> FS: 7AFE TURBO KIT!, !!!NOW PARTING!!!
post Aug 23, 2006 - 7:45 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
UPDATE- NOW PARTING!
Items:
Turbo XS rlf (modified 2 trumpets) Blow-off valve. $60 shipped. SOLD
Oil Filter Relocation Kit $25 shipped. SOLD
12:1 Fuel Management Unit (FMU) $85 shipped. SOLD
Fuel Cut Defender $50 shipped.
Autometer Boost Gauge ($50) SOLD
Greedy Exhause Gas Temperature Gauge (EGT) ($100) SOLD
Autometer A/F ratio Gauge ($60) SOLD
Greedy Oil Pressure Gauge ($40) SOLD
Oil Line Splitter with Pressure Reducer $55 shipped. SOLD
Koyo Aluminum Radiator $120 shipped.
Greedy Front Mount Intercooler and Piping $100 shipped. SOLD
550cc Injectors $200 shipped.
SAFC 2 $200 shipped.
MSD Boost Timing Master (BTM) and Tachometer Adapter $170 shipped.
MSD 6AL Ignition $60 shipped
So as some of you may know, I had this turbo kit on my car for about 9 months without any serious problems. I took it off about 2 months ago because I wanted a more reliable car since I only drive it to and from college, plus I may swap a 3sgte soon. This kit was VERY performance oriented. The guy who I bought it from put it on an engine with a gze bottom and reported 350 hp at 18 psi. I never ran this turbo at more than 8 psi, as I still wanted a reliable daily driver. After I installed this kit the difference was astonishing. The car would push me back into my seat at just 7 psi.
Here is a list of parts and pictures with descriptions:
Garrett GT28 Ball Bearing Turbo Charger with High Nickel Composite Cast Exhaust Manifold
This turbo charger is incredibly responsive: starts boosting at about 2000 rpm and is finished by 3000. There is no shaft play, but I will still say that the buyer should probably have this turbo rebuilt. The reason I say this is because I ran this turbo with the oil drain at about 10 degrees off of strait down and on a smaller oil return line than I should have. The turbo worked perfectly and still does, but sometimes it would burn oil upon heavy acceleration. I just want to be absolutely sure that the buyer knows that if he wants the longest life from the turbo that a minor rebuild should be done.
There is about 8,000 miles on the turbo charger.
The turbo should be reclocked so that the oil line is strait down (I'm just too lazy to do it myself).
Included with the turbo is an oil feed line and big return line, steel braided coolant lines, and external wastegate set to 7 psi.
The manifold is in great condition and comes with a heat shield and bung for the manifold temperature sensor that also in the kit.
The buyer should also know that in order to install this kit the front engine mount must be removed because of the way the turbo mounts. I ran my car like this for 9 months with no problems at all, but if you want you can get the rear mount reinforced or a custom from mount if you want to run much more psi. I never did this and had no problems.
UPDATE: 9/11/06 I am not selling this for sure until I get it rebuilt.
Additional Images:
http://img247.imageshack.us/img247/5545/dscn0077yb6.jpg
http://img209.imageshack.us/img209/848/dscn0079zi7.jpg
http://img247.imageshack.us/img247/3417/dscn0080au2.jpg
Perfect working condition, pre-welded into the IC piping. It's pretty loud when you are driving hard, but can be quieter if you are driving softly.
This is necessary for the mounting of the turbo. Comes with 90 degree elbow to keep oil lines away from the manifold.
Necessary if you are not using a 2 bar map sensor. This makes sure that the engine is getting enough fuel while boosting. Also included are the check valves. Steel braided line is included.
For Toyotas. Disables fuel cut while boosting.
Gauges: Autometer Boost Gauge($50)pending sale, Greedy Manifold Temperature Gauge (EGT) ($100), Autometer A/F ratio Gauge ($60)pending sale, and Greedy Oil Pressure Gauge ($40)pending sale all prices include shipping.
All gauges are in good condition and work perfectly. They hook up is easy, too. You just need to hook up ground, 12v, 12v ignition, 12v light (they light up at night) and then into the harnesses. Also included is the panel that I custom made from wood that fits the gauges into your glove compartment (see the pictures in my profile). Very sleeper.
Additional images:
http://www.6gc.net/images/member_photos/2866_5.jpg
http://img209.imageshack.us/img209/4946/dscn0072jt6.jpg
Necessary for the oil pressure sensor. Pressure reducer makes sure that the turbo is not over oiled. Brand new from jgstools.
I never installed this because I knew I wasn't going to run the psi that I would need it for, but I'm throwing it into the kit anyways. There are some bent fins, but I never installed it so to my knowledge it works fine. For manual transmission only.
