Enthusiast ![]() ![]() Joined Nov 4, '03 From Vancouver, Canada! Currently Offline Reputation: 0 (0%) ![]() |
ok,
Looks like i will be needing to replace my rear wheel bearings. All the shops in town only carry the hub+bearing assembly. I have however found a wheel bearing module. It is only the bearing and not the hub and is at a fraction of the cost.... $300 for the assembly and $80 for the module. I haven't taken apart the bearing/hub assembly and am not sure if I will be able to savage the remaining needed parts.... Need some wise info from all you gurus on the best plan of attack without killing my wallet! |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
you could always go to a junkyard and try that.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 22, '03 From NOVA Currently Offline Reputation: 16 (100%) ![]() |
advanced auto sells JUST the bearing assembly
http://www.partsamerica.com/ProductDetail....186&ptset=A ![]() except the thing is toyota presses in the wheel hub then presses the hub and nut so you can't really remove it not sure if you'll be able to tell from this picture what i'm talking about but at about "2 o'clock" you can see where there is a pressed notch thats what is extremely hard to undo ![]() basically to seperate wheel hub from bearing hub = HUGE HUGE HUGE biznatch This post has been edited by playr158: Dec 14, 2006 - 12:02 AM |
theres a few members parting put celicas, try one of theirs, you can put an ST hub on but you wont have your abs on.
![]() Enthusiast ![]() ![]() Joined Mar 25, '06 Currently Offline Reputation: 0 (0%) ![]() |
QUOTE you can put an ST hub on but you wont have your abs on. Im not sure what you are talking about... MY st has ABS ? -------------------- ----- '94 ST hatch --- Yellow ----- |
st hub will fit on a gt but doesnt have abs on it so your abs light will be on and unactive.
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) ![]() |
^^^ Wrong, just that one wheel will be inactive.
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
all 4 of mine locked up on me when i went skidding 40 feet to swerve out of the way of an idiot turning into me
QUOTE(celicast3sgte @ Dec 14, 2006 - 1:23 AM) [snapback]510343[/snapback] ^^^ Wrong, just that one wheel will be inactive. WRONG, when ANY fault is found on the ABS system the whole ABS system is disabled. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(playr158 @ Dec 14, 2006 - 5:01 AM) [snapback]510312[/snapback] advanced auto sells JUST the bearing assembly http://www.partsamerica.com/ProductDetail....186&ptset=A ![]() except the thing is toyota presses in the wheel hub then presses the hub and nut so you can't really remove it not sure if you'll be able to tell from this picture what i'm talking about but at about "2 o'clock" you can see where there is a pressed notch thats what is extremely hard to undo ![]() basically to seperate wheel hub from bearing hub = HUGE HUGE HUGE biznatch it doesn't say if this has abs or not? anyone know. i did the st search and came up with the same part number. my car is a gt but no abs -------------------- ![]() |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) ![]() |
QUOTE(Bitter @ Dec 14, 2006 - 8:32 AM) [snapback]510386[/snapback] QUOTE(celicast3sgte @ Dec 14, 2006 - 1:23 AM) [snapback]510343[/snapback] ^^^ Wrong, just that one wheel will be inactive. WRONG, when ANY fault is found on the ABS system the whole ABS system is disabled. This is correct. ANY ABS fault detected will disable the entire system. A single tire locking up in a panic braking condition with the others still rolling woudl cause a sudden pull to that side, possibly causing loss of control. -------------------- |
QUOTE(rjbibeau @ Dec 14, 2006 - 10:04 AM) [snapback]510402[/snapback] it doesn't say if this has abs or not? anyone know. i did the st search and came up with the same part number. my car is a gt but no abs GT but no abs that hub will work..GT hub and ST hub are the same its ABS vs NON-ABS that i believe is the difference...though i've only ever done hub work on NON abs cars so ive never seen the difference i'd trust my good friend lew on that info ![]() |
all hubs ive seen are non-abs.
what do people with ABS do? |
the abs ones have a larger hole in the center with this spindle looking thingy on the end, it just lets the sensor know somehow.
QUOTE(LewFX @ Dec 14, 2006 - 3:08 PM) [snapback]510485[/snapback] the abs ones have a larger hole in the center with this spindle looking thingy on the end, it just lets the sensor know somehow. via telepathy is how it lets the sensor now....its got ESPN ![]() |
has anyone that has ABS replaced their rear bearings?
i was just gonna ask the same thing. also has anyone ordered their rear bearings from that parts america place.
parts america = Advanced auto
so i'll probably be ordering set right after new years |
QUOTE(wind @ Dec 15, 2006 - 3:43 PM) [snapback]510799[/snapback] has anyone that has ABS replaced their rear bearings? yea, i bit the bullet and got one from a dealer, i couldnt find one with the abs tone ring anywhere else ![]() -------------------- |
Totoyta wants $470 (Canadian) each for ABS rear bearing + hub assemblies.....
Can anyone find me a better price? |
Lo-Fi Version | Time is now: February 18th, 2025 - 7:00 PM |
