Rod Bearings, keep going bad |
Oct 24, 2006 - 3:26 PM |
Enthusiast Joined Mar 30, '05 From Schuylkill County, PA Currently Offline Reputation: 0 (0%) |
I was just wondering if anyone else has had a problem with 5sfe rod bearings going bad , and if so what have you done to fix the problem. Any help will be greatly appreciated
Thanks -Eric |
Oct 24, 2006 - 9:01 PM |
Enthusiast Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
QUOTE(bobw @ Oct 24, 2006 - 3:26 PM) [snapback]495576[/snapback] I was just wondering if anyone else has had a problem with 5sfe rod bearings going bad , and if so what have you done to fix the problem. Any help will be greatly appreciated Thanks -Eric Your only Solution is to dismantle your engine and buy new rod bearings, perhaps get stronger ones and ARP rod bolts. Do regular oil changes, never abuse the engine when its still cold and that should help out a lot. Most Rod bearings brake because its not receiving enough oil and friction creams it pieces. A SWAP will just cost you more and giv emore headaches. Nows a good time to replace seals and do an engine rebuild. |
Oct 24, 2006 - 11:57 PM |
Thanks alot, i was thinking of just building the spare 5sfe over the winter and puttin a 3sgte head on and a turbo, and fixing the one thats in there with an oversize bearing to see if that help is for she's sitting for the winter
This post has been edited by bobw: Oct 25, 2006 - 12:03 AM |
Lo-Fi Version | Time is now: January 9th, 2025 - 10:01 PM |
