> Need help !
post Aug 13, 2006 - 1:30 PM
Culpable04
Joined Apr 17, '06
From New Jersey
when I installed my wheels the guy at the shop put the nuts in such a nice way that messed up the bolts, so now I need to change them the problem is that one of the bolts is turning with the nuts so I would like to know if some of you have any experience on this and if you know any trick, I don't wanna damage my wheel during this process.
Replies (1 - 11)
post Aug 13, 2006 - 3:47 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
QUOTE(Culpable04 @ Aug 13, 2006 - 11:30 AM) [snapback]468528[/snapback]
If the lugnut is turning with the bolt, then it broke. just remove the bolt and pray the none of the others are damaged. i have been riding with 4 bolts and haven't had any problems. i believe you'll need your wheel hub replaced if you want all 5 or you can see if a shop will be able to press another bolt into your hub. this happened to me before. lol.
post Aug 13, 2006 - 5:00 PM
laff09
Joined Jul 28, '06
From Delaware
Or you can buy a new wheel stud for 1.49 at pep boys, along with a big ass hammer and do it yourself
post Aug 14, 2006 - 11:54 AM
Culpable04
Joined Apr 17, '06
From New Jersey
thanks but the situation is this, the bolt and the nut are turing together when I try to take the nut off, so right now I can't removed my wheel, I have the wheel stud but in order to install new ones I need to get that one out. how do I do that with out damaging the wheel ?
post Aug 14, 2006 - 12:52 PM
they stripped the stud in the hub, take it back and make THEM fix it. this is caused by using an impact wrench to tighten your lugnuts down, which is horrible! after they fix it never go back to that shop.
post Aug 14, 2006 - 1:21 PM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
^ Agreed
post Aug 14, 2006 - 1:53 PM
Culpable04
Joined Apr 17, '06
From New Jersey
I went back to them and they said they'll fix it but they don't wanna be responsible for the wheel. they said their policy doesn't compesate for aftermarket parts which is BS cause they installed it, but if I can take it out myself I'll do it cause I don't want them to ruin my wheel. and in order for me to force them to pay for it I would have to go to court and I don't have the time needed for that.
just feel like burning the F****ing place down.
post Aug 14, 2006 - 9:03 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(Bitter @ Aug 14, 2006 - 12:52 PM) [snapback]468844[/snapback]
Um no?
Well, sorta.
If they did it, they should be the ones fixing it.
But I highly doubt a impact stripped the teeth [I'm not talking about the threads, I'm talking about the teeth that lock the stud to the hub].
I have NEVER seen an impact do that. I have seen guys hammer away with an impact til the nut won't turn at all [I dont' do this]. I've seen steel wheels with the steel around where the nut seats almost cut away from repeated abuse, but I've never seen the teeth stripped from an impact.
post Aug 15, 2006 - 1:00 AM
DEAMON
Joined Jun 10, '06
From USA CO . AURORA
i have seen this happend befor but it could be from rust kindasad.gif but i cant see it so i cant say for shure
where did u go ?
post Aug 15, 2006 - 1:08 AM
QUOTE(alltracman78 @ Aug 14, 2006 - 9:03 PM) [snapback]469059[/snapback]
Um no?
Well, sorta.
and ive seen a good strong impact strip them. its usually not the 'teeth' that strip, but the metal the surround the 'teeth' in the hub, since that steel is softer than the stud.
and the shop is resposible, if they wont fix it then get it fixed and have your laywer deliever the bill to them.
post Aug 18, 2006 - 10:38 AM
laff09
Joined Jul 28, '06
From Delaware
If they install aftermarket parts, then they ARE responsible for any damages incurred during the installation. Small Claims Court 4tw.
post Aug 18, 2006 - 12:49 PM
Culpable04
Joined Apr 17, '06
From New Jersey
my friend and I got it out without major damage to the wheel and my friend sent the bill to them, he's charging them for the wheel hub and hub studs, so we'll se their response. I pay a lawyer insurance at my job, so doesn't cost me anything to send a lawyer to court. smile.gif
Lo-Fi Version Time is now: February 20th, 2025 - 3:12 AM
