> Steering wheel swap guide, this is not common "how-to" but just small guide...
post Jan 6, 2007 - 4:04 PM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
At last I had some time for another upgrade. Steering wheel swap... My stock one was 4-spoke with airbag/horn in the middle.
Just history now biggrin.gif. Since today I have this one wink.gif genuine 7th gen. Celica/91-04 MR2 st. wheel.
Although horn mechanism and airbag connector were different everything is working now. And I'll try describe here how generally do that... believe it will be handy for anyone wink.gif
step no one: remove old steering wheel
Two screws on sides (behind small covers) holds airbag part
There are just two plugs inside. That yellow one is for airbag and white is horn (there is possibility also for cruise multi switch, where are many more wires. Horn wire is black, every time that last on right connected to wheel body)
When you unplug everything + unscrew nut in the middle you should remove wheel with puller (w/o that it's not possible at all)
step two: solving airbag connection
Different airbag connector means find right module (spiral) for it...
Of course... some customization should be done if airbag refill has different size (more are different, more custom work is needed). My one was just bit different... and airbag part was easy take into parts.
step three: solving horn connection
This step depends on type of horn you have. However every time it's about find how horn mechanism works, cut black wire off old wheel and connect it somewhere... It really depends on that horn mechanism. However it's really easy, just one wire to screw... somewhere wink.gif.
step four: piece everything together
Installation of new wheel body (with same center bore of course) is easy...
...and in my case screw horn cable to airbag body (not wheel body like stock one)...and all finished biggrin.gif.
This post has been edited by malpaso: Jan 6, 2007 - 4:27 PM
8 Pages V   1 2 3 > »
Replies (1 - 99)
post Jan 6, 2007 - 4:16 PM
snapshotgt
Joined Oct 12, '05
From Texas
post Jan 6, 2007 - 4:18 PM
zCelicaDude
Joined Nov 20, '06
From Auckland, New Zealand
very nice guide. this will be very helpful to the 6gc community. thanks!
post Jan 6, 2007 - 7:46 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
nice i like it a lot. How much did you get the stearing wheel for?
IPB Image <--- I miss :'' (
post Jan 7, 2007 - 12:35 AM
post Jan 7, 2007 - 2:39 AM
malpaso
Joined Feb 3, '06
thanks for posts and PMs. Here is additional info:
7th gen/MR2/MR-S st. wheel. Where and how much?: I have that st. wheel from e-bay for 250USD (here is another one, red stitched wink.gif)
Why not "how-to article"?: Yes, this should be "how to swap 7th gen st. wheel" article, but only for Euro models. Thanks to snapshotgt I know you have bit different wiring in US (because of that cruise control switch). Euro celicas don't have that at all... That means in US you must swap also that switch -> customize body of that new wheel (cut some hole or anything) and mount it somewhere (some screws in right place???). That's why I rather call it "guide" wink.gif
Is airbag really works? Are you sure?: Yes, airbag really works. When you turn keys on, every time runs "airbag-check" (airbag control light on for a while). If it's something wrong with check, control lights all the time. That's why I'm sure... Of course second way to prove it is crash biggrin.gif.
Do you have part # of that 7th gen module? Will it work in 6gen celi?: par number is not problem wink.gif 84306-32030. And, no I'm not sure it will work with 6gen celica... frown.gif. I don't have that module (I didn't want to spend another 50USD), it's just a general option and possible way to try.
post Jan 7, 2007 - 4:55 PM
tomazws
Joined Oct 30, '04
From So Cal
Nice swap dude! That 7th gen steering wheel looks 100x better!
post Jan 7, 2007 - 10:53 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
aww. i guess i wont be doing it. US import cars are gay.
post Jan 7, 2007 - 11:19 PM
Rockford
Joined Dec 22, '06
From Caracas-Venezuela
Excellent work, congrats!!!!
This post has been edited by Rockford: Jan 7, 2007 - 11:20 PM
Celica ST202
post Feb 10, 2007 - 9:19 AM
CelicaSweden
Joined Oct 14, '06
From Sweden
Which size is the puller?
100mm, 150mm or 200 mm ?
Need to know asap because Im removing my steering wheel right now : )
post Feb 10, 2007 - 10:43 AM
malpaso
Joined Feb 3, '06
QUOTE(CelicaSweden @ Feb 10, 2007 - 3:19 PM) [snapback]525678[/snapback]
That one I have is 3'' (cca 76mm)
post Feb 11, 2007 - 3:16 AM
CelicaSweden
Joined Oct 14, '06
From Sweden
QUOTE(malpaso @ Feb 10, 2007 - 10:43 AM) [snapback]525686[/snapback]
okey, is that a speciel one for just our celi or is it a universal tool ?
post Feb 11, 2007 - 3:28 AM
malpaso
Joined Feb 3, '06
QUOTE(CelicaSweden @ Feb 11, 2007 - 9:16 AM) [snapback]525876[/snapback]
universal one bought in local store...
