> Short Shifters vs Quick Shifters, Whats the difference
post Dec 20, 2006 - 1:27 AM
alaNi
Joined Nov 24, '06
From Kansas City
which one is better / diffrences ? thanks
Replies (1 - 3)
post Dec 20, 2006 - 6:19 PM
JesterDC
Joined Jun 21, '06
No difference, both shifters are short so that they're quick.
post Dec 21, 2006 - 11:23 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Short shifters are exactly that. Short. Go look for pictures of celicas with a TWM short shifter. Its a little stub.
Quickshifters aren't much shorter than stock and only reduced throws by 40%. I have the TRD shifter and I like it. I don't know if I would like the TWM.
**** Photobucket
post Dec 21, 2006 - 11:30 AM
uberschall
Joined Jul 29, '03
From north of detroit
for most people, the biggest difference is price.
the cheapest i've seen a trd quickshifter is $125, but an aftermarket short shifter can be had for as little as $25 off ebay. i actually made a short shifter myself, so it was essentially free.
mechanically, they do effectively the same thing. the higher the fulcrum is placed on the shifter rod, the shorter the distance the knob will have to move to engage a gear. the trd unit does this by moving the plastic cup that the ball rotates in a little higher to allow a longer lower arm. an aftermarket or homebrew will extend the lower arm less, but compensate with a shorter upper arm.
there are plenty of threads about installing aftermarket ones, or check the how-to's.
do you know who i am, mr. worley?
Lo-Fi Version Time is now: November 30th, 2024 - 7:37 PM
