> Turbo st owners
post Feb 6, 2007 - 7:39 PM
rayneezy23
Joined Jun 25, '06
From Bremerton, Washington
I was wonderin if, it is worth to turbo a st because i dont have the money to do a engine swap
Replies (1 - 11)
post Feb 6, 2007 - 8:20 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
i think to do it correctly, it would come to just a little less to turbo your engine then to just swap it, take ur time, save ur money, do your research n wait for the swap, why go for 180hp when you can go for 250-300 hp
post Feb 6, 2007 - 10:30 PM
rayneezy23
Joined Jun 25, '06
yeah your right thanks for the info
post Feb 6, 2007 - 10:57 PM
nate95
Joined May 5, '05
From mattoon, IL
i personaly liked the power that the turbo gave my ST, i just got tired of maintaining it kindasad.gif
post Feb 7, 2007 - 12:38 AM
QUOTE(nate95 @ Feb 6, 2007 - 10:57 PM) [snapback]524594[/snapback]
what kind of issues did you run into, nate?
post Feb 7, 2007 - 4:10 PM
trd94
Joined Jan 9, '05
From green springs ohio
alot depends on what you want , as far as money goes there about the same ,if you do the turbo right , and if done right your hp level could be close to the same ( just swapping the motor and not upgrading the 3sgte) , but tuning the 7a is a bit more of a trick and that is where alot of people have the trouble of (issues) , as far as being differant i think the 7afte would be the way to go , alot of guys do the swap i have seen at least 4 done so far in my area, but i am the only 7afte that i know of here in NW ohio, now if you want more hp than 200-220 than the 3s swap would be a better deal. that is my 2 cent , so as far as money goes they are both the same just one you drop in and the other you tune your A$$ off .
This post has been edited by trd94: Feb 7, 2007 - 4:12 PM
post Feb 9, 2007 - 1:46 PM
kriz45
Joined Jun 17, '06
From bellevue washington
but if you were doing a swap woulndt you have to replace the transmission and axels as well as the engine? so wouldnt it be cheaper to just turbo the ST?
post Feb 9, 2007 - 3:32 PM
trd94
Joined Jan 9, '05
QUOTE(kriz45 @ Feb 9, 2007 - 1:46 PM) [snapback]525444[/snapback]
yes you do have to swap tranny and axles, and the 7afte would be more of a bolt on and go but, the cost for the 7afte is tuning the dyno times cost, if your a good tuner you should be able to get every thing tuned in about 4-5 hours but as for myself as i am new to this and i have to be showed it has taken about 15 hours and i still have alot to learn wink.gif if the tune is not done right the 7a will end up costing you more than a swap , because you will start to replace things you would not have normally biggrin.gif
This post has been edited by trd94: Feb 9, 2007 - 3:33 PM
post Feb 9, 2007 - 5:35 PM
kriz45
Joined Jun 17, '06
oh ok. thank you
post Feb 12, 2007 - 11:57 PM
trdcelica94
Joined Apr 29, '03
From socal
turbo st all the way im happy with it it pulls hard on the freeway and has good accelerations a fun car swap is cool too
post Feb 13, 2007 - 3:30 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
I regret turboing my ST but did it knowing I would. I just wanted to prove a point. Anyway, so far, so good. No big problems or anything, but it was more expensive than a swap. Also, I didn't live here so turboing was quicker.
post Feb 13, 2007 - 3:51 PM
trd94
Joined Jan 9, '05
QUOTE(OOBE @ Feb 13, 2007 - 3:30 PM) [snapback]526526[/snapback]
if you regret it then why not do the swap , just a question? if your not happy with it then why put in the time or money in it? dont think i am trying to be a jerk or any thing ,i just am a little curious that is all.
Lo-Fi Version Time is now: February 24th, 2025 - 8:36 AM
