> noisy belt when a/c is on
post Dec 17, 2006 - 11:33 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
does anyone else belt make noise when you turn on the a/c?? i assume its the a/c belt.
Replies (1 - 5)
post Dec 18, 2006 - 12:37 PM
tin_foil
Joined Jun 7, '05
From Corvallis, OR
yeah, is it a sort of squeeking noise? 90% possibility its the a/c belt. You might be able to just tighten it, or you could buy a new one, they should only be a few bucks.
post Dec 18, 2006 - 12:39 PM
6gcSTVT
Joined May 3, '06
From New Hampshire
QUOTE(tin_foil @ Dec 18, 2006 - 12:37 PM) [snapback]511408[/snapback]
Darin H.
post Dec 18, 2006 - 1:24 PM
depends on the noise.......
belts don't make noise in general when they are in good condition
This post has been edited by playr158: Dec 18, 2006 - 1:25 PM
post Dec 18, 2006 - 1:41 PM
tin_foil
Joined Jun 7, '05
From Corvallis, OR
QUOTE(playr158 @ Dec 18, 2006 - 1:24 PM) [snapback]511417[/snapback]
post Dec 18, 2006 - 2:24 PM
which is covered by the "when they are in good condition"
reading comprehension > u
the compressor if bad will also make a noise, and if yours has a clutch that could be the problem too..
even when the a/c is off the belt spins :rollseyes: so if it were loose it would make noise 24/7
which i'm not ruling out a loose belt.....too many of u e-mechs say its 1 thing...and u can't diagnose it down to 1 certain thing without actually seeing the car...so variety of options helps someone asking a question
Lo-Fi Version Time is now: January 10th, 2025 - 8:13 AM