post Feb 11, 2007 - 11:18 PM
Excursion745
Joined Feb 10, '07
From West Springfield MA
7th gen/MR2/MR-S st. wheel. Where and how much?: I have that st. wheel from e-bay for 250USD (here is another one, red stitched )
Now what if i took out the cruise control.. does that mean i dont need to mod the new wheel or do i still need to put that dead switch in the new wheel???
post Feb 12, 2007 - 2:29 AM
malpaso
Joined Feb 3, '06
QUOTE(Excursion745 @ Feb 12, 2007 - 5:18 AM) [snapback]526071[/snapback]
If you will remove cruise control (that means you will not use it in your car anymore) you should do same steps like I did, plus:
1. remove cruise control switch (for sure it should be removed)
2. modify wiring harness (same plug is used for horn and cruise control switch -> you must cut anything but horn).
For example:
In picture below is plug (white, bottom of picture) and 4 wires. White, white+black-stripe, red, black. That black is horn (must stay) rest you should cut, because those are wires for cruise.
that's all
post Feb 27, 2007 - 10:56 PM
I was lucky enough to get my hands on some 7th gen parts at a good price biggrin.gif
from this
and about an hour later this
sorry about the night pic, but I just finished. I'll get some day pics tomorrow or so.
Martin, the way I did it was easier than the way you did - no airbag repacking, just a splice here and there wink.gif also, I used the 7th gen cruise switch (it's wired different than the 6th gen) so I'm 99% sure it works, I just need to road test it.
post Feb 27, 2007 - 11:13 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
nice. now i'm really thinking about doing this mod. what did you do different from martin's how-to?
post Feb 28, 2007 - 1:43 AM
malpaso
Joined Feb 3, '06
QUOTE(Batman722 @ Feb 28, 2007 - 4:56 AM) [snapback]531085[/snapback]
I'm glad someone had all parts from 7th gen (particularly 7th gen module/spiral) and made it different way...
So, am I understand right, you have used that module and it works even with cruise control??? More info please!!! smile.gif
post Feb 28, 2007 - 8:52 AM
the 7th gen clockspring (spiral) does not fit in the 6th gen. I simpily cut the connector off the 7th gen spiral and used it on my 6th gen one. Both have 2 wires, blue/black and yellow. It made the swap a 15-30min job. As for the cruise it get's a little tricky. The 7th gen switch has 2 wires from it (red and white) and the 6th gen has 3 (red, white, and white w/black stripe). You just have to find the right combination of 2 wires. I tried a few before I got it, I think it was w/bck to white, and white to red (from 6 to 7)
post Feb 28, 2007 - 9:30 AM
malpaso
Joined Feb 3, '06
QUOTE(Batman722 @ Feb 28, 2007 - 2:52 PM) [snapback]531202[/snapback]
the 7th gen clockspring (spiral) does not fit in the 6th gen. I simpily cut the connector off the 7th gen spiral and used it on my 6th gen one. Both have 2 wires, blue/black and yellow....
yea... but you have 50% chance to connect it bad an deploy it wink.gif. Any way to be sure which one is which?
I had black/red on 7th gen and red/red on 6th gen... kindasad.gif
This post has been edited by malpaso: Feb 28, 2007 - 9:31 AM
post Feb 28, 2007 - 11:20 AM
Martin NO !!! I cut here wink.gif not the bag connection itself
I had the 7th gen spiral wthat connects to the 7th gen airbag, the piece you didn't have wink.gif
post Feb 28, 2007 - 12:09 PM
malpaso
Joined Feb 3, '06
post Feb 28, 2007 - 2:27 PM
Negative
Joined Apr 28, '04
From Houston, Texas
There is also a 6th gen steering wheel that looks like that. Mine came with it. The only difference is the center part where the airbag is has embossed Toyota symbol and texture that matches our interior. I have seen them in junkyards before. This should make a much easier swap I would think although I haven't tried it [obviously]. Here is a pic of my stock steering wheel:
Sorry it's crooked but that was the only shot of the wheel that I had. Also several other cars came with it like Supra for instance if you can find one.
post Feb 28, 2007 - 2:41 PM
correct. The 98-99s had a 3 spoke also. IMO the 7th gen airbag looks better and is a lot easier to find.
post Feb 28, 2007 - 6:07 PM
and some more pics
I still need to clean and shine it up but I think you guys get the point.
post Mar 1, 2007 - 2:25 AM
azian_advanced
Joined Apr 18, '05
From Calgary
are all 7th gen steering wheels the same? do any come with leather?
i have a spare 3-spoke non-airbag 6th gen steering wheel from my sister's 94 6th gen and that wasn't wrapped in leather.. the wheel is thick and has a lot less grip.
anyway, my search for the jdm cf supra wheel continues.....
post Mar 1, 2007 - 2:43 AM
malpaso
Joined Feb 3, '06
QUOTE(azian_advanced @ Mar 1, 2007 - 8:25 AM) [snapback]531611[/snapback]
post Mar 1, 2007 - 9:46 AM
Negative
Joined Apr 28, '04
From Houston, Texas
So is my stock 3 post. Well pleather or whatever Toyota uses LOL.
