> Pirate Tuning Gt four finally rebuilding
post Sep 22, 2006 - 4:47 PM
snakeloa
Joined Sep 15, '03
From Germany
Hello, after quite a while of waiting, changing plansand ordering other parts....
I can now tell you that me rebuild is doing fine so far.
Then the clutch and the crank got treated and balanced.
The head received a full street port and oversized valves wink.gif new camshafts, springs titanium retainers....
Then evreything went very fast this week smile.gif Well after 10 month waiting and changing and deciding an....
On the pics above you can see the some of the parts we use at the moment....
GT35R bolt on kit smile.gif with recirc downpipe
e voila cp pistons (polymer coated outside and ceramic coted on top did actually found a place above the pauter conrods
Crankshaft fitted after some slight line boring...
Some more pics
Well now we hope to finish everything else soon. fuel supply, water injection....
I will let you know
cheers Joerg
Spec to be found on my website....
Replies (1 - 19)
post Sep 22, 2006 - 4:55 PM
celi_gt_racer
Joined Feb 6, '03
From huntingdon tennessee
post Sep 22, 2006 - 5:05 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
okay im kinda lost as to whats going on...can u please explain snakeloa
(\__/)
post Sep 22, 2006 - 5:23 PM
that looks like an AMAZING build there snakeola.
very much looking forward to the results of all the hard work and $$ im sure. wink.gif
post Sep 22, 2006 - 6:25 PM
snakeloa
Joined Sep 15, '03
From Germany
thank you guys. yes a lot of $ spent... But lets not talk about something i don't have anymore wink.gif I mean $ notes
First of all i can say: The thing i hated most was to have to wait for parts!
@ 3waystunna
i had in mind to run an ATS TD06. I bought a TD06 kit a new TRD clutch and the last ultra light C-One "racing" flywheel. and a 100psi Water injection. and a wide band lamda sensor set. An apexi Power FC
Well i guess you know what happened... I had to order a new fuel regulator, 800cc fuel injectors, and a 265L/h fuel pump
Then we decided to look into the engine.
Well i had some slight scratches in one of the cylinders. frown.gif you can be shure that i didn't like that kind of news. Especially as i never wanted to touch the engine itself.
Because of the scratch i had to go oversize... I of course decided to use some good aftermarket pistons. New conrods....
Then i decided to get a full street port job done and i sent my cylinder head with new camshafts to enginelogics around the half globe smile.gif
I decided then to use a bigger turbo. Instead of the TD06 i started to build up a GT35R Kit.
Well that caused me to order a new clutch.... I decided to go for a tein plate Carbon clutch from ATS & Accross.
then i thought well as so much time passed by now, i might swap my water injection and get a bigger direct port water injection which is digitally controlled.
Then i thought to shorten the waiting period i could order the datalogit software... a TRD quick shifter and a new custom designed speedo and some spare parts...
Crazy??? Well i guess yes.
So now at the moment after the crankshaft is back from nitrogen hardening the engine is getting rebuild.
Then the water injection will be fitted as the fuel supply will.
Then the engine will be shipped from Cologne to hannover where my mechanic is waiting to put back in the engine.
Then after some final work we should run some test.
I won't drive the car for another while. As i will get a tig welded full motorsport rollcage. And a ne paintshop on the roof and the rearsection of the car..
welll then there will be a running in priod, a few mapping sessions.... and then we will meet @ the PECM2007 in Varano wink.gif
cheers Joerg
post Sep 23, 2006 - 10:00 AM
hitcachi
Joined Jun 19, '05
From Nebraska
sweet!! Very nice looking and im diggin the castrol 5th gen in the background. biggrin.gif
post Sep 23, 2006 - 11:24 AM
thats going to be one amazing car when its all done. keep us updated with lots of pics and videos!
post Sep 23, 2006 - 12:02 PM
Predator
Joined Feb 26, '05
From Sweden
sounds awesome, good luck with everything
post Sep 23, 2006 - 12:15 PM
WH95TE
Joined Jun 16, '06
From Plantation, FL
Amazing on the outside aswell as the inside. Good job.
post Sep 24, 2006 - 11:34 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
OUTSTANDING!!! thumbsup.gif very nice.
post Sep 24, 2006 - 12:30 PM
Magic
Joined Mar 30, '03
From Cyprus
post Sep 25, 2006 - 3:21 AM
snakeloa
Joined Sep 15, '03
From Germany
QUOTE(Magic @ Sep 24, 2006 - 5:30 PM) [snapback]483238[/snapback]
I will... I want to try to get a few great videos done. I will buy a good viedeocam and then i am thinking about different mounting angels like in the front bumper, @ the fender on top-rear of the roof... smile.gif That should make good fun.
post Sep 30, 2006 - 3:02 AM
ice23q
Joined Jan 16, '04
From sydney australia
That is gonna be a FUN ride dude.... wicked stuff...
312whp with more to come....
post Oct 5, 2006 - 8:54 AM
snakeloa
Joined Sep 15, '03
From Germany
Ok Guys Where would you place the Water Injection nozzles? As they are screw and nut type we are limeted to go as deep into as the fingers or tools are long.
post Oct 5, 2006 - 10:49 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(snakeloa @ Oct 5, 2006 - 8:54 AM) [snapback]487934[/snapback]
I am pretty sure I have read that the best place for the water injection is post intercooler in the intercooler piping as far away from the intake manifold as possible. Someone needs to confirm though.
post Oct 9, 2006 - 3:33 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
i think this is different because he said its direct port, which i know nothing about
post Oct 12, 2006 - 5:55 PM
snakeloa
Joined Sep 15, '03
From Germany
Hello again,
after a small problem with my camshafts suddenly be bent... (I do not know how this happened. And nobody of the 3 people touching the camshafts can say ewhen or how it happened frown.gif ) We can now carry on with the rebuild.
The headwork.
A scribble of my mechanic.... I will have to ask him about it. Buit i guess he was measuring the compression-Ratio
I hope everything goes on well.
I was as well a bit nervous about the valve clearance.
Jun gave me this numbers for their camshafts: 0,20 intake 0,33 exhaust
My mechanic here told me normalo would be 0,15-0,25 intsake and 0,25-0,35 exhaust
My Head builder in the US Chris K told me 0,16-0,22 intake is fine and 0,23-0,28 exhaust is fine
We measured 0,16 intake 0,23-0,28 exhaust
My mechanic here says that the exhaust side could get a bit "tight"
Chris says it is just fine.
Well as he build the head for me than this is ok for me as well.
cheers Joerg
post Oct 13, 2006 - 2:51 PM
snakeloa
Joined Sep 15, '03
From Germany
Bolts are in place
Headgasket is an OEM one
and finally the head is on:
cheers Joerg
post Oct 17, 2006 - 3:43 AM
3WayStunna
Joined Jun 25, '06
Nice build bro, and thanks for the explanation....anywho, good luck.....
(\__/)
post Oct 17, 2006 - 8:20 AM
looks good brother, what kind of sleeves are you running, and boost level plans?
This post has been edited by playr158: Oct 17, 2006 - 8:21 AM
Lo-Fi Version Time is now: December 1st, 2024 - 6:07 AM
