> performance alignment, anybody got specs?
post Jan 25, 2007 - 6:34 PM
JaxMadine
Joined Jan 31, '06
Doing an alignment tomorrow, just wondering if anybody has some good specs floating around that give better handling and no odd wear.
Replies (1 - 6)
post Jan 25, 2007 - 6:37 PM
Rayme
Joined Feb 18, '06
From NB, Canada
none, just stay stock and get better tires.
What I mean is alignment adjustment can make a difference on circuit, lowering the lap times etc...its definitly not something you will experience on the street, especially with degrees low enough to not have un-even wear. I know theres a tire company that makes tires with harder insides, so that you can have some degrees of negative camber without too much wear.
Edit Found it :
Nitto geogen
http://www.nittotire.com/extras_ads_negative.asp
This post has been edited by Rayme: Jan 25, 2007 - 6:42 PM
-Rémy
02 SiR, 08 250R
post Jan 25, 2007 - 10:23 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
thats awesome, I didn't know they made tires like that
a slightly negative camber will improve your traction while cornering by keeping a bigger contact patch with the ground in a high speed turn... but how often do you take turns like that while you're going to the supermarket
if you don't have them already get front and rear strut bars, you'll be amazed smile.gif
I <3 Dustin---07/16/06
post Jan 25, 2007 - 10:30 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
QUOTE(hurley97 @ Jan 25, 2007 - 8:23 PM) [snapback]521418[/snapback]
3 point strut bar because 2 does not even come close and sway bars really make a difference
post Jan 26, 2007 - 10:10 AM
JaxMadine
Joined Jan 31, '06
Yes, i know all this, I was just wondering if anyone had a proven alignment setup. I guess Ill be the one to toy with alignments and do a report on it later.
post Jan 26, 2007 - 11:12 AM
well unless u have Cusco Pillow mounts up front your camber there is pretty limited and Rear camber is going to be very limited..crash bolts will help some though...
i really wouldn't recommend more then
1.5* in the front
1.0* in the back
of negative camber
This post has been edited by playr158: Jan 26, 2007 - 11:51 AM
post Jan 26, 2007 - 5:53 PM
JaxMadine
Joined Jan 31, '06
Well turns out that aligning a celica sucks major butt. add to it that they put bolts in the wrong places with different nuts. I just did the max spec align. which is -1.3 camb in the front, and spec toe all the way around. Last time I do that.
Lo-Fi Version Time is now: February 21st, 2025 - 2:00 PM