post Mar 1, 2007 - 11:05 AM
QUOTE(azian_advanced @ Mar 1, 2007 - 2:25 AM) [snapback]531611[/snapback]
do they all fit the same with the airbag ? yes. There are 3 7th gen wheels that I know of.
the leather wrapped wheel as Martin pictured
the non-leather wheel that I have
and the leather wrapped GT-S wheel
I went with the non leather because I had removed my leather interior (seats/wheel/knob) and went with more of a cleaner look IMO, just keeping it simple and more subtle. I have seen so many leather wheels and knobs showing their age being worn and I'd rather not deal with that issue a few years down the road.
post Jul 8, 2007 - 4:17 PM
kerosene
Joined Jul 4, '07
From US
even though o wasn't replacing my steering wheel, I was fixing my horn, this helped a great deal...Thanks...btw i took my pillow off without a puller...
post Jul 9, 2007 - 7:00 AM
Kadett
Joined Mar 17, '05
From The Netherlands
I really want one. To bad there aren't any available here in Holland for a descent price. I dont need the airbag but no junkyard will sell without and asking price = 400 euro's (550 USD)
post Jul 11, 2007 - 3:13 PM
dutchboy
Joined Jun 28, '07
QUOTE(Batman722 @ Feb 27, 2007 - 10:56 PM) [snapback]531085[/snapback]
Hi, have you made a write-up/how-to on the swap process?
Does the 7th gen steering column bolt right up?
What wires and where do you splice?
Did the cruise control work properly?
Thanks, really want to do this on my car!
post Jul 23, 2007 - 10:17 AM
Kadett
Joined Mar 17, '05
Found Myself a nice Leather 7th gen steering wheel completely intact. Cant wait to put it on. Since I dont have a Wheel Puller I will pay Mr T a visit and lend it there laugh.gif laugh.gif laugh.gif
post Jul 25, 2007 - 4:48 AM
dutchboy
Joined Jun 28, '07
Anyone know if the 6th gen cruise control switch will mount into the 7th gen wheel (US).
Thanks
post Jul 25, 2007 - 4:57 AM
malpaso
Joined Feb 3, '06
QUOTE(dutchboy @ Jul 25, 2007 - 11:48 AM) [snapback]582133[/snapback]
Thanks
IMO it will. It's just about one screw to fit...
post Jul 25, 2007 - 8:19 PM
dutchboy
Joined Jun 28, '07
Is the back side of the 7th gen wheel metal or plastic? Tan corolla 3-spokes are fairly common/cheap, if metal, paint will look pretty good, then I can re-upholster the grips whatever color I want.
post Jul 25, 2007 - 8:26 PM
Now all you have to do is test the airbag to see if it works. laugh.gif laugh.gif laugh.gif
No, really, very nice mod. I would be scared to do this, epecially messing with the airbag module.
CONGRATS!!!!!
post Jan 22, 2008 - 10:23 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
Nice write-up, man.
Just out of curiosity, if I were to purchase a momo wheel in the near future (and yes I would have the hub adapter), how difficult would it be to install? Obviously there would be no issue with wiring the airbag but has anyone installed an aftermarket steering wheel?
"He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn."
"What?"
"Just do it."
".......He said yes."
"Tell him you are not darklings. He should open up."
".......Sweet. Thanks."
"No problem."
post Apr 1, 2008 - 8:42 PM
tankd0g
Joined Oct 4, '07
From Nova Scotia
QUOTE(Negative @ Feb 28, 2007 - 2:27 PM) [snapback]531328[/snapback]
Slightly OT but how come there's a GT-2 sticker on your cruise control, is that how you turn the car into attack mode? smile.gif
post Apr 2, 2009 - 1:04 PM
reko
Joined Apr 17, '07
From Montreal, QC, Canada
Taking the thread back from the dead lol….
Quick question here… what if i currently own a momo steering with adapter… and want to put a 7th gen ? My car is a GT-S with SRS… so i have the yellow plug hanging… but if i buy a 7th gen steering, the SRS plug from it wont fit my 6th gen one… what can i do ? I dont have the stock steering with srs anymore…
post Apr 2, 2009 - 6:34 PM
take the momo steering of, and show us a picture. you can still put the steering, the airbag wont be functional.
you need to get the plug otherwise you cant use it.
post Apr 7, 2009 - 6:25 PM
windowlicker
Joined Jul 2, '08
From SoCal
quick question, is there any special process when disconnecting the airbag? i know some cars you have to disconnect the battery and let set for like a half hour before you disconnect it, then there are some that you can disconnect no problem. just got an NRG wheel that i'll be installing in the next week or two and don't want an airbag in the face when i go to do the install.
post Apr 7, 2009 - 6:43 PM
do the safest, disconnect the battery.
post Apr 7, 2009 - 6:48 PM
windowlicker
Joined Jul 2, '08
From SoCal
will do. i get spoiled with the mercedes airbags where i can just unplug them and not worry about it.
post Apr 14, 2009 - 12:41 AM
deliriouzgtfour
Joined May 15, '03
From So Cal,CA
any other precautions before starting...? like discharging the battery from the terminal and taking a fuse out so that the airbag will not deploy? Any other precautions, please let us know. Thanks
I'd hate for something to go wrong.
