> Transmission Question, what else to replace while replacing clutch
post Sep 13, 2006 - 10:42 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
my clutch is starting to slip a bit so now i needa save a bit of cash incase one day it goes really bad... so i needa kno what i need to save up for
so i was wondering... if i'm getting my clutch replaced.. what are all the things i should replace while doing it?
i notice some places have clutch kits which include
pressure plate
street disc
release bearing
alignment tool
a clutch kit should have everything i need right? so i think i will most likely buy a clutch kit?
but other than those parts in the kit, are there any other parts i should i replace while i'm at it? like:
bolts/screws
flywheel
throw out bearing
shift cables
master/slave cylinder
06 Civic EX
My For Sale Thread
Replies (1 - 1)
post Sep 13, 2006 - 10:57 PM
your flywheel should be checked against specs and cut or replaced if needed.
bolts may or may not be reusable.
shift cables should be ok
throw out bearing, if its cheap you might as well replace it.
master/slave, if its not broke then you dont need to fix it. but DO bleed the old fluid from the system and bleed any air from the system.
Lo-Fi Version Time is now: November 29th, 2024 - 6:45 AM
