05
From Texas
Not ALL GT(s) years came with braces -- i think 98-99 they stoped putting them on...
~snap
post Jun 23, 2006 - 11:50 PM
devilsden97
Joined Jun 13, '05
QUOTE(snapshotgt @ Jun 24, 2006 - 12:48 AM) [snapback]448303[/snapback]
~snap
i stand corrected
Kawi Love
post Jun 24, 2006 - 12:31 AM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE(WH95TE @ Jun 23, 2006 - 11:40 PM) [snapback]448297[/snapback]
that depends on how you drive.. the more aggressive you drive, the more you can feel the difference...
do you want my stock one? errr... first, do STs even have the two holes on the firewall for where the stock bar bolts to?
This post has been edited by azian_advanced: Jun 24, 2006 - 12:33 AM
post Jun 24, 2006 - 11:21 AM
celicasteve
Joined May 20, '06
From deltona, fl
yes they do, tapped and everything. Theres just black cirlces on them
Steve
If Columbus was told, "use the search function," he would have learned that the World was flat.
post Jun 24, 2006 - 11:33 AM
WH95TE
Joined Jun 16, '06
From Plantation, FL
Yeah they have the holes for the front and rear bar.
post Jun 24, 2006 - 12:55 PM
Tech9ine
Joined Jun 28, '05
From MB, Canada
are you getting rid of your stock one cheap azn? I may take it from you, considering i'd jump on anything thats actually local for a change.
post Jun 25, 2006 - 8:36 PM
azian_advanced
Joined Apr 18, '05
From Calgary
^^ yeah sure.. it beats having to ship it out. especially for something that's large and isn't worth much $$$.
PM me an offer..
Lo-Fi Version Time is now: November 27th, 2024 - 4:24 PM