Otherwise nice DYI post
post Apr 14, 2009 - 2:13 AM
malpaso
Joined Feb 3, '06
QUOTE (deliriouzgtfour @ Apr 14, 2009 - 7:41 AM) *
What I did is only disconnecting battery. Nothing else. No fuses, no nothing else.
post Apr 14, 2009 - 4:17 PM
deliriouzgtfour
Joined May 15, '03
From So Cal,CA
fixed my horn. On the other hand, wire was torn inside for the horn. Thanks malpaso. Anyone willing to do the 7th gen wheel swap for me? Ill pay someone..haha
post Apr 22, 2009 - 1:18 PM
windowlicker
Joined Jul 2, '08
From SoCal
took the airbag off this morning to speed up the process of changing out the wheel possibly tonight. just waiting on the hub from sparco that is supposed to be coming in today. can't wait to get the new wheel and quick release on for this weekend's rallyx.
post Apr 22, 2009 - 1:56 PM
azian_advanced
Joined Apr 18, '05
From Calgary
as long as the 7th gen wheel you get comes with the airbag components, you can wire it up with your stock gt-s airbag harness as mentioned in the how-to.
post Apr 22, 2009 - 2:12 PM
windowlicker
Joined Jul 2, '08
From SoCal
oh, i'm not putting in a toyota wheel, i'm putting in a NRG wheel with quick release. i will not have an airbag, don't want an airbag to the face while taking the car off sweet jumps in a rally.
post Apr 22, 2009 - 9:56 PM
reko
Joined Apr 17, '07
Hey I'm having a hard time trying to put the steering back...
You know where there is the bolt that holds the steering like here in the middle...
well i dont really know how to explain it but the thing on which you put the bolt it kinda shape in a star patern and so is the steering but i cant align those two properly so the steering wont go as far as it's suppose too... thus i can easily remove it...
any tips anyone?
post Apr 22, 2009 - 11:17 PM
windowlicker
Joined Jul 2, '08
From SoCal
well its a little late for this now, but what i have in my tool box at work is a sharpie. whenever i have to change out a steering angle sensor, i mark the 12 o'clock position on the main steering shaft and the wheel so i get the wheel put back on in the right spot. all you can do at this point is count how many turns it takes to go from complete left to complete right, then divide that by 2. it should get approximately where you need it. i would start there and see what you can do. i'd recommend putting the front on jack stands to make it easy to turn the wheel without the car on and that way its easier to take off and put on the wheel in the spot you need without turning the car on.
hope that helps and if there's anything else i may be able to help you with, give me a holler.
post Apr 22, 2009 - 11:25 PM
azian_advanced
Joined Apr 18, '05
From Calgary
yeah the wheel is supposed to be very tight.. use an impact gun to bolt it in or get a big socket 24mm and up and put it around the bolt so it sits on the wheel and carefully hammer it in place.. i dunno just throwing out some ideas...
post Apr 22, 2009 - 11:50 PM
windowlicker
Joined Jul 2, '08
From SoCal
QUOTE (azian_advanced @ Apr 23, 2009 - 12:25 AM) *
it didn't look that big, maybe a 17mm. impact gun works awesome, but if you're in a pinch, a long handled ratchet or breaker bar will do while you hold onto the wheel tight.
This post has been edited by windowlicker: Apr 22, 2009 - 11:51 PM
post Apr 23, 2009 - 8:25 AM
reko
Joined Apr 17, '07
That's the thing... i have a garage, impact gun and a big ass compressor but my car is at home ... without the steering! F*** I guess i'll have to try with the ratchet (then if its tight enough i'll be able to drive all the way to my garage...)
And Windowlicker, i know about the mark but i'm putting a new steering on!
post May 1, 2009 - 10:21 AM
chacha
Joined Dec 29, '05
From So-Cal
what's the part number for the clock spring....all i have is just the steering wheel without it...would it be best just to find a 7th gen clock spring? is that all i need and just splicing?
post Jun 4, 2009 - 7:55 PM
Superaison
Joined Apr 25, '09
From Ohio, USA
I did this today.
Was really easy, I didnt **** with the airbag refill, I just changed the connector on the current spiral to the new, was fast and easy.
Here is pic:
You don't want to know how much I got it for.
