> "Brake" Light on Dash
post Oct 5, 2006 - 2:53 PM
Camax333
Joined Jun 8, '06
From Hartford
Everytime I take a sharp turn the brake light on my dash comes on for a few seconds. What are the possible causes for this? I recently replaced my brake pads so could it simply be brake fluid? I think it might have something to do with the emergency brake. Any ideas or suggestions?
Replies (1 - 9)
post Oct 5, 2006 - 2:57 PM
low fluid level.
post Oct 6, 2006 - 3:17 PM
Camax333
Joined Jun 8, '06
From Hartford
I checked the brake fluid level...It doesn't seem to be low, it is a little above the minimum level. What else could it be?
post Oct 6, 2006 - 3:39 PM
airfron
Joined Jul 31, '05
From Southern California
top it off and see if that helps. you shouldn't keep your fluids at the lowest acceptable level anyways
post Oct 6, 2006 - 4:12 PM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
keeps fluids full not at a minium level
post Oct 9, 2006 - 1:12 AM
dubk
Joined Aug 28, '06
From U.S.A.
definitely fluid
post Oct 9, 2006 - 1:47 AM
monky32
Joined Oct 19, '04
From orlando
get your fluid to the right level. the same thing happened to me!!
post Oct 9, 2006 - 1:55 AM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
in US cars isnt the "brake" light on the dash for the e-brake? in canada the light is a "(!)" light when the e-brake is applied. if it is the same light as the one i am thinking about, then it could be bad ground.
post Oct 9, 2006 - 8:05 AM
Alex-UKSC
Joined Jul 23, '06
From Chester - UK
QUOTE(6gsillyca @ Oct 9, 2006 - 7:55 AM) [snapback]489349[/snapback]
They use the same warning light
My Celica Is Now For Sale
post Oct 9, 2006 - 9:47 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
This happened to me a couple of times before and it turned out that one of the hose lines where not properly connected going to the brake booster. Check your brake vaccum pipings
Lo-Fi Version Time is now: February 20th, 2025 - 3:33 PM
