gt4 hood and bumper, question about parts |
Nov 2, 2006 - 10:59 PM |
Enthusiast Joined Jun 17, '06 From bellevue washington Currently Offline Reputation: 0 (0%) |
so i read the post with all the part numbers and stuff. and its pretty long. i was wondering if i needed to get all of that stuff. i just want the hood and bumper but if i dont get all of the stuff off the list would it even work
if you could tell me what i need or tell me where i could find a diagram or somthing that would be great. thanks heres the list so you know what im talking about. Bumper Parts Cover, front bumper 52119-2b905 $223.27 This is the bumper (Thanks to jgreening for the correction) Absorber, front bumper energy 52611-20150 $62.76 This is the foam that goes behind the bumper Seal, hood to front end panel 53395-20020 $19.92 This is the rubber seal where the hood and bumper meet retainer, front bumper upper center 52521-20200 $25.44 this is the metal thing that holds the rubber in place Grill, sub-assy, rad., center 53101-20500 $46.29 This is the upper grille Grill, radiator, lower 53111-20750 $125.08 This is the lower grille Bezel, grille, lower RH 53112-20240 This is the right-hand bezel for the lower grill without fogs Bezel, grille lower LH 53113-20180 This is the left-hand bezel for lower grill without fogs Front turn signal, RH 81510-20750 Front turn signal, LH 81520-20750 Hood Parts Hood sub-assy. 53301-20500 $444.22 This is the hood Plate assembly, hood bulge 76190-20010 $ 42.95 This is the middle hood vent Bulge assembly, hood 76180-20010-XX This is the hood bulge. The -XX after the part number is a paint code, if you know your Toyota paint code, insert it there. Below are the part numbers, with color codes. Ornament sub assy, hood RH 75033-20030-XX This is the right-hand rear vent. The -XX after the part number is a paint code, if you know your Toyota paint code, insert it there. Below are the part numbers, with color codes. Ornament sub-assy, hood LH 75034-20030-XX This is the left-hand rear vent. The -XX after the part number is a paint code, if you know your Toyota paint code, insert it there. Below are the part numbers, with color codes. Guide,air to cowl 76191-20901 This if the optional hood spoiler |
Nov 2, 2006 - 11:47 PM |
actually all of those items are needed 100%. None of your USDM parts could be used in place of the ones listed.
there is the st205 rebar and the brackets not listed in there which you would need if you wanted the fogs also, (or you could cut your existing bar) and if you did want to get the fogs you would need different bezels, the brackets and the fogs themselves. basicly everything (without fogs) is about $1200 - and yes this is just to replace your hood and bumper. -------------------- |
Nov 3, 2006 - 1:44 PM |
wow... ok thanks
Nov 7, 2006 - 8:57 PM |
Enthusiast Joined Oct 31, '02 From Boise, ID Currently Offline Reputation: 2 (100%) |
Also a little note: There is an "optional" gt-4 hood latch if you go for the new hood. You either have to 1) buy this 2) know how to weld or have a friend who does or 3) live with a hood this has to be slammed pretty hard, and is tough to get open. Personally, I would strongly discourage 3 (since what you are actually doing if you don't modify is using just one of the two latch systems (there is the latch controlled from the driver's seat, and the emergency backup one you undo from the front.))
You can fabricate the grills yourself if you are gutsy. I know if I did it it would look aweful, so I just broke down and bought all the stuff. -------------------- psalm 69 |
Nov 8, 2006 - 12:03 AM |
Enthusiast Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
QUOTE(ScoobyDooCruiser @ Nov 7, 2006 - 6:57 PM) [snapback]500405[/snapback] Also a little note: There is an "optional" gt-4 hood latch if you go for the new hood. You either have to 1) buy this 2) know how to weld or have a friend who does or 3) live with a hood this has to be slammed pretty hard, and is tough to get open. Personally, I would strongly discourage 3 (since what you are actually doing if you don't modify is using just one of the two latch systems (there is the latch controlled from the driver's seat, and the emergency backup one you undo from the front.)) You can fabricate the grills yourself if you are gutsy. I know if I did it it would look aweful, so I just broke down and bought all the stuff. about your third point, i am using the stock latch and both the main latch and safety latch engage when i close it. but as i posted in another thread, you either need the gt4 latch or modify the safety latch hook to extend it by about half an inch if you have the gt4 bumper. without the bumper, my stock latch works fine as the gap leaves me room to get my fingers in, just have to press it a little to disengage the safety latch. but with the gt4 bumper, i wouldnt be able to open my hood. oh by the way, if you get the gt4 latch, make sure its a LHD one from europe as the cable from the RHD one enters from opposite side. -------------------- I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Nov 13, 2006 - 9:59 PM |
im thinking of a 3sgte swap and i heard that you cant fit it in without the gt4 hood. is this true? and if i moved the intercooler to the front bumper would it fit then?
thanks |
Nov 14, 2006 - 1:33 AM |
a st205 and st185 will fit with your current hood/bumper.
Nov 16, 2006 - 12:08 AM |
great! i was thinking i needed to save up another 2 thousand or so
Lo-Fi Version | Time is now: December 2nd, 2024 - 4:03 AM |