This post has been edited by Superaison: Jun 4, 2009 - 8:46 PM
I still own my celica, but i'm parting it out and junking it.. Or selling as a whole. Have a honda prelude now :(
post Jun 5, 2009 - 1:57 AM
Dragondog
Joined May 10, '07
From Lubbock, Texas
i got a question if you swap wheels with one thats not airbag is that illegal? will it pass inspection? someone told me it depends on the year of the car that 94+ must have driver airbag........my home state is texas if that makes a diff?
feedback
feedback
If I buy or sale please leave me feedback...thanks
cheap, quick, reliable, pick two
I treat my 6gc better then my own woman
post Jun 7, 2009 - 9:09 PM
windowlicker
Joined Jul 2, '08
From SoCal
here's some pics of the nrg wheel, nrg quick release, and the sparco hub installed. i really like the position of it as i won't have to be reaching for it when i have the seat reclined in order for me to fit in the car with a helmet on. still need to figure out how to wire up the horn, but i'm lazy....lol
post Jun 7, 2009 - 9:12 PM
windowlicker
Joined Jul 2, '08
From SoCal
QUOTE (Dragondog @ Jun 5, 2009 - 2:57 AM) *
i'd check your state's dmv website and see if anything is on there about it or go to your local inspection shop and ask them. that would be your best bet because a lot of the time people just go off what they hear and it may or may not be the truth. better to hear it from whoever is making the laws or doing the inspections. good luck.
post Jun 17, 2009 - 8:46 PM
windowlicker
Joined Jul 2, '08
From SoCal
ok, i finished wiring the horn in last weekend, so i'll post up what i did in case any of you guys do an aftermarket wheel like me. i used an NRG steering wheel with an NRG quick release and a SPARCO steering wheel hub. for connectors, i used 2 eyelet connectors and an inline splice connector. the reason i used the inline splice connector was in case i want to put the stock wheel back in, i didn't FUBAR the wiring or stock connector. plus its easy to put in and take off if needed.
there were two wires on the quick release and steering wheel horn button, but there was only one wire on the hub. basically i ended up using the one wire from the hub as the positive (signal wire) for the horn, and then i used one of the eyelet connectors on the black wire from the quick release as the ground. i grounded it via one of the screws that attaches the quick release to the hub. there is a metal shim that goes between the quick release and the hub, so you will need to take some cutters and trim out a notch big enough for the connector.
after you get the quick release or wheel firmly attached to the hub, you'll want to move onto locating the signal wire for the horn at the connecter by the steering column. its the green wire at the end of the connector. an easy way to make sure is to take a short piece of wire, slide one end in the connector which is the contact for the green wire and ground it out. if you have the right wire, the horn will beep. i highly recommend doing this with the key out of the ignition. it will work without the key, and the reason i recommend doing it with the key off is so you don't short to ground a different circuit and fry it.
now you're going to need to make a wire that will go from the green wire to the back of the hub. there is a contact area that you need to touch the signal wire to. the contact is the gold colored ring that allows you to keep contact while the wheel is turning.
in order to keep the signal wire contacting the gold ring on the back of the hub, i made a bracket that will constantly touch the gold ring. i made it from a piece of scrap metal i had laying around. it is important to make a smooth curve to the side that will contact the ring, as you don't want to scrape the hell out of the ring, which will lead to wear and a scraping noise.
the part in between my fingers is the part that touches the gold ring.
now you'll want to cut some 16 gauge wire (keep very close to the same size wire as what is at the connector from the steering column) to about 5". on one end you will want to put the second eyelet connector. the end with nothing on it is where you will use the inline splice connector at the green wire.
as for a place to put the bracket i made to contact the gold ring, i am just using the attaching point where the stock clock spring (steering angle sensor) screwed in, and i used the screw from the clock spring as well. sandwich the eyelet connector from the wire and the bracket, then tighten down the screw.
make sure that the curve is directed to make the smoothest path on the gold ring and make sure there is decent tension on the bracket.
don't forget to double check your work through the process and keep checking to see if the horn works through the process. if you keep checking as you go, then the less you have to back track if you make a mistake. it's pretty simple and easy though.
post Jun 20, 2009 - 10:27 AM
AnaXyd
Joined Jul 15, '08
From Norway
Will this swap from f.ex the Celica T23 to T20 actually work if you collide? Have somebody checked this?
post Jul 23, 2009 - 12:25 AM
tankd0g
Joined Oct 4, '07
From Nova Scotia
I just swapped a 99 rav4 wheel into my 5th gen (looks like a 98-99 celica 3 spoke). The 5th gen cruise control switch is an analog device as far as I can tell, with 4 wires on it. The Rav4 switch was a 2 wire digital. So I had to reuse my switch. It fits half decent using two of the holes already in the new wheel. Had to make a little bracket out of a peice of metal that I had but that was it. I thought I was going to be able to put the charge from my 5th gen airbag into the new wheel but it's much bigger than a 6th gen airbag like is pictured at the start of this thread, so no go. I could cut and splice the wires but I'm afraid that the trigger system is different so I decided it was safer just to leave the airbag out. I yanked the airbag light from the dash as well as the ABS light which I also have permanently disabled.