Additional image:
http://img220.imageshack.us/img220/728/dscn0083ja1.jpg
This is a BIG intercooler and just fits with no cutting required. I painted the front black with engine paint and it looks really good in my opinion. I also will include all IC/turbo piping for the kit, but note that it’s made mostly from crush bent piping. It worked well for me but everyone seems to want mandrel bent stuff now... whatever. (note ic piping is meant to hook up for a turbo that mounts downward.)
Additional Image:
http://img220.imageshack.us/img220/5047/dscn0085ce8.jpg
Work perfectly. Some of them have some cracks in the plastic at the bottom from use (see pictures). All of the o-rings were just replaced from the dealership (cost me 50 bucks for o-rings!), so no worries about leaks.
Excellent condition, works perfectly. A must-have for the bigger injectors and fmu. Plus it's sweet in that it tells you RPM, Manifold pressure, Knock, Throttle position, etc and can record stuff, too.
I got this from Manny (Pressure2) a while ago but never installed it. This retards engine timing per pound boost, so that you know your engine won't go boom-boom for higher boost. I never needed for only 7 psi, but it's a good safety precaution, especially for high boost. It's also tunable at the dyno. You can see that it's in amazing condition. It includes the tach adapter necessary for hook-up to the Celica.
MSD 6AL Ignition $60 shipped (cheap b/c wiring harness is cut)
I never installed this also because stock ignition sufficed for my low boost. This makes your spark super hot so that more fuel is burnt and you get more power. I will throw it in the kit anyways for someone who wants to run more boost.
I bought this kit from a member here, and I want to offer it all to you guys before it goes on ebay or I decide to part it. I bough this 9 months ago for $2500 dollars, plus I added more and better parts to it. Everything that you need minus fluids, manifold gasket, and a bung for the oil pan is included in this kit. I am willing to get rid of this everything in this kit kit for $2000 shipped, or less for local pick-up in Ventura, CA. Feel free to ask any questions, and thanks for you interest.
-Brian
This post has been edited by CheesyLobster: Sep 11, 2006 - 9:40 PM
Replies (1 - 17)
post Aug 23, 2006 - 8:46 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
its tempting... really tempting. but i'm gonna have to pass on this. looks like a pretty good deal too. i'll just have to settle for a weak na 7afe for now. good luck with the sale.
This post has been edited by j0e_p3t: Aug 23, 2006 - 8:46 PM
post Aug 23, 2006 - 9:58 PM
Shocker
Joined Mar 23, '06
From Nashville Tennessee
pm sent
post Aug 24, 2006 - 12:55 AM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
bump for a good deal
post Aug 24, 2006 - 4:11 PM
CheesyLobster
Joined Jul 19, '04
bump
post Aug 24, 2006 - 10:39 PM
FallenHero
Joined Dec 26, '02
From Alabama
bump. let me know if you decide to part it.
post Aug 24, 2006 - 10:59 PM
airfron
Joined Jul 31, '05
From Southern California
QUOTE(FallenHero @ Aug 24, 2006 - 8:39 PM) [snapback]472616[/snapback]
+1
there are a couple of items that i'd def. be interested in but i don't need the whole kit
and Ventura is about an Hour from here
i'll keep checking back on this thread
post Aug 25, 2006 - 11:11 PM
CheesyLobster
Joined Jul 19, '04
i'll let you all know if i decide to part within the next week. bump
post Aug 28, 2006 - 4:26 AM
CheesyLobster
Joined Jul 19, '04
bump
post Aug 31, 2006 - 3:01 AM
CheesyLobster
Joined Jul 19, '04
last chance for someone to buy everything in the kit. contact me if you want to negotiate the price.
bump.
post Sep 1, 2006 - 1:31 AM
CheesyLobster
Joined Jul 19, '04
bump, now parting.
post Sep 1, 2006 - 1:42 AM
airfron
Joined Jul 31, '05
pm sent
post Sep 1, 2006 - 11:35 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
YGPM
post Sep 5, 2006 - 12:40 AM
CheesyLobster
Joined Jul 19, '04
bumpo
post Sep 5, 2006 - 9:17 AM
Shocker
Joined Mar 23, '06
Great seller.. buy his stuff..
post Sep 7, 2006 - 10:25 PM
CheesyLobster
Joined Jul 19, '04
bump
post Sep 7, 2006 - 11:45 PM
DJ Sueno
Joined Jul 20, '05
From East Coast
QUOTE(CheesyLobster @ Sep 7, 2006 - 11:25 PM) [snapback]477429[/snapback]
What kind of Fuel Cut Defender is that? Interested, but never seen it before who is it made by and where did you get it ?
post Sep 7, 2006 - 11:54 PM
CheesyLobster
Joined Jul 19, '04
QUOTE(DJ Sueno @ Sep 7, 2006 - 9:45 PM) [snapback]477452[/snapback]
i don't know what kind it is, it came in the kit i got from a member here. it just says toyota on the other side and it splices into the map sensor.
Lo-Fi Version Time is now: November 29th, 2024 - 8:44 AM
