> what did I do this time?, could it be the clutch?
post Nov 8, 2006 - 3:26 AM
6strngs
Joined May 12, '06
From Wilmington, NC
yeah, so yesterday when I was driving, I noticed it extremely hard to push the shifter into a gear and when it did go in it would grind occasionally. well, I let it go overnight, and drove today and it was fine. then on my way home from work tonight, I started the car, started to move, shifted to second fine, then came to a stop at the end of the driveway, when I pushed in the clutch it felt kinda shaky. then I could not put it in gear. I pumped the clutch a few times and still nothing. it wouldn't go into any gear. after about 5 minutes I finally was able to force it into 1st. I started going and then pushed it into second with some difficulty. lucky for me it was 11 o clock at night, so there weren't many people around and all the lights stayed green for me, so I drove all the way home in second never going more than 30 mph, lol. anyway, I was wondering what this could be... on my way home, I noticed if I pressed in the clutch, the rpms dropped slower than they usually do, and with the clutch fully pressed in if I rev the engine, the my speed would inrease ever so slightly... this sounds like the clutch to me, but I want to know for sure. I knew the clutch has been slipping lately, and I knew it would need replacing sometime, I'm just wondering if I killed it once and for all, or if this is something else not related to the clutch.
Replies (1 - 5)
post Nov 8, 2006 - 4:14 PM
6strngs
Joined May 12, '06
From Wilmington, NC
nobody knows? at least tell me some other things to check before I drop a bunch of money on a new clutch.
post Nov 8, 2006 - 4:26 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
well if it's been slipping for a while you should buy a new clutch anyway. then change your tranny fluid after you do that.
I <3 Dustin---07/16/06
post Nov 8, 2006 - 4:43 PM
ra65_22re
Joined Aug 21, '06
From washington
i had that happen to me before. it was the clutch. now i have no problems at all.
post Nov 8, 2006 - 10:01 PM
bindertch
Joined Aug 18, '04
From Silverdale, WA
QUOTE(hurley97 @ Nov 8, 2006 - 1:26 PM) [snapback]500698[/snapback]
Don't forget to check the master and slave cylinders first. If one of them or the lines between them are bad then it would explain the problems. It could also be a air bubble in the line. Try bleeding the system first then check the cylinders for leaks and then the clutch.
post Nov 8, 2006 - 10:15 PM
bigal004321
Joined Jun 21, '05
From New york
yeah i would say a slave cylinder, but check everything bindertch said in his post first b4 you buy a clutch
bigal
1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
Lo-Fi Version Time is now: February 25th, 2025 - 6:16 PM