All in all it looks pretty good and the 1" smaller wheel makes for much quicker handling. Can't find the card for my camera or I would have taken pictures for all this but if anyone needs to see what I did with the cruise control switch I can get a picture of it.
post Jul 28, 2009 - 4:29 PM
shegarhuney
Joined Aug 29, '08
From AZ, US
GUYS!!.. i want to share a very very important information with you guys that i just discovered just now!!.. i can confirm this.. coz its working on my car now.. for all you guys that have the gen7 steering wheel n want the cruise control to work with your current clock spring.. instead of splicing n stuff.. you can get the newer version cruise control lever from a 98' or a 99' and its plug and play!!.. i got it to work.. i'm SO SO SO SO HAPPPPYYYYY... SO YUP.. will take some picts to prove my point!!..
FINALLYYY..
BOWAHAHAHAHHHAHAHAHAA..
This post has been edited by shegarhuney: Jan 18, 2010 - 5:35 PM
post Jul 29, 2009 - 1:06 AM
zonz540
Joined Jul 3, '09
From UT
I swapped a GT4 wheel w/out an airbag into my 6gc and it worked great, but decided that id rather have an airbag for safety and emissions. I put it all back together and my light wont go off. Any reset procedures or problems i may have caused? I plugged in all the harnesses and got the clock spring lined up in the center.
post Aug 7, 2009 - 9:51 AM
AnaXyd
Joined Jul 15, '08
From Norway
QUOTE (AnaXyd @ Jun 20, 2009 - 10:27 AM) *
post Jan 10, 2010 - 7:16 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
post Jan 10, 2010 - 8:58 PM
Wintersun
Joined Jan 5, '09
From Kent, United Kingdom
Have a Gen 7 wheel in my Gen 6 SSIII and was easy to swap, just plug and play with horn and airbag.
1996 Green JDM GT4
1998 White JDM SSIII
1994 Black JDM Supra Aerotop
1994 Black JDM GT4
1999 Black UKDM SR
1996 Black UKDM ST
post Jan 16, 2010 - 3:52 AM
abraxxa
Joined Nov 27, '05
From Vienna, Austria
Thanks to malpaso who redirected me to this thread from the gtfour.ch forums to find out how to mount my Lexus IS200/Toyota ST205 JDM hybrid wheel to my ST205.
My problem is just the different airbag connector.
I'll use the Lexus wheel because it's leather and the airbag from the JDM ST205 wheel because of the Toyota Logo.
I have a Rav 4 airbag here two I got from a Lexus guy who wanted the Airbag, also because of the logo, so we swapped.
The airbag from the JDM wheel has two brown wires, the one from the Rav 4 wheel a black an a red one, both have the small connector.
If I cut the wires and mount the big connector from my '96 4-spoke wheel to one of the airbags, how do I find out which way it should be connected?
cya, abraxxa
post Jan 16, 2010 - 11:14 AM
malpaso
Joined Feb 3, '06
QUOTE (abraxxa @ Jan 16, 2010 - 9:52 AM) *
See this topic made by Michelle. Answer is there smile.gif. And do not forget post some pictures when it's done!
post Jan 16, 2010 - 12:25 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
Does the RHD JDM st205 wheel have an air bag? and if so, is it as "direct" of a swap as all these others?
edit: even if it doesnt have an airbag, how easy of a swap would it be?
This post has been edited by devilsden97: Jan 16, 2010 - 12:25 PM
Kawi Love
post Jan 16, 2010 - 3:00 PM
GriffGirl
Joined Feb 7, '07
QUOTE (malpaso @ Jan 16, 2010 - 8:14 AM) *
Black is ground, red is power. If the two wires coming off the wheel itself are both brown, you will need to use a multimeter to see which is which.
QUOTE (devilsden97 @ Jan 16, 2010 - 9:25 AM) *
RHD vs LHD shouldn't matter where the steering wheel is concerned, since it's a circle tongue.gif
As for the directness of the swap, shouldn't be any more direct or less direct a swap than any other wheel discussed here. The wheel will swap right over, the airbag either will plug right in or it won't and you'll have to splice it in. No biggie.
post Jan 18, 2010 - 5:34 PM
shegarhuney
Joined Aug 29, '08
From AZ, US
no more fuss.. the missing link ladies n gentlemen..
QUOTE (FORGMANN @ Jan 17, 2010 - 1:44 PM) *
you don't need to splice any wires just buy this adapter
have to order from here not your dealer ..
http://toyota.spx.com/detail.aspx?id=407&p=173&g=21
This post has been edited by shegarhuney: Jan 18, 2010 - 5:37 PM
post Jan 20, 2010 - 5:25 PM
GriffGirl
Joined Feb 7, '07
Since this thread is pretty much the most thorough how-to-swap-your-steering wheel, I'd love to see it completed with information on how to splice in the 7th gen cruise stalk for those of us not lucky enough to get a 98-99 or whatever it was that's plug-n-play.
As a side note, in the interest of consolidating info, here is how to clear the airbag code, as per the BGB for a '95 USDM Celica
CLEARING CODES
1) At DLC, connect a jumper wire to terminal Tc. See Figs. 11
and 12. Connect another jumper wire to terminal AB. Turn ignition
switch to ACC or ON position. Wait about 6 seconds.
