> HELP!!! NEED CV BOOT
post Sep 22, 2006 - 3:15 AM
freakyre33c
Joined Jan 29, '06
i was putting my rims on my car last night and i notice a great amount of greaze around the bottom of the strut bolts and i then i notice the 3 -4 inch tear in my CVBOOT i need one fast if any one has one or two tell me?? how much are they oem anyways?
Replies (1 - 8)
post Sep 22, 2006 - 10:37 AM
its way easier to just get a new axle/cv assembly and install that than it is to...
remove the axle
remove the old boot
remove the cv joint
clean the cv join
inspect it for damage, scratches, gouges, ect
regrease the joint
reinstall the joint on the axle
install the new boot
install it into the car
if you buy a new axle/cv assembly then all you need to do is...
remove the axle
install the new axle
post Sep 22, 2006 - 10:44 AM
quicknstyle
Joined Oct 3, '02
From HOUSTON
im pretty sure they sell them at autozone pretty cheap assuming the boot is all we need
post Sep 22, 2006 - 11:56 AM
Starcraftjunkie
Joined Nov 21, '05
From Wpg, MB. Canada
my mechanic told me to make sure to get the oem cv's instead of aftermarket ones since they last a lot longer. In his experience, people who've used the cheaper stuff ($20 a boot) come back within the year to get them changed again.
post Sep 22, 2006 - 12:49 PM
Rayme
Joined Feb 18, '06
From NB, Canada
I did mine temporary with a split type boot..suprisingly after 2 months its still holding strong!! (again I see it as a temporary solution)...
-Rémy
02 SiR, 08 250R
post Sep 22, 2006 - 1:45 PM
wind
Joined Nov 4, '03
From Vancouver, Canada!
i used a split boot on mine.... its been 3 years and it is fine, no leaks and no tears
post Sep 22, 2006 - 1:57 PM
Snodalo
Joined Aug 22, '06
From Daygo
i just bought two new axels at napa, theyre going to be in tomorrow but they were 59 each which isnt bad. I think there is a court charge so i might have to give them my old ones. my cv is ****ed up too but im just replacing the axels. at autozone they said it was i think 139 each for each axel.
post Sep 22, 2006 - 3:35 PM
the reason why you want to replace the whole joint is becuase water and dirt can get in there and just eat up the joint over time weakening it. if it breaks when you're driving it can be very very very bad. not only are you stuck where you are, if you're turning when it happens you can spinning off the road.
post Sep 23, 2006 - 10:50 AM
freakyre33c
Joined Jan 29, '06
QUOTE(Snodalo @ Sep 22, 2006 - 1:57 PM) [snapback]482670[/snapback]
JUst ordered my new axle from carquest 70 BUCKS and my core
Lo-Fi Version Time is now: February 19th, 2025 - 7:27 PM
