I have had my indiglo gauges installed for almost a year, I haven't made any changes on the car ( besides the battery which I replaced like a 1 1/2 months ago ) and now my gauges blink are the same speed as my tachometer, if I speed up the blink faster and the other way around. ![]() has anyone have this happen before ? what should I look for ? -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) ![]() |
u should check your power (12v +)wire...where did u wired urs to?...
QUOTE(DeW_H0e_GT @ Feb 20, 2007 - 10:58 PM) [snapback]528885[/snapback] u should check your power (12v +)wire...where did u wired urs to?... to the ignition, they worked fine for all this time and now they started blinking -------------------- ![]() |
i would hceck all your ground connections....take your gauge wiring out n try to wire it again.....
Enthusiast Joined Jun 6, '11 From bulldog1 Currently Offline Reputation: 0 (0%) ![]() |
it did it with mine, with time it shorts, or maybe bad luck, i went beams oem!
Feb 20, 2007 - 10:12 PM
I didn't even remember I had indiglo gauges at some point. ![]() -------------------- ![]() |
Lo-Fi Version | Time is now: February 17th, 2025 - 11:24 AM |
