> cone filter - does it really make a difference?, newb questions
post Jan 2, 2007 - 12:48 PM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
Hi,
I notice that most members' cars have a cone filter fitted.
I picked up an unbranded burgandy red cone filter for a couple of pounds at my local scrappy. It looks brand new. Considering using it on my Celica, but does it really make a difference over the stock Toyota panel filter? Perhaps I should look at a K&N panel filter to go in the stock air filter box?
Also, being in the UK and as my Celica is my daily drive, the engine bay gets quite damp, salty and grubby. How do cone filters cope with water and dirt build-up? Should I be looking to box the cone filter in a similar way to the stock air filter box?
Finally, where is a good place to fit a mass air flow sensor with the stock setup and with the cone filter fitted?
This post has been edited by BloodyStupidDavey: Jun 16, 2007 - 12:03 PM
Replies (1 - 19)
post Jan 2, 2007 - 1:02 PM
tin_foil
Joined Jun 7, '05
From Corvallis, OR
Well, yes cone filters make a difference. Simply by providing less resistance for the air flow than stock boxes. But the reality is that slapping an unbranded cone filter on will probably get you 1-3 more hp at best. Unless you plan on showing off your engine bay to a lot to people who have no idea what they're looking at, and you really want to impress them with some colored filter thing sitting in there, I'd stay stock. biggrin.gif Especially cause of what you said about dirt and grime. Whatever you do, just don't put the cone filter in a box. That's not what they were designed for. You'll probably end up getting 0 to -2 hp. wink.gif Keep asking questions, it's the best way to learn.
post Jan 2, 2007 - 1:21 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
post Jan 2, 2007 - 1:43 PM
hitcachi
Joined Jun 19, '05
From Nebraska
everybody wants teh blingz in the engine too!
post Jan 2, 2007 - 2:17 PM
neo_in_aus
Joined May 2, '03
From Sydney, Australia
Most people use cone filters for the 'bling' factor because they generally look good in a well maintained and cleaned engine bay. Sad thing about it is, unless you pipe in cool air directly to the cone filter, you are actually harming performance of your car by only sucking in hot air. Hot air is less dense than cold air, and as such you get less bang for your buck.
So unless you are planning on showing off your engine bay quite a bit, i would get the K&N drop in filter or equivalent. I have been using a K&N drop in filter and it works great. you just have to make sure to regularly clean the filter, however any replacement filter that is not a cheap paper filter will have the same requirement.
post Jan 2, 2007 - 5:28 PM
BloodyStupidDave...
Joined Nov 14, '06
Thanks for all the replies.
QUOTE(neo_in_aus @ Jan 2, 2007 - 7:17 PM) [snapback]514625[/snapback]
But does it make a difference over the stock Toyota panel filter? biggrin.gif
Davey
post Jan 2, 2007 - 5:46 PM
uberschall
Joined Jul 29, '03
From north of detroit
QUOTE(BloodyStupidDavey @ Jan 2, 2007 - 3:28 PM) [snapback]514656[/snapback]
Davey
in a word, yes. in multiple words - a high performance filter (like a k&n) panel filter is designed to pass a higher volume of air by presenting less restriction (while maintaining a high level of filtration). oiled cotton filters require maintenance (washing and re-oiling), but the upside is that you can actually save money by purchasing one instead of a paper filter, which simply has to be discarded when it gets clogged/dirty.
i put a k&n in my last celica, and i'm putting one in my current one too.
do you know who i am, mr. worley?
post Jan 2, 2007 - 5:47 PM
manphibian
Joined Oct 13, '06
From UK
QUOTE(BloodyStupidDavey @ Jan 2, 2007 - 5:28 PM) [snapback]514656[/snapback]
Davey
I had a pipercross panel filter, which did make a difference over stock, then i got a K&N induction kit (cone) and that was better still.
As long as (mentioned above) you have a cold air feed going to it. The K&N 57i kit comes with a cold air hose and fixings.
And the cone filter gives the advantage of giving your engine a really cool, roaring noise biggrin.gif
And i'm in the uk and mine is fine.
