> oil leak and clutch adjustment..., god so close to being freakin 100% done.. BLARGH!
post Jul 19, 2006 - 8:30 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
ok so i have minor problems now in my car, the high pressure line is leaking oil, and i think its from th same place as always but im not 100% sure..
the part where it comes out of the big banjo bolt as hard metal and then hits the rubber piece and the rubber piece is clamped on i think is leaking, i added a third clamp to the middle and made sure to tighten the other clamps and it seems to work for a couple days and then it starts leaking again. (this has happened twice now)
also if i try to launch my car revving it up in first gear makes the car slowly creep forward even with the clutch to the floor, and it shifts hard when i am high in the rpms (if im driving like a grandma it shifts fine) i thought this meant i needed to bleed it but i have bled it a few times and it hasnt improved so does this mean i need to adjust the clutch?
thanks for anyone who answers on either account..
Lo-Fi Version Time is now: February 22nd, 2025 - 4:25 AM
