oil psi gauge |
oil psi gauge |
Aug 30, 2006 - 10:27 PM |
Enthusiast Joined Dec 31, '04 From white hall, Maryland Currently Offline Reputation: 0 (0%) |
ok i hook it all up, put the sensor in the head where it goes, and i touch the sending wire to the sending unit and the gauge jumps all the way up to 100 y is that. ????? i rewired and it still does the same thing, new sending unit...does the same thing. what could possibly be wrong???? HELP!!!!! (spke719)
-------------------- [font=Comic Sans Ms][size=3]
SI VIS PACEM PARA BELLUM (if you wish for peace, prepare for war!) |
Aug 31, 2006 - 2:04 AM |
Enthusiast Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
what you should get is a mechanical oil pressure gauge. Not an electrical one.
-------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Aug 31, 2006 - 2:14 AM |
QUOTE(spke719 @ Aug 30, 2006 - 11:27 PM) [snapback]474705[/snapback] ok i hook it all up, put the sensor in the head where it goes, and i touch the sending wire to the sending unit and the gauge jumps all the way up to 100 y is that. ????? i rewired and it still does the same thing, new sending unit...does the same thing. what could possibly be wrong???? HELP!!!!! (spke719) your grounding out your singal wire on the body of the sender. the signal wire should only touch the threaded part that it gets hooked up to. there should be some type of a gasket around the bolt that sticks out of the sender, to prevent it from grounding out on the body of the sender. This post has been edited by lagos: Aug 31, 2006 - 2:20 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 31, 2006 - 5:16 PM |
QUOTE(lagos @ Aug 31, 2006 - 2:14 AM) [snapback]474747[/snapback] QUOTE(spke719 @ Aug 30, 2006 - 11:27 PM) [snapback]474705[/snapback] ok i hook it all up, put the sensor in the head where it goes, and i touch the sending wire to the sending unit and the gauge jumps all the way up to 100 y is that. ????? i rewired and it still does the same thing, new sending unit...does the same thing. what could possibly be wrong???? HELP!!!!! (spke719) your grounding out your singal wire on the body of the sender. the signal wire should only touch the threaded part that it gets hooked up to. there should be some type of a gasket around the bolt that sticks out of the sender, to prevent it from grounding out on the body of the sender. im only touching it to the threads and it grounds out. -------------------- [font=Comic Sans Ms][size=3]
Lo-Fi Version | Time is now: January 11th, 2025 - 7:50 PM |
