> fuse panel
post Jan 30, 2007 - 11:50 PM
twolownissan2002
Joined Mar 22, '06
From Wesley chapel, Florida
ok first off i have a 94 gt 5 speed and i got it for 800 dollors and i has a couple problems but this is the main one has anyone had the fuse that say alt 100a blow and if so how do you replace it because i don tget it i is built in to the fuse panel and took it all apart but still no luck so any kind of help would be great thanks gary
Replies (1 - 11)
post Jan 31, 2007 - 1:03 AM
that fuse is in the engine bay and it's a big one. It does come out and you can get a replacement for it at any auto parts store (autozone, ect). If it blew then most likely it's *fused* in there. Get it out however you can (use needle nose plyers to pry out the prongs). Get the replacement and you'll see how long the prongs are, they go deep.
post Jan 31, 2007 - 1:16 AM
twolownissan2002
Joined Mar 22, '06
ok because the people who had it before just tried to get it out and broke all the plaset 5hit around it off and the prong where the only thing left then they filled it with vasaline lol have no clue y lol
post Jan 31, 2007 - 1:23 AM
betweenlies
Joined Apr 16, '06
From pawtucket ri
yea that happend to me its kinda of a hack job tho one of my old prongs is fused in ther so with the replacement had bend it a lil bit it still works fine and all only sometimes it tends to pop out all you have to do is push it back in but i wish you the best of luck and hope it dose not turn out as bad
post Jan 31, 2007 - 11:15 AM
twolownissan2002
Joined Mar 22, '06
when guys fuse went out did all your **** stop workin in the car i hope because none of mine works
post Jan 31, 2007 - 12:50 PM
Yes. Everything will be screwed up and either not work or not work properly until it's secure in there again.
post Jan 31, 2007 - 7:03 PM
twolownissan2002
Joined Mar 22, '06
man i love this site lol everything works great now lol and i have a perfect car that i oly gave 800 dollors for thanks gary
post Feb 2, 2007 - 12:46 AM
post Feb 3, 2007 - 12:57 PM
Remy
Joined Jan 25, '06
From MN
How did you get that fuse out ?? I tried pulling it out and broke the plastic around it then I used more forced then I pulled out and cracked the fuse box.... kindasad.gif
post Feb 5, 2007 - 2:17 PM
twolownissan2002
Joined Mar 22, '06
you have to unbolt the fuse box there is i think 3 or 4 bolts then when you do that there is clip that hold the black plastic around the fuses under that there is too bolts on both sides of the fuse remove those and slide it out
post Feb 5, 2007 - 9:09 PM
Remy
Joined Jan 25, '06
From MN
post Feb 7, 2007 - 4:13 PM
Remy
Joined Jan 25, '06
From MN
I got it out thanks for the help didn't know their was screws holding it down. tongue.gif smile.gif
Lo-Fi Version Time is now: February 24th, 2025 - 5:21 AM