2) Starting with terminal Tc, apply body ground alternately
to terminal Tc and terminal AB twice each, in cycles of 1/2 to 1 1/2
seconds (sequence is: Tc, AB, Tc, AB). Finally, keep applying body
ground to terminal Tc until air bag warning light flashes quickly,
indicating codes are cleared.
NOTE: When alternately connecting jumper probes to terminals,
simultaneously release one probe from one terminal while
connecting other probe to other terminal. If time interval
between probings exceeds 0.2 second, codes will not clear.
post Jan 21, 2010 - 8:32 AM
malpaso
Joined Feb 3, '06
OMG... I really didn't know what my now 3 years old topic can make smile.gif. Thank you all with sharing with your own ways how to solve airbag issue. It's really amazing. bowdown.gif
post Jan 22, 2010 - 12:03 AM
GriffGirl
Joined Feb 7, '07
Now, back to that cruise stalk swap! I'm clearly electrically challenged, so the odds of me figuring this out any time soon are slim. Help? BAAAAAAATMAAAAAN!
post Jan 22, 2010 - 8:23 AM
I just looked over my notes, it's not super clear.
From the 6gen connector from the clockspring there's 3 wires
red
white
right ? (and the black horn)
7 gen to 6 gen
red to red
black (cut) to white
white to white w/black
that all I got, I took them both apart and saw the diff, check itr out smile.gif
good luck
post Jan 29, 2010 - 4:38 PM
shegarhuney
Joined Aug 29, '08
From AZ, US
hehe..
post Jan 29, 2010 - 5:16 PM
abraxxa
Joined Nov 27, '05
Good to see that the adapter fits!
cya, abraxxa
post Jan 29, 2010 - 5:42 PM
yarik83
Joined Nov 22, '04
From FL
malpaso. I understand that you need a puller to remove the column to completely remove wheel but would I be able to take the wheel, unscrew that center piller and somehow rotate my steering wheel 180 degrees without removing it? 2 years back when I had engine swap they mounted my steering wheel upside down. I was wondering if I could pull this off without a puller.
Thank you sir
Captain Pessimist
post Jan 29, 2010 - 5:49 PM
abraxxa
Joined Nov 27, '05
I removed mine about a year ago without a puller but it took about 10-15 minutes.
cya, abraxxa
post Jan 30, 2010 - 1:21 AM
GriffGirl
Joined Feb 7, '07
I needed a puller to remove my 4 spoke wheel, definitely NO way I would've gotten it w/out a puller, but to remove the 3 spoke wheel I don't expect I'd need a puller whatsoever. My guess, Yarik, since yours has been removed once already, is that you may not need one.
If you do need one, you can get it from Autozone; they "rent" them - you buy it for $20, use it, and return it for a refund (their policy!)
post Jan 30, 2010 - 1:56 AM
malpaso
Joined Feb 3, '06
QUOTE (abraxxa @ Jan 29, 2010 - 11:49 PM) *
exactly. depends on wheel... old ST st.wheel was impossible to remove w/o puller but at GT-four it was easy. So unless you give a try you never know smile.gif
post Feb 16, 2010 - 3:50 PM
GriffGirl
Joined Feb 7, '07
QUOTE (shegarhuney @ Jan 18, 2010 - 2:34 PM) *
Just thought I'd update this with my own findings, I was able to order this part off of http://www.handsontools.com/; prior to ordering I emailed to confirm part is in stock - part is in stock and will ship within 48 hrs. Part costs $16 on this site, but shipping is a bit high at $10 for UPS ground.
Edit: sub-"herness"? lol
This post has been edited by GriffGirl: Feb 16, 2010 - 4:02 PM
post Feb 16, 2010 - 4:01 PM
GriffGirl
Joined Feb 7, '07
QUOTE (Batman722 @ Jan 22, 2010 - 5:23 AM) *
red
white
7 gen to 6 gen
red to red
good luck
Can anyone confirm this? I spliced in my 7th gen cruise stalk this weekend but it's not working.
On the 7th gen stalk, the black is crimped in with the white w/black wire, so I basically did the same with the clockspring side of the harness, cut in the W and W/B to the same on the stalk. I'm thinking this is where I went wrong - do I need to separate the B and the W/B on the stalk and splice them in separately to the clockspring side?
Also, would this possibly cause an airbag ecu code? I spliced in my airbag again, blue to black, yellow to red, reset the airbag ecu but the light is still on. I ran diagnostics on it, it's Code 12. Anyone else get this problem?
I have to run through DEQ in a month, and am pretty sure I won't pass if my SRS Warning light is on. Help! tongue.gif
post Feb 16, 2010 - 4:15 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
QUOTE (GriffGirl @ Feb 16, 2010 - 5:01 PM) *
red
white
7 gen to 6 gen
red to red
good luck
how did you clear the airbag code? At the DLC?
My F/S Thread!
