> Removing the interior dash components
post Jul 10, 2006 - 11:02 AM
KB-2
Joined Jul 6, '06
So...i want to paint all teh lil inserts in my car...the door hadles, the air vents, all that stuff.....but im not sure about how to take them off, without damaging anything...are there lil screws somewhere? or do i jsut like prop it off??
KB
Replies (1 - 10)
post Jul 10, 2006 - 12:48 PM
JFrost9
Joined Aug 27, '05
From Texas
The ones in the door are held with screws, the center one just pops off... but the clock will be attached. Ive never tried the air vents, but ive never seen screws for em either.
post Jul 10, 2006 - 1:19 PM
airvents just pop in and out
post Jul 10, 2006 - 9:14 PM
ShadowFX
Joined Jan 22, '04
From WA, Australia
There are clips holding in the passenger side air vent. I'm not sure how to actually unclip it, I just pulled really hard (broke one of the top clips but still goes back in with no problems, sits fine.)
post Jul 10, 2006 - 9:21 PM
KB-2
Joined Jul 6, '06
how do you remove the pannel w/ the power window buttons and door locks?
KB
post Jul 10, 2006 - 9:22 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
The center actually has 2 screws in it on the bottom. The piece around the shifter needs to be removed first, this piece is just held in by clips. removing this piece will reveal the 2 screws holding in the center. drivers and passenger side vents just pull out. eccept i was never able to get the passenger side vent out cuase i didn't want to break anything smile.gif
post Jul 10, 2006 - 9:26 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE(KB-2 @ Jul 10, 2006 - 7:21 PM) [snapback]454302[/snapback]
you have to remove the door panel for that. First remove all the screws. there should be like 4 or 5 i can think of right now including the one in the interior door handle. Look under the door and around the rear of it. there should be black clips. Push those in and then pop them out. that should be it i think.
after you remove that then there should be one screw that needs to be removed to get the panel you are talking about off.
post Jul 10, 2006 - 9:38 PM
KB-2
Joined Jul 6, '06
ohhh allright thanks alot !
KB
post Jul 11, 2006 - 5:48 AM
ShadowFX
Joined Jan 22, '04
From WA, Australia
QUOTE(MaskedMan @ Jul 11, 2006 - 10:26 AM) [snapback]454310[/snapback]
What I did was just slip a very thin screwdriver under the side of the panel. Then slide the screwdriver down to the bottom of the panel, and then pop it up from the bottom.
post Jul 11, 2006 - 12:42 PM
x2
post Jul 11, 2006 - 4:47 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
oh there's no screw? shoot sorry my bad then, i thought there was... kindasad.gif
Lo-Fi Version Time is now: November 30th, 2024 - 3:43 PM
