7A intake new bling doesn't work, 94 and 97 chamber covers won't easily interchange |
Aug 20, 2006 - 10:20 AM |
Enthusiast Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
I have a polished intake for a 7a but it is 94-95. Everything appears to
be the same as far as bolt pattern and hose connections go. The basic shape is different. I was just wondering if they will interchange. This post has been edited by 97lestyousay: Mar 19, 2007 - 6:23 PM -------------------- JDM guy made me do it.
Aug 21, 2006 - 2:42 PM |
QUOTE(97lestyousay @ Aug 20, 2006 - 8:20 AM) [snapback]470822[/snapback] I have a polished intake for a 7a but it is 94-95. Everything appears to be the same as far as bolt pattern and hose connections go. The basic shape is different. I was just wondering if they will interchange. they should be the corolla 7afe intake looks different than the 7afe 94,95 -------------------- yea your 3sgte is cool but ill stick to my 7agte
Nov 19, 2006 - 5:04 PM |
I hope they interchange OK I just did this this morning.
Nov 19, 2006 - 5:07 PM |
that looks SWEET man! good work!!
13.6@108MPH, 5SFTE Powered |
Nov 20, 2006 - 3:03 AM |
that looks incredible Randy, purely incredible. WOW !!!!
Nov 20, 2006 - 10:40 AM |
that does look sweet. +3 i like it.
Nov 21, 2006 - 11:40 PM |
Enthusiast Joined Oct 27, '05 Currently Offline Reputation: 0 (0%) |
great one...
Nov 22, 2006 - 11:36 AM |
Enthusiast Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
looks good Randy, but nobody answered your question lol
I'd say if the bolt holes line up it would be fine, can't hurt to try I guess -------------------- |
Nov 22, 2006 - 11:40 AM |
Enthusiast Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
should be ok !
but if it's not pass it dowm to me will be in good hands ps I'm serius about that, if it doens't fit let me know and I'll get it from you, I have a back pack full of pennies -------------------- |
Mar 19, 2007 - 6:14 PM |
It looks good but don't work. Everything lines up all hoses connect.
The underside is different the pcv inlet is in a different spot, and the housing itself is quite a bit different. Upon startup it revs to, I assume the limiter I shut it off before it hit 5000 but it was rapidly increasing, not quite WOT but close. I had my son check the throttle body and it never opened he said. so its pulling air from somewhere. I never threw a code at all. I tried it about 6 times removing the cover 3 times to check stuff with no luck. I put the 97 back on and it ran perfect no problems at all. The 94 manifold chamber is evidently quite a bit different than a 97. Anyone have any Ideas? -------------------- JDM guy made me do it.
Mar 19, 2007 - 7:50 PM |
Heres the problem. The port below isn't covered by anything other than the metal gasket,
on the 94 manifold that area is totally open and the gasket isn't held down by anything. Learn from my stupidity and don't try this. -------------------- JDM guy made me do it.
Mar 19, 2007 - 8:46 PM |
what is that port for? where does it go to?
you can't just cover it up with something? -------------------- |
Mar 19, 2007 - 8:51 PM |
Enthusiast Joined Oct 3, '05 From Houston, Texas Currently Offline Reputation: 12 (100%) |
yeah when I took my intake off mine would rev too, but it was because I left one of the bolts off from the egr valve.
Oh yeah I was looking at the inside of your intake manifold and it looks different than mine. This post has been edited by 94st_santos: Mar 19, 2007 - 8:54 PM |
Mar 19, 2007 - 9:00 PM |
QUOTE(Culpable04 @ Nov 22, 2006 - 11:40 AM) [snapback]504507[/snapback] should be ok ! but if it's not pass it dowm to me will be in good hands ps I'm serius about that, if it doens't fit let me know and I'll get it from you, I have a back pack full of pennies It's sad that it doesn't fit on yours after the effort you made for it. if you don't have a solution, I would take it from your hands. -------------------- |
Mar 19, 2007 - 9:06 PM |
QUOTE(hurley97 @ Mar 19, 2007 - 6:46 PM) [snapback]537833[/snapback] what is that port for? where does it go to? you can't just cover it up with something? It has dry carbon in it so the air in it has exposed to combustion, the 97 intake blocks it so blocking it at the port would probably fix it. I am just going to forget about it and maybe polish the 97 and engrave it or just forget the whole altogether since I plan to swap next year. -------------------- JDM guy made me do it.
Mar 19, 2007 - 9:09 PM |
QUOTE(Culpable04 @ Mar 19, 2007 - 7:00 PM) [snapback]537843[/snapback] QUOTE(Culpable04 @ Nov 22, 2006 - 11:40 AM) [snapback]504507[/snapback] should be ok ! but if it's not pass it dowm to me will be in good hands ps I'm serius about that, if it doens't fit let me know and I'll get it from you, I have a back pack full of pennies It's sad that it doesn't fit on yours after the effort you made for it. if you don't have a solution, I would take it from your hands. The manifold in your profile pic looks the same as my 97, is that the original motor? I figured it would be the same the polished 94 I have. -------------------- JDM guy made me do it.
Mar 19, 2007 - 9:27 PM |
it was my original motor I replaced that one with a 95 engine same year but stupid me didn't swap the red cover so now my engine bay doesn't look as clean
Mar 19, 2007 - 9:37 PM |
QUOTE(97lestyousay @ Mar 19, 2007 - 10:09 PM) [snapback]537848[/snapback] The manifold in your profile pic looks the same as my 97, is that the original motor? I figured it would be the same the polished 94 I have. you are right Randy, he has a 96+ intake mani cover on that * * Stevenson, you said the motor was replaced with another 95, correct ? I would guess it was a 7a from a Corolla, not a Celica hence the different intake mani cover (same year) -------------------- |
Mar 19, 2007 - 9:42 PM |
QUOTE(Batman722 @ Mar 19, 2007 - 9:37 PM) [snapback]537862[/snapback] QUOTE(97lestyousay @ Mar 19, 2007 - 10:09 PM) [snapback]537848[/snapback] The manifold in your profile pic looks the same as my 97, is that the original motor? I figured it would be the same the polished 94 I have. you are right Randy, he has a 96+ intake mani cover on that * * Stevenson, you said the motor was replaced with another 95, correct ? I would guess it was a 7a from a Corolla, not a Celica hence the different intake mani cover (same year) I'll take a look at my current manifold tomorrow morning and compare it to the pic here. but my guess is that the engine is from a corolla and that would explain why I don't have a sample port for the EGR temp sensor. I'll get rid of the whole EGR set-up as soon as I get my hands on a multimeter This post has been edited by Culpable04: Mar 19, 2007 - 9:43 PM -------------------- |
Mar 20, 2007 - 11:38 AM |
Enthusiast Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
Randy, whenever you decide to swap, let me know. I would take that intake manifold cover and the valve cover off your hands, and if you are going to try the swap yourself, I might be able to get over there and help out a bit.
I'm not really an asshole, but I play one on the internet. **** Photobucket |
Lo-Fi Version | Time is now: November 27th, 2024 - 2:35 AM |
