I have a question..... |
Feb 7, 2007 - 3:17 AM |
Enthusiast Joined Mar 20, '06 From S.D. Currently Offline Reputation: 0 (0%) |
Will a '94 GT 5S-FE engine fit into a '94 ST ??
Feb 7, 2007 - 3:49 AM |
Enthusiast Joined Apr 24, '04 From S. Cali Currently Offline Reputation: 0 (0%) |
quick answer yes. But from what ive heard you need to change engine mounts and some other stuff. but doable. but if youre gonna do that why not just swap in a 3sgte. you'll be happier with that
This post has been edited by Davesceli: Feb 7, 2007 - 4:00 AM |
Feb 7, 2007 - 12:47 PM |
oh because I have a '94 ST that have 200K on the engine and I also have the 5S-Fe with 120K so i just want to drop that in...
Feb 7, 2007 - 5:20 PM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
Not an easy job.
You'd need Engine [which you have], Tranny, axles, wiring harness, ECU and probably a ton of things I'm not thinking of. Basically you would be doing 90% of the same work required to swap to 3S-GTE. Not really worth it IMO. I think a newly rebuilt 7A would be cheaper and easier. BTW - Your profile lists you as a GT. Are you sure you have an ST? Does the 5s you have laying around look like the motor already in your car? This post has been edited by Negative: Feb 7, 2007 - 5:21 PM -------------------- |
Feb 16, 2007 - 9:19 PM |
Enthusiast Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
unless the pics in ur profile are wring then you have a gt, not an st. if it is a gt then the swap would be cake.
Lo-Fi Version | Time is now: November 24th, 2024 - 1:21 PM |
