While doing the clutch..., Engine mounts? |
Oct 3, 2006 - 5:47 PM |
Enthusiast Joined Apr 14, '06 From Vancouver, WA Currently Offline Reputation: 0 (0%) |
My clutch has been slipping like a mad man so I ordered the ACT Street clutch and was just wondering if I should do my engine mounts while I'm down there. I've noticed that my engine does have a chugging feeling if I let off the gas accasionally and I was just wondering if this was the result of my mounts going bad?
Anyone else experience the same thing? -------------------- |
Oct 4, 2006 - 8:38 AM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
QUOTE(GTS13 @ Oct 3, 2006 - 5:47 PM) [snapback]487014[/snapback] My clutch has been slipping like a mad man so I ordered the ACT Street clutch and was just wondering if I should do my engine mounts while I'm down there. I've noticed that my engine does have a chugging feeling if I let off the gas accasionally and I was just wondering if this was the result of my mounts going bad? Anyone else experience the same thing? You could have engine mounts going bad, or it could just be that you are disengaging the clutch too quickly. If you do your own work on the transmission, you will have access to 3 of the 4 engine mounts. The 2 which mostly control engine movement would be the front and rear transmission mounts. I would check those 2 for any wear or tearing. As long as they are not torn/broken, or show any signs of being ABOUT to tear, you should be fine. Engine mounts are very expensive business, and really don't need to be done unless absolutely necessary. -------------------- |
Oct 4, 2006 - 9:44 AM |
Enthusiast Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
Go to advance auto and pick up a tube of 3m Window Weld Urethane and fill the stock mounts. Works great!
Oct 4, 2006 - 6:21 PM |
Enthusiast Joined Aug 28, '06 From U.S.A. Currently Offline Reputation: 2 (100%) |
just buy the motor mount inserts from kirkosaurus. $40 some bucks and they work absolutely fabulous.
Oct 4, 2006 - 6:40 PM |
Enthusiast Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
QUOTE(dubk @ Oct 4, 2006 - 6:21 PM) [snapback]487643[/snapback] just buy the motor mount inserts from kirkosaurus. $40 some bucks and they work absolutely fabulous. ya, but if they mounts are actually cracked, then its a good idea to fill them or replace them. The inserts will work to maximum potential if they are used in conjunction with a working mount. This post has been edited by hitcachi: Oct 4, 2006 - 6:40 PM -------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Lo-Fi Version | Time is now: November 24th, 2024 - 12:47 AM |
