> Throwing out an Idea...., Custom sub enclosure
post Aug 10, 2006 - 5:35 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
So I was thinking today. Thinking about if and when I get around to upgrading from the stock sound system where I would put the subs. Then I got to pondering on this idea... Swap out the air cylinders that hold the hatch up for a stronger set, reinforce the hatch tray somehow, and mount a sub box to the under side of the hatch tray. This way you can open up the back and your subs would be pointing right out of the back..
Does that make sence? Kind of like how the Axis tC lifts the TV in the back...
Thoughts?
This post has been edited by 95CelicaST: Aug 10, 2006 - 5:35 PM
**** Photobucket
Replies (1 - 5)
post Aug 10, 2006 - 6:05 PM
vsideboy
Joined Mar 29, '06
From Hull, UK
You would probably need high torque linear actuators to lift the lid AND a sub+box.
Doubt you would find any boot strutts powerful enough to hold it all up TBH. My bootlid closes itself if the wind catches my spoiler and both strutts are working correctly.
Just my opinion though, maybe someone will contradict.
Subs work best when they are securely mounted, so I also think it may sound a bit bab being stuck to the lid.
post Aug 12, 2006 - 3:41 AM
Wouldn't you want your subs pointing up, rather than down at the floor, and inside the car when the hatch is lifted, rather than outside?
post Aug 12, 2006 - 2:39 PM
JFrost9
Joined Aug 27, '05
From Texas
Seems like alot of work, for not a great result. Not to mention all the rattle fixing you would have to do with your hatch...
post Aug 25, 2006 - 10:37 AM
Dm_Vinny
Joined Apr 4, '05
QUOTE(vsideboy @ Aug 10, 2006 - 7:05 PM) [snapback]467569[/snapback]
Agreed... First the linear actuators would be expensive.
Second, think about the vibration your going to put on your hatch, you know what nevermind the hatch think of the glass! I bet it wouldnt last too long.
post Aug 27, 2006 - 2:31 AM
Celica power
Joined Mar 16, '05
From Netherlands
dont forget the kg of the subs there are extreme about 10 kg each
Lo-Fi Version Time is now: February 13th, 2025 - 6:09 AM
