> Headlight Condensation, What to do?
post Jul 2, 2003 - 4:59 PM
6JenCelica
Joined Apr 9, '03
From Long Island, New York
My high beams have some condensation in them.... its driving me absolutely nuts. Anybody have any suggestions on what to do to get it out or what is causing this? It rained here for about two months straight... does that have anything to do with it?
Thanks in advance!
Jen
Replies (1 - 30)
post Jul 2, 2003 - 5:47 PM
celi_gt_racer
Joined Feb 6, '03
From huntingdon tennessee
ive had the same problem Jen ... i had condensation in my passengers side high beam.. it pissed me off to no end.. but its wrecked now.. so i might as well not worry about it frown.gif .... any advice on how to fix condensation would be great to hear biggrin.gif
post Jul 2, 2003 - 6:31 PM
speedracer_2020
Joined Jun 22, '03
From Toronto, Ontario, Canada
Ok guys, this may sound gehtto.. but...
Un fasten your bulb .. and use a hair dryer hot air into there. The rubber seals are all on the male ends of the light stuff.. sooooooooooo go nuts. The water will dry up!
I've done it countless times. Believe me.
"Stealing Ideas from Pretty Girls" 1 - "Buying new headlights" 0
Shaun
post Jul 2, 2003 - 10:22 PM
Guest_Matthew_*
get some JDM clear headlights
w00t
post Jul 2, 2003 - 10:27 PM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
I've got the same problem. I was thinking about taking the light housing out and putting silicone sealant wherever there are two pieces of plastic that connect. I don't know if it will work though. confused.gif
post Jul 3, 2003 - 1:52 AM
dcgoalie312
Joined Dec 20, '02
From OKC
check for a small hole or two on the front of the headlight. i had the same problem and i had a hole in the glass so i had to but a new headlight mad.gif , but it looks so much better now i am happy i did it
post Jul 3, 2003 - 2:23 AM
Mynzeyes
From Franklin/Nashville, TN
drill a hole in the bottom. problem solved. smile.gif.
-John-
AIM==Mynzeyes
post Jul 3, 2003 - 5:37 AM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
QUOTE (Mynzeyes @ Jul 2, 2003 - 11:37 PM)
-John-
John: That won't always work... especially on cold and dense days... It'll help release the water, but not evaporate it.
Jen: You'll either need to isolate the source, or just relace the whole assembly if you can't find the cause of the problem.
post Jul 3, 2003 - 7:41 AM
macavely
Joined Nov 4, '02
i have that same problem too this it was you have to do.. take the casing off.. and drill 3 holes at the bottom if the case and 2 on the back next to the bulb and one on top... problem solved..
post Jul 4, 2003 - 2:37 AM
Blackcelliman
Joined Nov 8, '02
From Narragansett,RI
I've had a little condensation in my drivers side high beam ever since I got the car 3 years ago. It hasn't gotton any worse and the light has never blown out. I just deal with it because I don't want to mess with it.
post Jul 4, 2003 - 8:37 PM
pflau
Joined Apr 8, '03
From New York City
YIKES.. what's all these talk about drilling people..
Ive got the same problem forever.. and its on the passenger side high beam. and I dont mean condensation.. I mean dripping wet.. water on the inside of the lense.
so what do I do?? unscrew the bulb and let the housing air out. parking it under the sun helps the most.. especially during summer. and since it's only one light.. its gotta be that the seal isnt very good. so I take care not to aim at the light when I wash my car.
but of course.. since I dont use the high beam much.. I can just let the bulb unscrewed for weeks at a time and the water would eventually evaporate.
post Jul 5, 2003 - 2:13 PM
Celica2085TA
Joined Sep 18, '02
From Masachusettes
my headlight don't have any water in them if you want to get rid of the water this is what you should do. order the jdm headlights and ship them to me and ill send you the original headlights for FREE yes you herd me FREE absolutly no charge that way you won't have to deal with drilling holes lol
post Dec 28, 2003 - 1:58 AM
holson
Joined Aug 12, '03
From Boston, MA, USA
mine came with a lot of water in the driver's side high beam assembly. I used a hand pump and pumped the water out of the headlights and use some towel to try and dry as much as I could and as soon as the dry cold weather came, the headlight dried itself up.
post Dec 28, 2003 - 3:09 AM
subsolo_21
Joined Nov 26, '03
From McKenzie, TN
People...Dont drill holes!!!
