> FS: 93-97 4AFE/7AFE Turbo kit for Sale!
post Oct 24, 2006 - 8:11 PM
toytech
Joined Dec 16, '05
From MD
Up for sale is the turbo kit that many of you have seen in my car (185hp @ 8psi on stock internals). $4500 o.b.o. If you live on the east coast, I will help install the setup on your motor, or if you decide to buy mine, I will help with the swap or do it for you($).
-Log Manifold
-Nissan Motors (T3 .42/.60) Full boost at 2500rpms (has 4k miles on turbo)
-Turbosmart Stealth wastegate
-Supersonic BOV
-2.5" Custom downpipe with flex pipe and two sensor bungs for 02 sensor and band 02 sensor.
-All Powercoated in Mil-Spec Hummer Black Aluminum Intercooler piping with Tig welds.
-Custom Coach Intercooler(Air to Air)
-Blue SAMCO piping connectors and ATP Turbo bolt clamps
-K&N 2.5 Air Intake
-95 Civic Radiator
-315cc Supra injectors and well as a spare set of 460cc rx-7 injectors for more fuel if you need it.
Any much, much more...
Also for sale is motors(thats right theres 2) and Manual trans with Quaife LSD and Stage 4, 6 Puck Clutch for Competition Clutch. Motor was re-built at 168k miles from the bottom to the top and now has 172k miles on it. When motor, was re-built, the new turbo was put on and new clutch and trans were installed. Trans had 12k miles on it when I installed it and it is a HYBRID 1997/2001 Trans, C52 bellhousing on a 2001 Corolla trans. LSD was installed and has since had 4k miles put on it, the same as the clutch. Motor has oil filter relocation, Can fit huge oil filters, oil drain already setup for turbo drain. There is more done, as if you have any questions. The other motor is bone stock sitting at the machine shop, so if you want it, you have have it for $100.
I'm sure I missed a hole lot, so email me or pm me or reply if you have any questions. Thanks. hazer00@yahoo.com
Scuba
Replies (1 - 2)
post Jul 19, 2007 - 10:05 AM
dutchboy
Joined Jun 28, '07
Is mounting a civic radiator an involved process? I heard somene say that the hose(s) are on the wrong side. Is that true?
Can you mount on either side of engine bay?
Does it provide ample cooling?
civic radiators are much cheaper, affordable aluminum option?
post Jul 19, 2007 - 11:49 AM
kerosene
Joined Jul 4, '07
From US
u selling the engine itself?
Lo-Fi Version Time is now: November 25th, 2024 - 11:45 PM
