> Dyno'd the Celi, Take a look...
post Sep 24, 2006 - 7:56 PM
celicagurl152003
Joined Oct 12, '04
From Montgomery, AL
Replies (1 - 19)
post Sep 24, 2006 - 7:59 PM
block
Joined Jul 27, '06
From Soda
on a ST? what mods did u have? pretty kool. aren't ST's 110hp?
post Sep 24, 2006 - 8:01 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE(block @ Sep 24, 2006 - 7:59 PM) [snapback]483344[/snapback]
post Sep 24, 2006 - 8:08 PM
celicaST
Joined Jun 23, '05
QUOTE(block @ Sep 24, 2006 - 6:59 PM) [snapback]483344[/snapback]
yep, but im guessing two of those runs are with the nitrous. im scared to think what my car would put down on a dyno.
post Sep 24, 2006 - 8:09 PM
celicagurl152003
Joined Oct 12, '04
From Montgomery, AL
horsepower 105 @5200rpm torque 117 @2800rpm
post Sep 24, 2006 - 8:14 PM
im assuming 3&4 are with nitrous?
those runs(especially 4 looks REALLY lean...
post Sep 24, 2006 - 8:29 PM
celicagurl152003
Joined Oct 12, '04
From Montgomery, AL
yes runs 3 & 4 are with the Nitrous.....
post Sep 24, 2006 - 8:33 PM
96c-oneconv
Joined May 12, '04
From canada
still pretty decent numbers for an st. Keep up the good work.
post Sep 26, 2006 - 12:11 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(celicagurl152003 @ Sep 25, 2006 - 1:29 AM) [snapback]483357[/snapback]
The runs with nitrious are dangerously lean.
post Sep 26, 2006 - 12:33 AM
just so I am sure about this, this is what your engine has done to it (from your profile)
Heads 3 Angle Valve Job
Oversized Valves
Performance Cams Reground
and still you got only 87-88 to the wheels ?
and with
Dry Shot Nitrous Kit (75 shot)
you got 122-123 ?
it all just seems low to me.
post Sep 26, 2006 - 12:47 AM
Steevo
Joined Jul 19, '06
From Colorado
Altitude corrected or not? And at what altitude?
post Sep 26, 2006 - 1:46 AM
based on your dyno sheet, i wouldnt use the nitrous if i were you. your motor is VERY lean and wont last long.
post Sep 26, 2006 - 7:26 PM
JFrost9
Joined Aug 27, '05
From Texas
this is a dumb question i know, but im just out to learn... what does a lean engine refer to? and what are you guys looking at to tell that?
post Sep 26, 2006 - 8:04 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(JFrost9 @ Sep 27, 2006 - 12:26 AM) [snapback]484150[/snapback]
Lean means the engine isn't getting enough fuel. Tyically when reffering to gasoline engines, a good clean burn is an airfuel mix of about 14.7:1. A number higher than that means the airfuel mixture is lean (has more air). A number lower means the mixture is rich (more fuel). Most engines run rich around 13 to 12... rarely leaning out more than 14.7...
post Sep 26, 2006 - 8:10 PM
phonex98
Joined Mar 25, '06
Ok, i knew what lean meant but now im curious... why is too lean, bad. It would seem to me that a lean mixture would allow the gasoline to fully react, and having oxygen in excess, just blowing that out the exhaust? No ?
----- '94 ST hatch --- Yellow -----
post Sep 26, 2006 - 11:07 PM
rayneezy23
Joined Jun 25, '06
From Bremerton, Washington
im guessing that headers dont actually help
post Sep 26, 2006 - 11:08 PM
Steevo
Joined Jul 19, '06
From Colorado
The leaner the mixture the more prone to detonation it is, plus the flame front is much hotter and can actually melt a piston.
post Sep 27, 2006 - 12:05 PM
QUOTE(phonex98 @ Sep 26, 2006 - 9:10 PM) [snapback]484182[/snapback]
think of it this way. there is a lot of heat inside a cylinder when its making power. the heat inside can cause detonation. the more fuel you put in there (rich), the better cooling and protecion you get. the less fuel you have (lean), the more you risk detonation.
you can clearly see by looking at the a/f chart that its only a matter of time till that motor goes, based on how lean it is.
post Sep 27, 2006 - 2:51 PM
i wonder how much better a FED/OBD1 7A-FE would dyno with the same bolt ons? atleast theres a nice flat powerband all the way to redline.
post Sep 27, 2006 - 4:01 PM
pure_dx
Joined Dec 28, '05
From USA
btw: did u hook up the safc yet?
Lo-Fi Version Time is now: December 4th, 2024 - 10:18 PM
