> GT-4 4WD to RWD, Is it possible??
post Jun 30, 2006 - 4:11 AM
MadManInABox
Joined Nov 1, '05
I know this might seem an odd thing to do, but I was wondering if it is possible to disengage the drive to the front wheels on a GT4, sending all the power to the rear wheels.
Ive searched throught the forum and cant seem to find any info on this
Any info would be good, whether it can or cant b done...
Replies (1 - 16)
post Jun 30, 2006 - 4:26 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
I would think no, unless you put in a mr2 tranny and made custom mounts to mount the engine the other way. you would pretty much need custom everything, pull you would need to cut out your firewall i would think. Even if you just got rid of your front axels you would still get the same power to the back wheels. not worth it. why would anyone not want awd?
post Jun 30, 2006 - 4:33 AM
MadManInABox
Joined Nov 1, '05
QUOTE(CheesyLobster @ Jun 30, 2006 - 9:26 AM) [snapback]450696[/snapback]
Thanks 4 the advice, gonna keep researching it tho...
Its easier to drift with rwd than with awd
A futher question: Is the GT4 4WD or AWD??
post Jun 30, 2006 - 4:47 AM
Insanity-74
Joined Jan 9, '05
From Under the car
There is a lever on the back of 165 gearboxes where you can switch the drive between front wheel drive, rear wheel drive and all wheel drive....used for MOT brake tests...not advisable to use for long, but I`m sure you could rig something!!!
GT4`s are all wheel drive - AWD
post Jun 30, 2006 - 6:49 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Possible yes... but if you have to ask this question... chances are you can't do it. AND... what for? Don't say drift unless you got PLENTY PLENTY of track experience...
post Jun 30, 2006 - 7:02 PM
nik
Joined Sep 30, '02
QUOTE(Kwanza26 @ Jun 30, 2006 - 4:49 PM) [snapback]450873[/snapback]
YEAH Rhys Millens company makes a kit for the evo's to convert to rwd from awd
post Jun 30, 2006 - 7:50 PM
creamed_corn
Joined Oct 30, '05
QUOTE(CheesyLobster @ Jun 30, 2006 - 4:26 AM) [snapback]450696[/snapback]
Why would anyone not want AWD? All-Wheel Drive is terribly ovverated in my opinon. Sure, it grips well off the line and in corners, but it eats your horsepower at cruising speeds and has a tendency to understeer in most conventional setups (not as bad as FWD mind you). I would much rather have a RWD platform with a good traction and stability control for adverse conditions. That way the front wheels are freed up and can do what they are meant to do--steer; lightly and precisely.
Of course this is a Celica board and a lot of the kids on here are bound to buy into the "GT4 is God" hype.
This post has been edited by creamed_corn: Jun 30, 2006 - 7:50 PM
post Jul 2, 2006 - 12:01 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(creamed_corn @ Jul 1, 2006 - 12:50 AM) [snapback]450878[/snapback]
Not everybody goes to the track... most people here have probably never really raced... so there is no problem besides curiosity, and in some cases... pipe dreams. I do agree AWD is overrated and a bit worshipped round here... but RWD isn't that great either. Each has its own advantage and disadvantage... and just because the new cool scene is the drift scene... doesn't make FWD cars any less cool than RWD cars.
post Jul 4, 2006 - 8:45 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Was done with a fifth-gen All-trac, had to in order to free up enough space in the engine bay for the Lexus SC/GS400 V8 with twin turbos this Aussie sandwiched in there.
Damned impressive burnouts, but I don't know how it handles.
post Jul 4, 2006 - 8:50 PM
Rayme
Joined Feb 18, '06
From NB, Canada
Doing it the guerilla way.....don't you just need to weld together the center diff and disconnect the front shafts?
-Rémy
02 SiR, 08 250R
post Jul 4, 2006 - 9:04 PM
Sammyr
Joined Mar 28, '05
From Dunedin, New Zealand
To my knowledge, 4wd cars will tend to have a bias to either ff or fr (correct me if i am wrong) so welding diffs will pontentialy cause loads that the system is not designed for, to do it properly you would have to swing the engine around 90 degrees put in a new gear box, drive shaft and diff, fabricate a new transmission tunnel to accomidate the drive shaft/ gear box and that isnt even touching on suspension set-ups, it would be a big job but would be well cool if someone was to do it!
post Jul 5, 2006 - 4:10 PM
uberschall
Joined Jul 29, '03
From north of detroit
the rwd cradle from an awd car (like a gt4) would bolt right up....but the torque split would present issues. you'd really have to get a rwd donor car (a lexus or older supra, maybe?) and use a different motor arrangement and trans. the transverse front arrangement with an awd trans would suck something awful. i'm of the mindset that unless you have unlimited funding, you should leave it fwd or swap the whole gt4 driveline and use the awd. besides, if you're looking to build a REAL drift car, it's not going to be streetable anyway, so you'll also have to invest in another daily ride.
do you know who i am, mr. worley?
post Jul 6, 2006 - 6:57 AM
b1gr3d
Joined Feb 25, '03
From Springfield, MO
while you'r making RWD just do a 1z or 2z swap at the same time..
Coming in 2010
post Jul 6, 2006 - 9:40 PM
trd94
Joined Jan 9, '05
From green springs ohio
i wuold think it would work, the are doing it in japan to evo & subies all the time to use them for drifting,
post Jul 7, 2006 - 3:53 AM
MadManInABox
Joined Nov 1, '05
Wat about altering the diff to be more rear wheel bias??
post Jul 7, 2006 - 4:08 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
shouldnt drift an AWD car anyways, becuase all 4 wheels are supposed to spin together. "drifting" throws this off, and cuases the differential to burn out. This is why you can only tow an AWD car on trailer or rollers. And why make a GT4 a rwd to be a drift car anyways. Considering that the price of a GT4 is already greater than that of a s13, ae86, fc, or you could even find like a 93 sc300 for cheaper. It would just be easier, cheaper, and in the end have a "better" drift car just becuase of the better aftermarket drift applications for those cars. But if were just wondering if it is possible to make the GT4 RWD, then yes it is. The main problem is if it is actually worth it or not.
post Jul 7, 2006 - 10:32 AM
team_omega
Joined Aug 14, '05
From St. Paul, MN(USA)
here is your answer....but with a v8....dont know the mods to this car though..
http://www.youtube.com/watch?v=5C0veAb-CiM...ch=rwd%20celica
6 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 12th, 2025 - 2:13 PM
