> air bag light..., air bag light...
post Sep 27, 2006 - 4:46 AM
blackbullet
Joined Jul 21, '04
From Fresno, CA
my air bag light pop up all of a sudden so what should i do? is there any way to kill the light or see what the problem is like a dianostic test or something? or do i have to go to the shop to turn the light off?
Replies (1 - 5)
post Sep 27, 2006 - 7:34 AM
The ABS has it's own ABS ECU and if there is a prob with the system (sensor or whatever) it shuts the system down and you have normal braking ability and the ABS light will remain illuminated. You can then read the ABS codes
94-95
ignition in the ON position,
bridge E1 & TC in the diagnostics box, just like checking codes, read the code from the ABS light
codes 31-34 are the sensors @ each wheel.
31 Malfunction of right front wheel speed sensor signal. Check
speed sensor, sensor rotor, wiring harness and connector
32 Malfunction of left front wheel speed sensor signal. Check
33 Malfunction of right rear wheel speed sensor signal. Check
34 Malfunction of left rear wheel speed sensor signal. Check
speed sensor, sensor rotor, wiring harness, and connector
post Sep 27, 2006 - 8:53 AM
toyotatech
Joined Jun 14, '05
From colorado
for the air bag light your need the scan tool to pull codes.
post Sep 27, 2006 - 11:18 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
you have a 97 correct?
you need an OBDII scanner. depending on the scanner you get it'll either just give you a code which you'll have to look up or it'll tell you exactly what the problem is. some OBDII's allow you to clear CEL's so maybe its the same for the airbag light
I <3 Dustin---07/16/06
post Sep 27, 2006 - 11:32 AM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
Advance auto parts should let you use there's for free....at least they do by my house
This post has been edited by Daftboy: Sep 27, 2006 - 11:33 AM
post Sep 28, 2006 - 5:55 PM
blackbullet
Joined Jul 21, '04
From Fresno, CA
thanx guys...ill see what i can do.
Lo-Fi Version Time is now: November 30th, 2024 - 6:23 PM
