sticky still confuses me, tranny |
Jun 28, 2006 - 10:40 PM |
Enthusiast Joined Oct 4, '03 From CENTRAL, NY Currently Offline Reputation: 0 (0%) |
Ok, i know there is a sticky on this but i am still confused. I did the 3sgte swap and used my 5s tranny. all was well but now the diff bearing is shot and i guess i might as well swap the tranny. my friend has a 91 mr2 with a 5s in it , what will i need to do to put this tranny into my celica and make it work. I know it bolts to the engine but what about cables, axles , ect. ..... will it work , sorry to make anyone repeat this headache, just lost
-------------------- [img][http://memimage.cardomain.net/member_images/12/web/516000-516999/516799_123_full.jpg/IMG]
Jun 29, 2006 - 10:17 AM |
Enthusiast Joined Jun 21, '06 Currently Offline Reputation: 0 (0%) |
QUOTE(CELICAKIDD324 @ Jun 28, 2006 - 10:40 PM) [snapback]450206[/snapback] my friend has a 91 mr2 with a 5s in it If it's the same transmissioin, shouldn't it be a direct swap? Why is your friend giving you his transmission, even if there's something wrong with it you might be able to scrap parts from both tranx (yours and his) and be able to make one working transmission. Also when you swapped in the 3SGTE did you do any beafing up of the tranx? Because the 5s was built with 130bhp in mind while your new engine is putting out +260bhp. |
Jun 29, 2006 - 10:29 AM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
The Trannies can take a punch. Manny (presure2) is pushing 235 hp on a 200K miles 5S tranny. And Defgeph 240+ whp on a 3S-ge tranny. Im also running 255bhp on a 3S-GE now for almost 2 months with no problems.
But the shiftingcables are ment to be the other way around on a MR2 since the engine is placed in the back instead of the front. This post has been edited by Kadett: Jun 29, 2006 - 10:30 AM -------------------- JDM Powerplant installed, BPU coming very soon!
Jun 29, 2006 - 11:56 AM |
QUOTE(Kadett @ Jun 29, 2006 - 10:29 AM) [snapback]450342[/snapback] The Trannies can take a punch. Manny (presure2) is pushing 235 hp on a 200K miles 5S tranny. And Defgeph 240+ whp on a 3S-ge tranny. Im also running 255bhp on a 3S-GE now for almost 2 months with no problems. But the shiftingcables are ment to be the other way around on a MR2 since the engine is placed in the back instead of the front. I thought he had at least upgraded his clutch, and if he hasn't he should consider it. |
Jun 29, 2006 - 12:55 PM |
Upgrade your Clutch is a smart thing to do. I took the risc of putting a new OEM 3S-GE clutch in it when swapped. Holding all the (still stock) gte power with no problems. Maybe the wear will be more then with the normal engine on it but hey thats fine by me.
Jul 6, 2006 - 3:45 PM |
Ok, so using the mr tranny sounds like too much of a headache, what happened was my diff bearing in my current tranny is shot. i assume that you must crack the tranny apart to change this and figured i might as well just put a rebuilt tranny on there rather than just changing out the bearing, seams to me that the rebuilt tranny will be the easier way to go. I just dont have time to make this complex. anyone know where i can get a used 5s tranny 5 speed manual. any good cheap sites out there? also if the diff bearing is a easy fix let me know, especially if there is way to get the bearing out and replaced without having to move or remove the 3sgte , not looking forward to this.
Sean ps its been a while for me, whats the tranny called , cant see it on there -------------------- [img][http://memimage.cardomain.net/member_images/12/web/516000-516999/516799_123_full.jpg/IMG]
Jul 6, 2006 - 3:48 PM |
are asking for a tranny code?
if so i believe its "S54" i think |
Jul 7, 2006 - 12:02 PM |
yep i need the tranny code and where the cheapest place to get a rebuilt would be , or does anyone know how involve changing the diff bearing would be and if there is way to do it without removing the entire tranny?
Jul 19, 2006 - 8:51 PM |
refresh
Jul 19, 2006 - 11:43 PM |
QUOTE(CELICAKIDD324 @ Jul 7, 2006 - 5:02 PM) [snapback]453055[/snapback] yep i need the tranny code and where the cheapest place to get a rebuilt would be , or does anyone know how involve changing the diff bearing would be and if there is way to do it without removing the entire tranny? You HAVE TO pull the tranny out to open the diff... and yeah... it's hard if you don't know what you're doing, and you can perma screw up if you don't know what you're doing... Oh... and n/a MR2's have the same tranny as the Celica GT's... except of course the shifter bracket... -------------------- "It's ok to be naked girl... I'm an artist!"
Lo-Fi Version | Time is now: November 23rd, 2024 - 9:04 AM |
