![]() Enthusiast ![]() Joined Aug 15, '06 From MICHIGAN Currently Offline Reputation: 1 (100%) ![]() |
Can anyone tell me where the best place to mount an aftermarket amp is? I would like to put it somewhere visible if thats possible, and it snows where I'm from, so I cant really put it under the seat. Please include pics if thats possible... Thanks!
FYI. The amp is for two 10" kicker subs |
![]() Enthusiast ![]() ![]() Joined Mar 16, '05 From Netherlands Currently Offline Reputation: 4 (100%) ![]() |
Back seats
![]() Side trunk ![]() -------------------- |
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) ![]() |
Mount it to the box. Check my prrofile for a pic. Let me know if you need more.
It is a 1200 watt amp, about 2.5 feet wide, and I made a couple custom alminum brackets to bolt the amp up to. The hard part was angling them so the amp would look good. I bolted these right up to the box. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) ![]() |
I mounted mine on the floor. Easy to get to for controls and can breathe..
![]() -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 27, '05 From Texas Currently Offline Reputation: 0 (0%) ![]() |
damn celica power, is that your trunk? What did you make that floor out of?
-------------------- ![]() I am now a part of the ihavemorethen16gc club! |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '04 Currently Offline Reputation: 5 (100%) ![]() |
QUOTE(Celica power @ Aug 15, 2006 - 12:55 PM) [snapback]469239[/snapback] Back seats ![]() Side trunk ![]() That is an amazing setup! |
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) ![]() |
mount it somewhere the amp can breathe, as stated above... dont want to fry anything... i just took off my hatch cover and mounted on top of the box, gets plenty of air
okay, Ill probably put it on the back seat, Because someone told me that he mounted his amp to the box and it rattled one of the components loose in the amp, I dont know if thats true or not.
-Thanks |
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
One of mine is bolted under the rear deck. The other is inside the panel next to the backseat where the rear speaker would normally be. Both are out of the way, both have been there for a while, and both still function perfectly.
QUOTE(JFrost9 @ Aug 15, 2006 - 12:28 PM) [snapback]469259[/snapback] damn celica power, is that your trunk? What did you make that floor out of? The floor is made of mdf whit leather QUOTE(gt_driFFter @ Aug 15, 2006 - 12:34 PM) [snapback]469261[/snapback] QUOTE(Celica power @ Aug 15, 2006 - 12:55 PM) [snapback]469239[/snapback] Back seats ![]() Side trunk ![]() That is an amazing setup! 1000 watt woofers And a voodoo capacitor 2.5 varad -------------------- |
Yesterday I got my amp in the mail and I really went out and did some looking for the right spot to mount it, but I found that the material around the side of the trunk and back of the trunk were probably to flimsy to mount it to. Since my car is a convertible I cant get to the back of the seat, because the place where the top folds down into is in the way. I was thinking the side of the box might be good, if you have any advice or opinions please let me know. The box is factory sealed.
-thanks This post has been edited by aslearvert: Aug 22, 2006 - 9:49 AM |
![]() Enthusiast ![]() ![]() ![]() Joined Jul 20, '06 From St. Thomas, Virgin Islands Currently Offline Reputation: 0 (0%) ![]() |
eek...that sucks, I was gonna say the back of the back seat, mostly because thats where mine is (i just put the backseats down while I'm driving, I didn't want to ditch the hatch cover cuz I wanted to be able to hide everything when I park up).
I've seen them mounted to the box, never did it myself though... -------------------- ![]() "I bet you drive a standard." "You could make some money off that bet." :D |
I've mounted three different amps directly to boxes, and all of them are still alive and kicking today.
Yeah I cant find anywhere else to put it so im going to mount it on the top of the box. Anyways... not to get off subject, but, I had the amp and subs all the way hooked up, I used an extremely overpriced rockford fosgate wiring kit that I bought at best buy, I go to try it out and I realize there is no fuse in the fuse holder thats built into the power line, so i thought that they probably put it in the kit. NOPE, None of the fuses in the kit fit. Has anyone else experienced this problem, what fuse do I need? HELP!!! Is it possibly an ANL fuse. Another thing is with the deck I have, Sony Explode (installed by Best Buy), There are six RCA connections in the back of the deck. 2 for rear out, 2 for front out, 2 for BUS in, they had the rear speakers hooked up to the rear out, we had to unhook these to put the sub in, but i still want to use my rear speakers, how do I do this? Also, thanks for helping me out already, I appreciate it.
(The link is the wiring kit) http://www.bestbuy.com/site/olspage.jsp?sk...d=1134701342243[/url] This post has been edited by aslearvert: Aug 23, 2006 - 8:47 AM |
QUOTE(aslearvert @ Aug 23, 2006 - 8:11 AM) [snapback]471924[/snapback] Yeah I cant find anywhere else to put it so im going to mount it on the top of the box. Anyways... not to get off subject, but, I had the amp and subs all the way hooked up, I used an extremely overpriced rockford fosgate wiring kit that I bought at best buy, I go to try it out and I realize there is no fuse in the fuse holder thats built into the power line, so i thought that they probably put it in the kit. NOPE, None of the fuses in the kit fit. Has anyone else experienced this problem, what fuse do I need? HELP!!! Is it possibly an ANL fuse. Another thing is with the deck I have, Sony Explode (installed by Best Buy), There are six RCA connections in the back of the deck. 2 for rear out, 2 for front out, 2 for BUS in, they had the rear speakers hooked up to the rear out, we had to unhook these to put the sub in, but i still want to use my rear speakers, how do I do this? Also, thanks for helping me out already, I appreciate it. (The link is the wiring kit) http://www.bestbuy.com/site/olspage.jsp?sk...d=1134701342243[/url] ![]() I have the same wiring kit -------------------- |
Okay well... I figured out the fuse thing, it is the 100 amp fuse that comes in the kit, but last night I was up really late and didnt see the cutout in the side of the fuse holder (HAHA) but with the speaker thing, i think best buy messed up the install of the deck, because the front speakers are trying to come out of the subs is what it sounds like, and for some reason they already had the REM cable hooked up.
![]() Enthusiast ![]() ![]() Joined Aug 20, '06 From Kissimmee Currently Offline Reputation: 0 (50%) ![]() |
QUOTE(Celica power @ Aug 15, 2006 - 11:55 AM) [snapback]469239[/snapback] Back seats ![]() Side trunk ![]() !!!!!!!!how can i do something like that, it looks amazing |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) ![]() |
I don't know about other people, but I had a sony x-plode amp hooked up and hanging behind one of the back seats. You can't really see it entirely but you can tell it was an AMP.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) ![]() |
depending how big ur amps are.. u could try putting it on the floor of the front passenger seat (since it's kinda deep) and make a false floor to cover it?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) ![]() |
what ever you do, if you have a heavy amp..dont mount it to the back seat's back....i found that out the hard way. Now the cover on the back seat is fallin off.
Lo-Fi Version | Time is now: February 13th, 2025 - 1:48 AM |
