> 1st post...low idle problems..help please
post Sep 18, 2006 - 7:44 PM
TurboZo
Joined Sep 18, '06
From Irvine,CA
Hi, glad to find an active forum for the 6 gen celica...
I've had our (my wife's car) 99 GT for 3 years now. Since I've had it, I've been struggling with the low idle problem. On start up, the engine often stalls since the RPMs aren't high enough. At first I used to slightly hold the pedal until it warmed up. After taking the throttle body off, cleaning it, cleaning the ISC, testing it, the cold start worked for a while then started having the problem again. Currently, when starting up, it idles around 450 and feels like it will cut out. Once in a while the idle seems correct though soon it goes back down. with the AC on, at a standstill in D (auto), it starts to chug a bit since the idle is so low. Recently, I gave up and took it to a trustworthy mehcanic...he did a fuel system cleaning along with the intake cleaning. afterwards, the idle worked great...at cold start, the idle went right above 1k then eventually came down to 750...that lasted a whole 3 days...and now it is back to as I mentioned before. This issue has been driving me nuts for 3 years. I'm considering doing the seafoam manuver today.
Other things that may be related:
-some smoke at startup (perhaps aging seals, or pcv valve, or something else?)
-the engine temp stays low for quite a while, not staying at the midway mark like it did before)
Any input would be much appreciated.
Thanks,
Zo
99 GT
145k
auto
Replies (1 - 9)
post Sep 18, 2006 - 7:50 PM
GreenyST204
Joined Apr 11, '06
From Tasmania
Welcome TurboZo,
This might help
Resetting your Air/Fuel Mixture Ratio
Ok Gladys, lets play house, you be the door and I'll shut you.
post Sep 18, 2006 - 7:53 PM
check the engine coolant temp sensor, check the IAC motor, and check the wiring that runs to and from all of those.
post Sep 19, 2006 - 12:46 PM
TurboZo
Joined Sep 18, '06
From Irvine,CA
QUOTE(Bitter @ Sep 18, 2006 - 7:53 PM) [snapback]481179[/snapback]
Thanks for the suggestions. Is there any additional info on the IAC Motor? Does this forum have a link to an online Repair Manual. I've been using the MR2 one (mr2-tech.com)
Thanks,
Zo
post Sep 19, 2006 - 1:52 PM
hitcachi
Joined Jun 19, '05
From Nebraska
QUOTE(TurboZo @ Sep 18, 2006 - 7:44 PM) [snapback]481175[/snapback]
lol. Whats up with alot of the 99 GT's being owned by people wives?
post Sep 19, 2006 - 1:59 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
might be the aic or the o2 sensor.
post Sep 19, 2006 - 2:47 PM
TurboZo
Joined Sep 18, '06
From Irvine,CA
QUOTE(hitcachi @ Sep 19, 2006 - 1:52 PM) [snapback]481415[/snapback]
haha. well for us, my wife originally wanted an eclipse but I said no way since they have such a horrible track record in terms of reliability. I was thinking of the newer celica but my wife said they look too boxy and guy-ish...on the other hand she said the older celicas are curvy and (you guys are going to hate this) feminine. So I got her the last year of that generation.
we really like this car and would love it if it wasn't for this damn idle problem.
-Zo
post Sep 19, 2006 - 2:54 PM
Kadett
Joined Mar 17, '05
From The Netherlands
In my case, Low RPM and almost stalling was caused by a malfunctioning O2 Sensor.
post Sep 19, 2006 - 3:03 PM
TurboZo
Joined Sep 18, '06
From Irvine,CA
QUOTE(Kadett @ Sep 19, 2006 - 2:54 PM) [snapback]481442[/snapback]
which one was it in your case, the one on the exhaust mani or the one further down?
thanks,
zo
post Sep 19, 2006 - 3:13 PM
Kadett
Joined Mar 17, '05
Well the 3S-GE only has one since it has a 4-2-1 exhaust mani. So it was the one further down between exhaust mani and cat. But I think a local garage/dealer can find it out for you.
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 23rd, 2025 - 2:16 AM
