> Rear suspension hum.
post Sep 13, 2006 - 10:07 AM
bindertch
Joined Aug 18, '04
From Silverdale, WA
For the last month I have been hearing a hum from my rear suspension. It sounds like it was coming from the passenger side so I replaced that side's hub but the hum is still there. Any ideas on what could do this? I thought maybe a bushing or the strut. Any ideas would help I am going to put it up on a lift this weekend so that I can inspect everything but I don't want to start tearing the entire rear suspension apart.
Replies (1 - 8)
post Sep 13, 2006 - 10:10 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
did you replace the wheel bearing with the hub? otherwise the wheel bearing might need some more grease
post Sep 13, 2006 - 1:49 PM
bindertch
Joined Aug 18, '04
From Silverdale, WA
I put the one that I bought from you Lewfx on there and everything was fine. I drove to Montana and then over to Washington and on the way to Washington it started to hum. I thought it was the bearing but like I said I replaced it and the hum is still there.
post Sep 13, 2006 - 2:22 PM
LewFX
Joined Jan 28, '05
how quickly i forget...tire pressue okay?
post Sep 13, 2006 - 2:23 PM
check the alignment, TOE can cause some hard to find noises that sound like bearing humm.
post Sep 14, 2006 - 9:52 AM
bindertch
Joined Aug 18, '04
From Silverdale, WA
QUOTE(Bitter @ Sep 13, 2006 - 12:23 PM) [snapback]479347[/snapback]
I have no odd tire wear and since it started I have driven about 3k miles. I'm thinking that it might be a strut or a bushing.
post Sep 14, 2006 - 10:21 AM
LewFX
Joined Jan 28, '05
id take a looksy but you seem far from torrance.
post Sep 14, 2006 - 3:19 PM
QUOTE(bindertch @ Sep 14, 2006 - 9:52 AM) [snapback]479633[/snapback]
toe in or toe out can be very hard to feel, just a degree out of specs can cause noise with some tires.
post Sep 14, 2006 - 3:24 PM
LewFX
Joined Jan 28, '05
strut wont cuz humming.
Lo-Fi Version Time is now: November 29th, 2024 - 6:57 AM
