> Apexi power fc, Mr2 ECU in ST205
post Sep 26, 2006 - 12:34 PM
deversator
Joined Sep 26, '06
From Switzerland
Does anyone knows if there are any changes nesserary, in the ECU wiring, if I want to fit an Apexi power FC from an Turbo Mr2 Gen III in my ST205?
I know the IC pump woudn't work, but have I to cut the wires to provide ECU damage?
Gruss Deversator
Replies (1 - 2)
post Sep 29, 2006 - 6:44 AM
P5ycho
Joined Mar 29, '06
From UK
its been done many times, u can find all info u need on www.gt4oc.net..
believe u have to short the wires to the charge cooler pump to make it run continuosly other than that its a pretty strait forward fit, then u will need someone to map the power fc on a dyno to what u want the car to do.
post Sep 30, 2006 - 1:17 AM
deversator
Joined Sep 26, '06
From Switzerland
Thanks, I fitted the ECU yesterday. It works really plug and play, I just maked a bridge by the intercooler relay.
Gruss Deversator
Lo-Fi Version Time is now: January 10th, 2025 - 6:33 AM
