> Intercooler
post Jul 6, 2006 - 7:32 PM
ToysRfast
Joined Dec 11, '05
From MN, Rochester
I'm looking for a intercooler for my 3sgte swap anyone recommend anything? I have 700$
Replies (1 - 19)
post Jul 6, 2006 - 7:41 PM
pshh if you have 700$ on just an intercooler get a SPEARCO its the best one out there IMO and flows better then greddy!
post Jul 6, 2006 - 9:19 PM
i have a spearco ... seems to work well for me. it was only about 300 on ebay.
post Jul 7, 2006 - 12:11 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
my next intercooler. One sided to keep the intercooling pipes away from the hot side of the exhaust / manifold and should make for a better more efficientt route. bar and plate
Core Dimensions: 600mm X 300mm X 76mm
Overall length of 770mm
All TIG Welded 6061 Aluminum, polished end tanks
100% Vacuum Brazed Core
High Efficiency Bar & Plate Construction
2.5inch Inlet and Outlet
Max Recommended PSI: 45psi
Low pressure drop w/ only 0.2psi at 15psi of boost
Tested CFM: 1020 CFM
i doubt one brands Bar and plate cools more than another brand so.
i mean how can you screw up sheets of folded aluminum.
under $200 for it also.
Heres a link.
post Jul 7, 2006 - 12:55 PM
why would you want a one sided one? its going to be tricky as hell to route the piping all to one side.
if you want to keep your piping cool from the exhaust manifold, just use some heat wrap.
post Jul 7, 2006 - 2:11 PM
didn't you ever read the thing on MR2oc about heat wrap...its bad from wat i gathered...
one sided is the way i'm going to go to john its a great idea and the pipes are actually really easy to run...
post Jul 8, 2006 - 2:42 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
QUOTE(playr158 @ Jul 7, 2006 - 3:11 PM) [snapback]453106[/snapback]
sweet. yeah the pipes wont be an issue im also relocating the bat to the trunk
post Jul 8, 2006 - 7:33 PM
heat wrap isint good or bad. its all in how or where you use it.
i still dont understand the point of going to a one sided setup. if your looking for something clean and short, clock the trubo, then go from the turbo to the drivers side down, and from the throttle body to the passengers side. it would be a clean and simple setup.
This post has been edited by lagos: Jul 8, 2006 - 8:24 PM
post Jul 8, 2006 - 9:03 PM
yea, but, doing it that way, your really not shortening the piping at all.
post Jul 8, 2006 - 9:08 PM
QUOTE(presure2 @ Jul 8, 2006 - 10:03 PM) [snapback]453523[/snapback]
yeah but, neither would having the piping all run to one side.
post Jul 8, 2006 - 11:21 PM
you don't even need to relocate the battery just run the pipe up the fender in the same path as your stock intake
(i also plan for the 1 sided IC and piping run through the fender for reasons 1) cleanness of engine bay(including clocked turbo) and 2) side feed intake manifold)
This post has been edited by playr158: Jul 8, 2006 - 11:22 PM
post Jul 8, 2006 - 11:44 PM
pure_dx
Joined Dec 28, '05
From USA
QUOTE(lagos @ Jul 8, 2006 - 7:33 PM) [snapback]453511[/snapback]
ah, finally, someone who understands, you should talk to the guy in the other thread who wants to heat wrap his headers
post Aug 1, 2006 - 9:40 AM
FallenHero
Joined Dec 26, '02
From Alabama
guys, i am looking at an intercooler for a great price, but i don't know about sizes.
# Polished Finish Aluminum.
# All TIG Welded 6061 Aluminum.
# Overall Size: 32" x 12" x 3"
# Inlet/Outlet: 3"
# Max Recommended PSI: 30psi
# Pressure Drop at under 10%
that too big?
also available
Overall Size: 28" x 9" x 2.5"
Inlet/Outlet: 2"
This post has been edited by FallenHero: Aug 1, 2006 - 9:45 AM
post Aug 1, 2006 - 1:13 PM
CilverSeliST205
Joined Nov 3, '05
From Chicago Suburbs
QUOTE(ToysRfast @ Jul 6, 2006 - 7:32 PM) [snapback]452792[/snapback]
consider getting water-air IC, beefy pump, monster heat exhanger and 3-4 gallon tank. Less piping than any FMIC and possibly better efficiency... heat shield it if necessary, mix up your water wetter and your good to go smile.gif
QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback]
i dont drive fast, i just fly low
post Aug 1, 2006 - 3:02 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
i have your piping kit already to go! see the buying selling section. you might find some more intercooler info there too.. *hint hint*
post Aug 1, 2006 - 3:45 PM
jdg371
Joined Jun 14, '05
QUOTE(zipstrips @ Aug 1, 2006 - 4:02 PM) [snapback]464138[/snapback]
post Aug 1, 2006 - 4:41 PM
Magic
Joined Mar 30, '03
From Cyprus
You can ask for the GReddy Spec-M Intercooler (New 2-Layer Intercooler by Greddy).You can buy the Kit for the Nissan S15 which is the cheaper (beacuse its including just few pipes in the kit) and go for custom piping using that core.Average price for that kit i think its around 50,000Yen.
post Aug 23, 2006 - 9:35 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
QUOTE(x_itchy_b_x @ Jul 7, 2006 - 1:11 PM) [snapback]453060[/snapback]
Heres a link.
looks like its gunna fit..
post Aug 23, 2006 - 9:39 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
no crash bar?
anyways for 700$ id go the stock w2a setup..
quicker spool, cleaner engine bay, more oem.
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
**** the crash bar tongue.gif, i dont plan on crashing. its only a 5mph bar that thing is light weight.
Lo-Fi Version Time is now: February 25th, 2025 - 1:59 PM
