> Camber Adjustment, I have a slight problem
post Jan 3, 2007 - 1:42 PM
y2komar
Joined Sep 21, '06
From New York City
I have a 94 gt. Dropped with h&R springs and KYB shocks rear and front.
I took it to get alighned and they said because of the drop the camber is off slighly.
I have the upper mount of the springs with a preset camber adjustment. Is there something else i can do to adjust it better.
What do you guys have.
Even after the alighnment the car still turns towards the right.
Replies (1 - 8)
post Jan 3, 2007 - 1:44 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
Get some "crash" alignment bolts to allow camber adjustment
post Jan 3, 2007 - 1:58 PM
y2komar
Joined Sep 21, '06
From New York City
QUOTE(bufferdan @ Jan 3, 2007 - 1:44 PM) [snapback]514828[/snapback]
Sorry I dont know what you are talking about?
What is a crash alignment bolt?
How do you install them.
Thank you
post Jan 3, 2007 - 2:15 PM
y2komar
Joined Sep 21, '06
From New York City
I found this online
These bolts are used for crashed cars that have suspension damage and cannot be returned to stock camber. The bolts are available in three sizes: 1 Dot, 2 Dot and 3 Dot. The part numbers are as follows:
1 Dot 90105-15004
2 Dot 90105-15005
3 Dot 90105-15006
Each successive bolts will change front camber by -0.5 degrees. I used 2 Dot bolts in my car to get close to the camber I wanted, since 3 Dots would give me more than I wanted. The alignment I ended up settling on was as follows:
Has anyone done this?
Then, how did you get the proper alignment?
post Jan 3, 2007 - 2:35 PM
get a set of CUSCO upper pillow mounts for the front
http://www.japanparts.com/Pic/pic075/058.htm
http://www.japanparts.com/db/partslist.php...er=&volkey=
post Jan 3, 2007 - 4:51 PM
Rayme
Joined Feb 18, '06
From NB, Canada
Just get the eibach or obx camber adjustment bolt...its basicly bolts with cams on them.
Its what I have and my alignment is all in specs now(mind you I installed the bolt myself using my eyes as aligment! lucky sob).
This post has been edited by Rayme: Jan 3, 2007 - 4:54 PM
-Rémy
02 SiR, 08 250R
post Jan 3, 2007 - 10:35 PM
y2komar
Joined Sep 21, '06
From New York City
QUOTE(Rayme @ Jan 3, 2007 - 4:51 PM) [snapback]514878[/snapback]
Thank you for the help. This is what I found I hope it works well.
IEC-35450 Adjustable Camber Kit, Eccentric Bolts, 17mm, Toyota/Lexus/Pontiac/Scion, Front,
Ingalls Engineering Co
Not all camber kits are created equal!
These adjustable camber kits from Ingalls Engineering have a Posi-Change feature, allowing camber changes up to 3 degrees positive. Each block displays a vertical line above the bushing that represents a 2 degree positive change. Don't trust your wheel alignment to just anyone--Ingalls has been producing camber kits for over 20 years, and you can be assured that you're getting a quality product
post Jan 11, 2007 - 10:13 PM
jdg371
Joined Jun 14, '05
I got a pair of 2 and 3 dots from Toyota for 20 bucks
post Mar 1, 2009 - 4:48 AM
trdproven
Joined Aug 2, '05
From Guam
Do camber kits work only because they are skinnier bolts and you can adjust the angle? thats what it looks like.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: November 23rd, 2024 - 12:32 PM