Go for it, as long as you fit some kind of cold air feed (from under the car)
This post has been edited by manphibian: Jan 2, 2007 - 5:50 PM
post Jan 2, 2007 - 8:54 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Open element filters, cone, paper, foam, whatever it is... is mostly for the sound. The power increase is too small to really notice.
post Jan 2, 2007 - 9:47 PM
hashmaster52
Joined Dec 3, '05
From San Jose, CA
QUOTE(tin_foil @ Jan 2, 2007 - 1:02 PM) [snapback]514605[/snapback]
lol yea but alotta times ur told 2 search.
post Jan 3, 2007 - 3:10 AM
manphibian
Joined Oct 13, '06
From UK
QUOTE(Kwanza26 @ Jan 2, 2007 - 8:54 PM) [snapback]514706[/snapback]
I disagree. When i installed my cone and cold air feed, the difference WAS noticable! The throttle response was a lot faster and any flatspots in the acceleration were removed.
There is no doubt that increased cold air flow into the engine makes a difference.
post Jan 4, 2007 - 12:55 AM
Jaws4God
Joined Mar 27, '04
yeah i mainly did mine for looks.. but I do like the sound of it..
post Jan 4, 2007 - 1:11 AM
ExSane
Joined Apr 17, '06
From under your bed.
THIS LINK WILL GIVE YOU ALL YOUR ANSWERS.
http://www.6gc.net/index.php?action=information&itu=11
If I were you, go for the K&N Drop In Filter. Esp with your situation with dirtiness of your engine bay. My 2 cents.
post Jan 5, 2007 - 10:19 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(manphibian @ Jan 3, 2007 - 8:10 AM) [snapback]514772[/snapback]
we're not talking about cold air. Open element filters tend to get hotter if anything...
post Jan 6, 2007 - 3:46 AM
tin_foil
Joined Jun 7, '05
From Corvallis, OR
QUOTE(Kwanza26 @ Jan 5, 2007 - 10:19 AM) [snapback]515344[/snapback]
^x2. Your cool air feed is the only thing you feel making a difference. Just a cone isn't going to make any noticible difference.
post Jan 12, 2007 - 2:47 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
QUOTE(tin_foil @ Jan 6, 2007 - 3:46 AM) [snapback]515594[/snapback]
Agreed, although you're getting more air, it's gonna be hotter which can actually be worse. The cold feed is a good idea, especially since most CAI's get wet (very bad) and the feed can somewhat bypass that. Make sure your feed is placed in angles that water cannot travel up. Also it's always good to create a heat shield for you filter. They're not too hard to make and there are examples everywhere. It's just too bad no one makes perdy ones for our cars already.
post Jan 12, 2007 - 2:53 PM
nate95
Joined May 5, '05
From mattoon, IL
go with out the filter!! lol. not smart, but does add more power. and better throttle response.
post Jan 12, 2007 - 6:39 PM
Rockford
Joined Dec 22, '06
From Caracas-Venezuela
I would prefer.. the K&N OEM replacement...
Celica ST202
post Jun 15, 2011 - 3:51 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
back from the dead, I just hate creating new threads. I'm looking for a drop in filter, thats not oem. Well OEM is my cheapest option at around $20 with taxes included. The best filter I'd go for within my budget would be $50 for the K&N. The reason I don't want K&N is because I don't like oiling it and cleaning it. I currently have a cone K&N and it just doesn't seem to stay red with the oil I put on it after every 5,000 miles.
Whats the best DRY drop in filter for Under $45???
post Jun 16, 2011 - 1:44 AM
trdproven
Joined Aug 2, '05
From Guam
TRD is within your budget but it is an oiled version. never heard of a drop in dry filter for our celica. In fact, i think its a waste of money to get a drop in filter. Although it does bring in a percentage improvement of air flow but it misses the two significant things we look for. #1 Most Air Flow Possible such as a cone filter that gives most potential performance increase for that particular system and #2 Sound (by preference). A drop in filter is really just for some unnoticeable improvement and keeping it stock profile sound and looks. Or perhaps thats what you are looking for?
I've owned:
TRD Drop In Filter
Injen
Fujita
Weapon R
Apexi
and generic unbrand
This post has been edited by trdproven: Jun 16, 2011 - 1:53 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: November 27th, 2024 - 11:34 PM
