Normal Operating Range for Gauges, Help me choose gauges. |
Aug 4, 2006 - 2:59 PM |
Enthusiast Joined Mar 29, '06 From Regina, SK, Canada Currently Offline Reputation: 38 (100%) |
Well I am not exactly sure where this topic should fall. I was originally thinking electrical, then maintenance, but I decided to put it under Forced Induction since I figure only people running a turbo go through the trouble of installing guages, especially a boost!
So I have been searching and searching gauges across the net and there are so many different ranges on them. I have seen EGT gauges that have a max of 1200F and some that have a 2400F max, so I was hoping that all of you running turbos could give me what your normal operating range is and what the max I should get would be. Also if you could state if its a 3SGTE or a 5SFTE that would be great. I am planning on building a 5SFTE so that is what I am most interested in, so once again Manny I am hoping to get an answer from you. Thanks in advance! Of course all others I am hoping to get your feedback! So basically let me know all of your gauges, oil pressure, boost, egt, oil/water temp, etc. Not saying I am getting all the gauges but thought it would be nice to know. Thanks. David This post has been edited by WALKER: Aug 4, 2006 - 3:00 PM -------------------- |
Aug 4, 2006 - 3:12 PM |
the 1200* ones your seeing are more than likely in celius.
13.6@108MPH, 5SFTE Powered |
Aug 4, 2006 - 3:16 PM |
QUOTE(presure2 @ Aug 4, 2006 - 2:12 PM) [snapback]465524[/snapback] the 1200* ones your seeing are more than likely in celius. I was kind of thinking that the 1200 would be in C and the F was a typo. It would make sense. Do you know what your normal operating range is on your gauges, or do you have to wait until you have the car and check it when your in it? -------------------- |
Aug 4, 2006 - 3:22 PM |
it all depends on my right foot.
Aug 5, 2006 - 12:58 PM |
I guess I have never had a vehicle with gauges that monitor temperatures or pressures. Do they vary quite a bit?
How do you know when the temp or pressure is too high/low? That is sort of what I am looking for eventually. Once I get gauges I would want to know what is normal so I would actually know if I was operating too low/high. -------------------- |
Aug 5, 2006 - 9:50 PM |
Enthusiast Joined Nov 7, '05 From Brisbane, Australia Currently Offline Reputation: 0 (0%) |
i'd recommend an oil pressure and oil tempurature gauge for any car with mods done, just to be safe.
boost is optional, as they come on avcr's and most electronic boost controllers these days, it's not 100% necessary. otherwise, i've got oil press, oil temp & air/fuel ratio.... hope that helps. max |
Aug 7, 2006 - 3:09 AM |
Enthusiast Joined Jan 16, '04 From sydney australia Currently Offline Reputation: 0 (0%) |
Water Temp is a good idea as well....
-------------------- 312whp with more to come.... |
Lo-Fi Version | Time is now: November 23rd, 2024 - 9:26 PM |