Ferdi says (11:29)
post Feb 16, 2010 - 4:52 PM
GriffGirl
Joined Feb 7, '07
QUOTE (GriffGirl @ Jan 20, 2010 - 2:25 PM) *
CLEARING CODES
Edit: Samir, I'll email you the PDF out of the BGB - it's got diagrams and PICTURES! lol
Edit again: Here's the PDFs for anyone else who wants them. "srs.pdf" has the wiring diagram, "airbag restraint system.pdf" contains trouble shooting, reset info and codes interpretation
This post has been edited by GriffGirl: Feb 16, 2010 - 5:06 PM
post Feb 16, 2010 - 4:55 PM
samir0189
Joined Mar 8, '08
ive got the BGB, thats why i was asking if thats how you cleared it. wink.gif In that case, im gonna guess something bigger is wrong, incorrect wiring or something? code 12 is not very specific....
My F/S Thread!
Ferdi says (11:29)
post Feb 16, 2010 - 5:09 PM
GriffGirl
Joined Feb 7, '07
I think you're right, I think it's something with my connections actually.
Today I ordered the adapter harness - a bit too little, too late perhaps, I don't know. I depinned the clock-spring side of the connector, but didn't actually CUT anything off, so it's possible I could re-pin the connector, use the adapter, and be good to go!
post Sep 15, 2011 - 10:02 AM
Arsaces
Joined Oct 7, '10
Hey guys,
I am thinking hard about doing this swap, but I see a lot of people who are having trouble with it and I need to drive this car daily. I have a few questions, and I know some of them have been answered, but I want to be 100% confident and clear before a buy the parts to start the swap. My car is a 95 USDM by the way. First off, if I am lucky and able to find a 98-99 wheel do I still need to do splicing and modding to get the airbag to connect? What about the Rav4 wheel (looks pretty much the same imo)? Regarding cruise control, will I not be able to use my existing 6g cruise control stalk?
Shopping list:
7th gen Wheel or Rav4 wheel or 98-99 6gen wheel
7th gen airbag
Airbag connector adapter
post Sep 15, 2011 - 11:22 AM
abraxxa
Joined Nov 27, '05
Just buy the adapter posted above.
cya, abraxxa
post Sep 15, 2011 - 12:39 PM
Arsaces
Joined Oct 7, '10
QUOTE (abraxxa @ Sep 15, 2011 - 11:22 AM) *
And the current cruise control works just fine?
post Sep 15, 2011 - 12:46 PM
spy00005
Joined May 15, '09
From yonkers, NY
buy the adapter and just leave the cruise control it had thats what i did (with a 7th gen wheel)
*Thing i want for my car(i wish i had money)*
-full gt4 front end conversion (DONE :) JUST NEEDS PAINT(next on to do list) -new seats all around
-riser blocks -fog lights -new radio and speakers all around
-full bodykit splitters and sideskirts to go with conversion (just needs fitting and painting)
-nice rims (Got TC rims and painted them white)
-light blue tint (next step will do this right after i get my paint job)
WTB Reasonably priced
Projectors just Lows
post Sep 15, 2011 - 12:51 PM
Arsaces
Joined Oct 7, '10
QUOTE (spy00005 @ Sep 15, 2011 - 1:46 PM) *
Ok, thank you very much. I really appreciate all of the knowledge that all the people of this forum have shared with me so far, it honestly means a lot.
post Sep 22, 2011 - 10:05 PM
trdproven
Joined Aug 2, '05
From Guam
i disabled my cruise control, the red stitch steering wheel didn't have the extra cruise control lever, but I've never used it anyway.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Sep 23, 2011 - 8:30 PM
Arsaces
Joined Oct 7, '10
Hey guys, got my steering wheel on, I would like to wire up my CC lever. Does anyone still have the splicing information, or can anyone confirm that the connections batman posted are correct? One of the CC levers I have has 3 wires coming off of it, and the other has 2.
post Sep 23, 2011 - 8:51 PM
spy00005
Joined May 15, '09
From yonkers, NY
i used the old cc in my old steering wheel had but don't know about using the splicing.
post Sep 23, 2011 - 9:41 PM
Arsaces
Joined Oct 7, '10
QUOTE (spy00005 @ Sep 23, 2011 - 9:51 PM) *
I was expecting to be able to do the same, but the new stalk is much shorter inside the wheel than the old one was, the old one I have does not fit.
post Sep 24, 2011 - 12:58 AM
spy00005
Joined May 15, '09
From yonkers, NY
which steering wheel are you using because the old cc should fit just not going to be straight out would be angled down something like this \ mine defenatly fit but like i said im using the 7th gen leather wheel have no idea about the other ones ill see if i can take a pic tomorrow.
post Sep 24, 2011 - 4:06 PM
Arsaces
Joined Oct 7, '10
QUOTE (spy00005 @ Sep 24, 2011 - 1:58 AM) *
The ebay listing says that it is off of an 03 celica, but it looks more like a rav4 wheel to me, no leather wrapping, just the same material as our e-brake. The CC off of my car has 3 mounting screws, but the new wheel only has 2 mounting holes, and the mounting area is much smaller making it so that the old one will not fit.
8 Pages V   1 2 3 > »
Lo-Fi Version Time is now: January 10th, 2026 - 2:55 PM
