Fitting Speakers, 6.5 inch speakers? |
Nov 25, 2006 - 12:56 PM |
Enthusiast Joined Nov 13, '06 From Windsor, CT Currently Offline Reputation: 0 (0%) |
I just came back from Bestbuy with 4 rockford 6.5 inch speakers. The size of the speakers were said to fit in my 95 ST hatch, but when i got home, the speakers were slightly smaller than the stock ones. Now i have 4 speakers that dont even fit, does anyone know for sure the size of the front and rear speakers for 95 ST hatch?
Nov 25, 2006 - 3:57 PM |
Enthusiast Joined Jul 22, '06 From San Antonio / georgetown, Texas Currently Offline Reputation: 9 (100%) |
think its 8in in the front and 6.5 in the back. i just made some ghetto brackets to hold the front 6.5 speakers in.
This post has been edited by D_Dawg: Nov 26, 2006 - 7:50 PM -------------------- |
Nov 25, 2006 - 6:54 PM |
Enthusiast Joined Dec 19, '02 From West of Atlanta Currently Offline Reputation: 1 (100%) |
The true size is closer to 6-3/4" but the 6-1/2" can be installed pretty eaisly. Eaisest way I've found without using an adapter is to use the new speakers grill ring as an adapter. Mount the speaker to the ring without the grill installed then screw the whole thing to the stock mount. The last ones I did the ring just barely covered the stock holes so I just notched the ring with a file and screwed it down. If you want you can also put a washer under the head of the screws but they shouldn't go anywhre even without the washers. I might not look pretty but behind the door panel you can't see it and it works great.
Nov 25, 2006 - 8:44 PM |
Enthusiast Joined Sep 2, '05 From Fort Madison, IA Currently Offline Reputation: 0 (0%) |
actually in the front of most celicas its 8" and in the back its 6 3/4" but you can fit 6.5 in the back and what i found out is that kicker comp vr 8s work great in the front
i have kickers in the front and clarion 6.5s in the back and it sounds great -------------------- |
Nov 25, 2006 - 9:54 PM |
guess im just gonna make a ghetto bracket somehow, thanks guys
Nov 26, 2006 - 7:46 PM |
Enthusiast Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) |
I ghetto rigged my front door speakers with some Locktite glue and some slivers of Dynamat. They're holding up pretty well so far.
http://www.6gc.net/forums/index.php?showtopic=42982 -------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
Lo-Fi Version | Time is now: December 1st, 2024 - 11:18 PM |
