> compression test
post Aug 11, 2006 - 8:55 PM
4wheelWOnder
Joined Jan 1, '05
From rapid city, SD
whats a compression test?
Replies (1 - 1)
post Aug 11, 2006 - 9:04 PM
alltracman78
Joined Aug 9, '06
From Ma
You check the pressure the piston creates in the combustion chamber with a guage that is threaded into the spark plug hole.
It can tell you if you have a leak somewhere in the chamber, like worn rings or a bad valve.
Lo-Fi Version Time is now: November 27th, 2024 - 8:54 AM