All you have to do is use silicone to seal the housing and, shabang, you've got it. I would check for holes in the glass 1st, but if that isnt it go with the silicone.
post Dec 28, 2003 - 12:26 PM
Uriel
Joined Sep 28, '03
From Brighton, MI
QUOTE (pflau @ Jul 5, 2003 - 1:37 AM)
I had the same prob. on my drivers high beam....and I did the same thing as pflau! I just pulled out the bulb and left it for a couple of weeks...WORKED LIKE A CHARM!!! wink.gif
post Apr 12, 2004 - 1:11 PM
mikew04
Joined Feb 19, '04
From austin tx
sorry to bring back an old thread, but i have the same problem. how do you get the housing out? drivers side FYI
thanks
post Apr 12, 2004 - 1:36 PM
kuya1284
Joined Nov 15, '02
QUOTE (mikew04 @ Apr 12, 2004 - 11:11 AM)
thanks
remove the bumper.
post Apr 12, 2004 - 1:46 PM
mikew04
Joined Feb 19, '04
From austin tx
oh. well that will be fun.
post Apr 12, 2004 - 2:44 PM
celicarocker
Joined Sep 25, '03
From cranston RI
i have about an inch of water in my drivers side high beam.... im gonna drain it and fix the problem when i put my kit on....
post Apr 12, 2004 - 4:27 PM
saleeka
Joined Sep 4, '03
From Twin Cities MN
my driver side high beam is bad too... last month I tried to take my bumper off to fix it with no sucess- i even snapped one of the screws from under the hood frown.gif ...
post Apr 12, 2004 - 7:24 PM
mikew04
Joined Feb 19, '04
From austin tx
how hard is it to take off the bumper? anything i should know?
post Apr 12, 2004 - 8:20 PM
bonzaisushi
Joined Oct 3, '02
From bonzaisushi@hotmail.com
mani have bout a inch of water 2..... i figure if it fills up enough ill put a fish in there....
post Apr 12, 2004 - 11:27 PM
saleeka
Joined Sep 4, '03
From Twin Cities MN
QUOTE (mikew04 @ Apr 13, 2004 - 12:24 AM)
from my experence, and from what ive heard from some, damn hard... especially the bolts inside the fender- hard to get to....
post Apr 18, 2004 - 6:18 PM
mikew04
Joined Feb 19, '04
From austin tx
no kidding. there are 3 in the fender, damn impossible to get to. and the plastic clips that you unscrew a little, then they pop out? yah, those are about the most un-reliable things in the world. I finally got the bumper off, got the light out, used a little bleach where the water left stains, and im gonna seal it up with some silicone. hopefully this will work, and ill just have to drive without the bumper cover for a few days.
post Apr 18, 2004 - 6:31 PM
celicaman96
Joined Sep 21, '02
From SLC, UT
Here's what I did before I eventually had to replace my high beam...
Take a shop vac (or a regular vaccuum, but it WILL get ruined). Duct tape a good length of plastic tubing (about .25" in diameter and about a foot long - you can get it at any hardware store) to the end of the vac hose to make a seal. Take out your bulb, stick the tubing into the headlight and turn on the vaccuum. If the tubing you get is firm enough you can run it all around the inside of the light and up against the inner part of the lense where the condensation builds up; yet it needs to be a little flexible too. Problem solved, no bumper removal.
PS - I ruined my moms vaccuum doing this, it was a regular vac and I sucked a ton of water with it. Use a wet/dry shop vac wink.gif
post Apr 18, 2004 - 7:12 PM
sinner96ST
Joined May 15, '03
From Aurora IL
I have this happen in my passenger side high beam all the time... it's not a lot of water, just some condensation.. it eventually evaporates on its own. A buddy of mine had a tiburon (97 i think) and it had water in the headlight casing after only a few weeks straight from the factory.
post Apr 19, 2004 - 2:24 PM
UT_Celica_GT
Joined Dec 9, '03
From Utah
I have condensation in my driver side high beam too! I'm glad I'm not the only one. I was thinking about the hair dryer idea lmao. It is starting to get on my nerves. it's not a lot of water, just condensation on the front of it.
post Apr 19, 2004 - 5:39 PM
celicarocker
Joined Sep 25, '03
From cranston RI
i have some inches.... i was thinking about putting a fish in there.... that would be a nice mod... i could mod a little door on the inside so i could feed it...
post Apr 19, 2004 - 7:24 PM
mikew04
Joined Feb 19, '04
From austin tx
you could have a whole habitat in there. like those things where you put soil, grass, plants and stuff, and then you can have frogs and salamanders live in there! hmm, i forget what they are called.... damn i should have left that water in there... tongue.gif
post Apr 19, 2004 - 7:34 PM
Pali_playa
Joined Apr 4, '04
From VA, USA
ecosystems?
post Apr 19, 2004 - 9:19 PM
mikew04
Joined Feb 19, '04
From austin tx
Thats it!
Lo-Fi Version Time is now: November 24th, 2024 - 2:30 AM
