> 17x8.5 GramLight fitment on a celica +48 offset, Please help I tried reading the sticky, still not sure
post Aug 10, 2006 - 3:00 AM
eggman40
Joined Aug 17, '04
From California
Sorry to bring up an old topic but even after reading the sticky im still confused about offset and fitment. I promise to study more on it. smile.gif I want to pick up a set of Gram L. 57s rims that are 17x8.5 with +48 offset. I wanted to know if these would fit normally or if i would need some spacers for them? my car is lowered quite a bit but its adjustable so i could compensate. Any help would be greatly appriciated. thank you!
ps. and yes this guy is local (stupid paypal) ...ranting, sorry
Replies (1 - 3)
post Aug 10, 2006 - 12:45 PM
Kadett
Joined Mar 17, '05
From The Netherlands
With 8,5 width I dont think you would clear the shocks. I think a 15mm spacer would be sufficient.
Check the next site where you can calculate the difference between your current setup and what you want to place.
http://marksink.com/tire_wheel_offset/offset.html
With a 15mm spacer (effective 33mm offset) it would be
The clearance from stut housing to the inside of the wheel will be 17mm LESS
The outside edge of the wheel will EXTEND an extra 21mm
post Aug 10, 2006 - 1:00 PM
eggman40
Joined Aug 17, '04
From California
QUOTE(Kadett @ Aug 10, 2006 - 5:45 PM) [snapback]467448[/snapback]
thanks for the help kadet, this will help for sure.
This post has been edited by eggman40: Aug 10, 2006 - 1:01 PM
post Aug 20, 2006 - 11:20 PM
dans_st
Joined May 24, '03
From Andrews TX
I don't know if it will help any but I have some Axis Hiro 19x8.5" rims with 245/35/19 toyo T1-S Proxes with a 35mm offset and Tein S-techs
and when I hit a dip of a low slope in the road going over 45 mph my tire rubs on the inside of the wheel well in the rear, and on the outsid eof the tire(rear) I can barely even put a finger(pinky) between the tire and fender.
So I thyink that 35mm offset is perfect.
if you go 33 I think you would be hitting alot worse, and 38mm would rub on the fender.
I know that there is alot of difference between a 19 and a 17, but they are the same width and I thought that this might help
-Daniel
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
Lo-Fi Version Time is now: February 22nd, 2025 - 2:33 PM
