![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) ![]() |
Im pretty sure ive seen someone post up the wiring/pin position of the harnesses on the back of the gauge clusters for either the st204 or the 205 or both.
i tried searching both the FI and this section of the forum under "gauge cluster wiring" and came up with nothing. anyone know where i can find what each wire on the back of the gauge cluster harness does??? thanks a bunch. and also i assume the 3s and the 5s ecu have the same voltage amount for the speed the car is going. i.e. 50mph is 1.5v with both the 3s ecu and the 5s ecu and its the gauge/needle thingy determins at what position it needs to be at with the 1.5v input. I assume this because even tho i have a 3s hooked up to a 5s cluster the cluster still reads the revs and the speed are not affected. man im tired... did that makes sence??? well all i need are the wiring diagramms for the clusters on both the st204 and 205 thanks |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) ![]() |
AT200/ST204 to ST205 Combo Meter How-To
I'm pretty sure that the SPD signal it's not a constant voltage going to the ECU. Everything I've read says that it's a pulsed signal and the frequency of the pulses is what tells the speedometer and ECU how fast you're going. If it was a simple voltage signal the speed limiters would be a lot easier to defeat. Hope that helps. -------------------- ![]() Project ST204.5 99.88946% complete... |
thanks now i feel like a wanker cus i checked the sticky for the FI but failed to check the sticky here and yet i posted my question in this section...
thanks a bunch... |
That's ok. We already knew you were a wanker...
![]() -------------------- ![]() Project ST204.5 99.88946% complete... |
Lo-Fi Version | Time is now: February 23rd, 2025 - 10:51 PM |
