> Suspension Suggestions/ Help
post Feb 10, 2007 - 3:30 PM
Smitty2145
Joined Aug 24, '06
From Michigan
I have been purchasing some suspension components over the last few weeks, tell me what you think of the set-up and please feel free to give me suggestions.
KYB Gr-2 Gas Shocks/ Struts
Tanabe DF210 (drop springs)
St185 Performance sway bar links
Suspension Techniques Rear Sway bar
Neon Front Strut Bar
Replies (1 - 6)
post Feb 10, 2007 - 4:15 PM
lilgreenyoda
Joined Jan 22, '07
From Loveland
The GR-2s are basically a stock replacement. Not much of an upgrade, but a little. They probably won't last as long as you'd like them too if its dropped. They'll work for now, but the KYB AGX shocks are a little better suited for dropping purposes because you can adjust the firmness on the AGXs.
post Feb 10, 2007 - 4:22 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
neon strut bar wont do anything too, get a 3 point brace
post Feb 10, 2007 - 5:45 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(LewFX @ Feb 10, 2007 - 4:22 PM) [snapback]525751[/snapback]
Yes it will, just pare it with the stock GT brace that mounts to the firewall. I didn't know the st185 end links would help, or fit. You might get a little more understeer than best performing with only the rear sway bar, but that depends on what you like.
Live Free, Be Happy
post Feb 10, 2007 - 6:33 PM
LewFX
Joined Jan 28, '05
he never said he has a GT or ST, my GT didnt have a strut bar
post Feb 12, 2007 - 8:01 PM
JesterDC
Joined Jun 21, '06
QUOTE(LewFX @ Feb 10, 2007 - 7:33 PM) [snapback]525774[/snapback]
I'm pretty sure all GT's before 1998 did, so that's why you don't have one wink.gif
post Feb 12, 2007 - 8:23 PM
airfron
Joined Jul 31, '05
From Southern California
i have close to the same setup, the same springs, sways and cheepo front strut bar.... you definitely want to get that front sway bar.. i was on just the rear for a while and noticed a huge change when i got the front on.. if you are looking for an adjustible shock i hear good things about the koni yellow's, the kyb's are pretty much just an oem replacement
Lo-Fi Version Time is now: February 20th, 2025 - 6:09 AM
